94 B4000 overheat Eureka
by HyundaiAbuser - 02/17/20 05:48 PM
PP Euro 5w40 SN Plus formulation VOA
by BurntMusic - 02/17/20 04:35 PM
Bicycle Shops
by CourierDriver - 02/17/20 04:26 PM
EBC Brakes
by hatt - 02/17/20 04:17 PM
Dream Car
by MrQuackers - 02/17/20 04:06 PM
What are people using now for outdoor antennas?
by BAJA_05 - 02/17/20 02:49 PM
3.0L TDI
by Shorthorn - 02/17/20 02:48 PM
Mountain Bike Whee/Tire Sizes!
by jcartwright99 - 02/17/20 02:21 PM
Found this old Fram XG8A on eBay
by blufeb95 - 02/17/20 01:54 PM
2005 Civic Horn Replacement
by cb450sc - 02/17/20 01:51 PM
QS Conv vs. QS HM vs. PYB
by Fordiesel69 - 02/17/20 01:09 PM
Kia Proceed?
by WhyMe - 02/17/20 12:44 PM
RIP Donald Stratton
by 02SE - 02/17/20 12:41 PM
WIX 51393 C&P
by FordBroncoVWJeta - 02/17/20 12:09 PM
Interesting find..
by Mad_Hatter - 02/17/20 10:09 AM
Step Shift Transmission
by Gebo - 02/17/20 09:24 AM
Hope to hear from State Farm today
by WyrTwister - 02/17/20 09:20 AM
jds59, JimMorrison, bjfangjd, 45ander5, FlightRT
70725 Registered Users
117 registered members (762fermeandyou, 2013ecof150, 01rangerxl, AandPDan, 2K2AcuraTL, 55hambone, 10 invisible), 2,247 guests, and 27 spiders.
Topics301,580
Posts5,198,415
Members70,725
Pennzoil platinum 5W30 2008 Toyota Sienna 230,000 miles #5199160 08/28/19 05:09 PM
G
GYA Offline OP
G
Blackstone did the analysis. 7000 miles on the oil with .25 quart make up.The two elevated metals are aluminum at 9. Average is 4. Iron at 33. Average is 8. Everything else is normal. Any thoughts? It’s a high mileage van that remains a strong runner.
Re: Pennzoil platinum 5W30 2008 Toyota Sienna 230,000 miles [Re: GYA] #5199168 08/28/19 05:19 PM
danez_yoda Offline
Supertech dino. smile
Is there a thread on which oils have repeatedly reduced iron and aluminum on this forum? I don't recall any but it would be nice.
That said your van running a good oil as is with the PP. I highly doubt an oil from a different bottle will solve the problem. be careful with changing viscosity since that engine is a
VVT engine. The oil viscosity has a role to play on how it works. 5W-30 is a good middle of the road oil.
Re: Pennzoil platinum 5W30 2008 Toyota Sienna 230,000 miles [Re: GYA] #5199171 08/28/19 05:21 PM
O
Onetor Offline
O
Every engine wears differently. Blk St only gets a very small representative sample size. It's not a true and accurate reading. That is what i have learned on BITOG. I'm not an expert, maybe Buster can explain it better. If I'm wrong, I'm wrong....
Race engines are physically measured for a reason. UOA s are good for trend analysis etc.....I' have used Blackstone Labs and they are awesome.So, Im not knocking them. A chemist told me that anything over a 100 ppm is a red flag. Every engine/driver/environment are different though
N = R* x fp x ne x fl x fi x fc x L
Re: Pennzoil platinum 5W30 2008 Toyota Sienna 230,000 miles [Re: GYA] #5199181 08/28/19 05:36 PM
Slick17601 Offline
Looks good, does it have piston slap when it is cold?
2018 RAM Bighorn 5.7
2008 Toyota Sienna 3.5
Re: Pennzoil platinum 5W30 2008 Toyota Sienna 230,000 miles [Re: Slick17601] #5199211 08/28/19 06:04 PM
G
GYA Offline OP
G
Yes it does.
Re: Pennzoil platinum 5W30 2008 Toyota Sienna 230,000 miles [Re: danez_yoda] #5199296 08/28/19 07:51 PM
dave1251 Offline
Pennzoil "conventional" is your iron answer.
don't use.
