Chery A520 2.0 L Transmisstion Oil
by Omar_Eltahan - 01/20/20 02:38 AM
castrol 5w30 c3 for an LS?
by neo3 - 01/19/20 11:32 PM
Windows 10 Upgrade Guide
by OVERKILL - 01/19/20 09:59 PM
FCA and Foxconn partner on EV's
by OVERKILL - 01/19/20 08:55 PM
IIHS Crash pics of Full Size Trucks
by kstanf150 - 01/19/20 08:15 PM
Are Engine Splash Guards Really Needed?
by Mr_Luke - 01/19/20 08:14 PM
supertec cartridge filters
by super20dan - 01/19/20 06:17 PM
More Valvoline on rollback at WM
by jayjr1105 - 01/19/20 06:13 PM
Crossed poles on jumper cables
by 3Aone - 01/19/20 05:33 PM
Napa Gold 7060 7.5K miles
by KenshinHimura - 01/19/20 05:09 PM
Can you move a car with the starter?
by atikovi - 01/19/20 04:49 PM
Leaf spring advice.
by mpack88 - 01/19/20 02:19 PM
Detroit 4-53T swap update.
by A310 - 01/19/20 12:54 PM
Wiper arm tension...
by Loogie - 01/19/20 12:26 PM
Changing Battery
by Char Baby - 01/19/20 12:16 PM
UOA shelf life
by STIcandy - 01/19/20 12:02 PM
Harry_Seaward, MrH1325, Thetarmac, lbstyling, tanpw
70483 Registered Users
43 registered members (67ZL1, brages, Astro_Guy, Bighorn2500, Bookmaker, 6 invisible), 1,637 guests, and 21 spiders.
Topics300,336
Posts5,173,609
Members70,483
Most Online3,825
Jan 19th, 2020
My friend mustang die while on high way #5199334 08/28/19 08:45 PM
M
MetalSlug Offline OP
M
My friend call me . He stay 8 hours away . Anyway he got 97 mustang gt . While he on highway . Suddenly the car loose power and he push the gas and the car won’t do nothing . It end up cut off . Light is good . I told him might be fuel pump . Try hit it while crank . It try to crank but it won’t turn over . Now the battery dead because he try to crank it many time .
Re: My friend mustang die while on high way [Re: MetalSlug] #5199342 08/28/19 08:52 PM
M
M
Is dead battery cause engine to loose power and shut off like that ?
Re: My friend mustang die while on high way [Re: MetalSlug] #5199343 08/28/19 08:52 PM
F
Fawteen Offline
F
Tow it to a mechanic and get it fixed.
Re: My friend mustang die while on high way [Re: MetalSlug] #5199347 08/28/19 08:58 PM
K
kstanf150 Offline
K
Man that’s hard to read
Re: My friend mustang die while on high way [Re: MetalSlug] #5199351 08/28/19 09:03 PM
clinebarger Offline
If IIRC.....The fuel pump relay is built into a module in the right front fender. I've seen those go belly-up from cracked solder joints.
There's also a Inertia Trip switch in-line on the fuel pump power circuit, I've also seen those go bad & trip over the slightest bump in the road.
See if it's a fuel pressure issue first by using a alternative fuel source....Then check if the pump actually has power which is easily done at the Inertia Switch.
One side should have B+ while cranking & the other should have a Ground return from the pump motor (Through the windings).....If that shows good, Short the to pins/circuits together to bypass the Inertia Switch.
2001 Chevy Camaro L92/4L80E
Re: My friend mustang die while on high way [Re: MetalSlug] #5199354 08/28/19 09:06 PM
clinebarger Offline
People tend to freak out when a car dies & run the battery dead trying to get in running again, Like it's going to magically fix itself.......
Re: My friend mustang die while on high way [Re: clinebarger] #5199361 08/28/19 09:21 PM
T
The_Eric Offline
T
Yup. Crank it a few times to see what it does or doesn't do, then save the battery.
2005 Lincoln Aviator 4.6 DOHC
2000 Honda Accord 2.3
2001 Hyundai Elantra 2.0
1979 Ford F-150 351M
Re: My friend mustang die while on high way [Re: MetalSlug] #5199368 08/28/19 09:28 PM
M
M
Sad that I am 8 hours away . I told him gone ahead and call the town truck . And ask him to take to a shop that he know well . And bite the bill . I told him I will send him $200 on top of what ever bill he have to pay. Kinda help him out .
Re: My friend mustang die while on high way [Re: MetalSlug] #5199370 08/28/19 09:29 PM
M
M
Most important thing as 10:28 pm is get off the highway and go home .
Re: My friend mustang die while on high way [Re: MetalSlug] #5199374 08/28/19 09:33 PM
TheLoneRanger Offline
Might simply be out of gas...? oilburner
Some days you eat the bear, some days the bear eats you.....
Re: My friend mustang die while on high way [Re: TheLoneRanger] #5199387 08/28/19 09:46 PM
A
Anduril Offline
A
One thing Ive learned since getting a Mustang - when the low fuel light comes on, you get gas NOW. With a 15 gallon tank and not the most fuel efficient engine, you can't get terribly far at that point. The first time I ran mine down, I ended up running out of gas in the gas station parking lot.
2015 Nissan Versa Note 1.6/5MT
2012 Toyota Tacoma 2.7/4AT
2007 Toyota Camry 2.4/5AT
2005 Nissan XTerra 4x4 4.0/6MT
2002 Mustang GT Convertible 4.6/5MT
2009 Kawasaki Vulcan 900
2013 Hyosung ST7
Re: My friend mustang die while on high way [Re: MetalSlug] #5199389 08/28/19 09:49 PM
V
vavavroom Offline
V
I thought your horse died. Whew! smirk There are a lot of things that can cause the engine stalling. It's got to do with interrupting air or fuel flow or missing spark. Could be anything from a failed fuel pump/clogged fuel filter, bad MAF/MAP sensor, ECU problem, bad ground, bad crank or cam position sensor or even a bad ignition switch.
Re: My friend mustang die while on high way [Re: kstanf150] #5199406 08/28/19 10:36 PM
L
Lolvoguy Offline
L
LOL
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: My friend mustang die while on high way [Re: kstanf150] #5199525 08/29/19 05:48 AM
AZjeff Offline
Maybe so but he's a good friend.
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP
18 Nissan Titan 5.6 DI, QSUD
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: My friend mustang die while on high way [Re: MetalSlug] #5199591 08/29/19 07:03 AM
R
ragtoplvr Offline
R
Mechanics love it when people need a repair, and then burn up their starter and ruin the battery cranking on it hoping something will change. On a fuel injected car, the odds of it starting after a few more seconds of cranking are very small. Modern gear reduction permanent magnet starters do not have a lot of thermal capacity, and are pretty easy to burn up too. I have seen armatures turn blue from the heat. Spend 250 or more just to get it to crank and then find out what is wrong.
Rod
