Vehicle in question is our 2012 Jeep Liberty Sport 4wd.
Replaced front pads and rotors yesterday due to some sticking pads due to rust buildup. The passenger side was the worst, but the bracket cleaned up and the pads move freely in the hardware. The piston on the caliper moved in, albeit a little bit hard, but nothing felt like it was binding. After the job was done on the test drive the passenger side was definitely locked up, not too hard as I could still drive the vehicle, but it smoked a little bit. Jacked it up and it was definitely not moving. Do you guys feel this is a caliper issue? It is the original with 91K on it. I did completely flush the whole brake system before hand and it seemed to pull fluid fine, so I assume the brake hose is ok? Kinda at a loss here, don't want to slap a caliper on it if I don't need to, but there was a fair amount of surface rust on the piston.