Re: Pennzoil platinum 5W30 2008 Toyota Sienna 230,000 miles [Re: GYA] #5199476 08/29/19 03:36 AM
demarpaint Offline
Is this the very first run with the PP 5W30? If so the results are usually a more accurate representation of how an oil did after the second run because any residual oil from a prior brand are out of the engine. If not, check again after another 5K run and see if anything changes.
God Bless Our Troops
Re: Pennzoil platinum 5W30 2008 Toyota Sienna 230,000 miles [Re: GYA] #5199488 08/29/19 04:15 AM
dnewton3 Offline
Global Moderator
Global Moderator
This is a sample size of ONE. Let's not jump to conclusions.
I concur with Blackstone and would recommend you take another UOA in 5k miles. See if there is an upward trend, downward trend, or little change.
Overall, the Blackstone averages are reasonably accurate. What you don't directly get from Blackstone is the understanding of normal variation. But I assure all they have PLENTY of data on this engine series; this is a widely used engine in many Toyota platforms.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: Pennzoil platinum 5W30 2008 Toyota Sienna 230,000 miles [Re: GYA] #5199526 08/29/19 05:49 AM
Spector Offline
at 230,000 miles why waste your money on a UOA. Unless you are willing to do something dramatic and spend $$$$ on this engine why bother, just drive it until it dies. Seriously, what are you going to do if it continues to give high iron, other than changing the oil more often to get the numbers down UOA are sort of useless other than to look for coolant etc.
Re: Pennzoil platinum 5W30 2008 Toyota Sienna 230,000 miles [Re: Spector] #5199529 08/29/19 06:00 AM
danez_yoda Offline
yup. it could go another 100k miles with 100ppm/5k on iron and not fail, all depends on where the iron is coming from. we all imagine its the engine block, it could be something that is rusted and slowly shedding iron particles as well.
Re: Pennzoil platinum 5W30 2008 Toyota Sienna 230,000 miles [Re: GYA] #5200847 08/30/19 04:41 PM
M
Mad_Hatter Offline
M
dnewton is right, you need to do a 2nd or even a third UOA to establish a trend. Good thing is you don't need to do an expensive UOA.
Just looking at this one UOA stand alone, I'd try running a thicker oil with a higher AW add pk. Like a 10w30 (higher 150c kv) HiMi. I'm not sure backing off the miles would get the wear metals down to where you want them. Then again it could be a case where no oil is able to accomplish that, given the age of the vehicle. But I'd try a HiMi next if it were me... both QS and Chevron make a syn blend HiMi that are worth a try.
[Linked Image]
Re: Pennzoil platinum 5W30 2008 Toyota Sienna 230,000 miles [Re: Spector] #5201025 08/30/19 08:43 PM
G
GYA Offline OP
G
The UOA was only $28. Not a big cost. I bought the vehicle on the wholesale market for $2000 w/212,000 miles. It’s AWD and the body is excellent. Colorado vehicle so the underside is clean. I use it to tow a 16ft airstream Bambi. Mostly it’s for short trips to work and back. About one mile each way. I average 8000 miles a year. Everything works. Just posting and testing for my interest and your viewing pleasure. If the motor pops then it’ll be on the salvage market.
Re: Pennzoil platinum 5W30 2008 Toyota Sienna 230,000 miles [Re: GYA] #5201107 08/30/19 10:53 PM
Deontologist Offline
Seems pretty typical for a 2GR:
https://www.clublexus.com/forums/is-2nd-gen-2006-2013/922424-2012-is350-used-oil-analysis.html
My IS350 with the 2GR-FSE showed similarly high iron and aluminum levels after a 6500 mile interval. Nothing to worry about.
Re: Pennzoil platinum 5W30 2008 Toyota Sienna 230,000 miles [Re: GYA] #5201125 08/30/19 11:34 PM
M
Mad_Hatter Offline
M
Sounds like you have the right attitude👍.. you could try switching up lubes but at $2000 but meh...it is what it is, right?
Re: Pennzoil platinum 5W30 2008 Toyota Sienna 230,000 miles [Re: GYA] #5201613 08/31/19 05:29 PM
dave1251 Offline
Switch to a "conventional" 30 grade for annual OCI's the iron will trend down.
don't use.
