Found a small screw in my tire tread tonight, tires are fairly new, were put on around 4 months ago. It does appear to be in a location that is safe to repair, I'm just not sure if I should since the tire still holds air just fine.
Tread depth where the small screw went in = 8/32 or 9/32, around 6.35mm - 7.14mm.
Shaft length of small screw, 11-12mm (can't remember the exact number with dial caliper.)
It kind of seemed like the screw went in at an angle when I pulled it out, I can't remember exactly. Would you still repair the tire just in case? Or keep driving, and not worry about it.
*Oh, just to be clear. In the pictures the screw is just sitting on top of the tire, I included it for a size reference.
