New Valvoline looks promising?
by kr_bitog - 02/22/20 08:45 PM
rock like debris in generac generator 17kw
by jb5150 - 02/22/20 08:25 PM
FL820S C&P BAD GLUE JOB
by naterbomb - 02/22/20 08:21 PM
Photo Uploader Not Working
by ZeeOSix - 02/22/20 07:49 PM
Faulty clutch master cylinder 17” Honda Civic
by parshisa - 02/22/20 07:33 PM
Ford drain plugs
by buck91 - 02/22/20 07:09 PM
What's the greatest amount of miles you've heard of someone
by Speak2Mountain - 02/22/20 05:53 PM
Oil Jug - Leaking
by MasterSolenoid - 02/22/20 05:40 PM
Which one
by tiger862 - 02/22/20 05:05 PM
HM from the start?
by AJB0009 - 02/22/20 04:00 PM
Fram XG3600 instead of XG3614
by BTW574 - 02/22/20 03:57 PM
Unbranded Hydraulic Fluid Filters
by shibby6600 - 02/22/20 03:53 PM
Homemade pizza
by 53' Stude - 02/22/20 03:07 PM
New Shoes For The Tacoma!
by Delta - 02/22/20 02:52 PM
Giti tires - newish large brand.
by pezzy669 - 02/22/20 02:51 PM
New pennzoil oils
by Spitter - 02/22/20 02:26 PM
Breaking in the new clutch. Backwards.
by Chris142 - 02/22/20 02:18 PM
Toyota 0W20 $2.95 + shipping YMMV
by Q451990 - 02/22/20 01:34 PM
Toyota Catalytic Converter (B2)
by MaximaGuy - 02/22/20 01:31 PM
The Camry lives!
by 53' Stude - 02/22/20 01:01 PM
Markovchain, o_s, naterbomb, Jimiii, jb5150
70784 Registered Users
102 registered members (Ag76, AC1DD, ABursell, alchargo, 2003f7, 2009Caraman, 8 invisible), 1,981 guests, and 21 spiders.
Topics301,806
Posts5,203,088
Members70,784
Help Finding 24V motor #5198811 08/28/19 10:35 AM
DriveHard Offline OP
Mods, please move if there is a better spot.
My team builds prototype machines...this particular application is giving me a headache. Any help would be GREATLY appreciated!
Looking for:
Variable Speed Electric Motor and Controller
24V
Minimum 3.5 kW (~5 hp)
Must be able to go up to 2000 rpm (would prefer maximum rpm of 3500-4000)
Smile, it increases your face value
2013 Fiat 500 Abarth mod heavy (my DD)
2018 Alfa Romeo Stelvio TI Sport (wife's)
2011 Silverado Crew Cab LT 6.2L/6spd (tow pig)
2007 Nissan Xterra (trail toy)
Re: Help Finding 24V motor [Re: DriveHard] #5198820 08/28/19 10:42 AM
W
Wolf359 Online Content
Online Content
W
That's a pretty tough spec which is probably why it's giving you a headache. Usually for something like that, you like higher voltage like 240v because those motors last longer than 120v. Let us know if you find it.
Re: Help Finding 24V motor [Re: DriveHard] #5198830 08/28/19 10:54 AM
Chris Meutsch Offline
Call these people, ask for Ian.
https://www.matlockelectric.com/
2005 Honda CR-V EX, 280k
Re: Help Finding 24V motor [Re: DriveHard] #5198889 08/28/19 11:51 AM
T
The_Eric Offline
T
Try looking at military surplus motors that run hydraulics or other associated devices.
2005 Lincoln Aviator 4.6 DOHC
2000 Honda Accord 2.3
2001 Hyundai Elantra 2.0
1979 Ford F-150 351M
Re: Help Finding 24V motor [Re: DriveHard] #5198934 08/28/19 12:45 PM
M
meep Offline
M
5HP from 24V is crazy. 3.6KW at 24V is like 150 amps. That's starter motor territory.
2018 F150
2015 crv (wifey!)
Re: Help Finding 24V motor [Re: meep] #5198949 08/28/19 01:00 PM
There are many in off-highway equipment...the tricky part is the "variable" part.
Can you drive ANY 24V DC motor as variable with a PWM? I have one in hand that is being driven on/off, but I don't know if I can drive it variably.
I am also looking into golf cart motors...many of them are much more powerful than I need...but start at 36V-48V
If I have a 48V golf cart motor, can I drive it with a variable 24V source? I've found a variable golf cart motor that is rated for 10hp at 48V - can I expect to get 5hp driving it at 24V? My simple DC equations I do remember tell me I can...?
Out of all the classes from engineering school, this is the one I remember the least about.
Re: Help Finding 24V motor [Re: DriveHard] #5198972 08/28/19 01:19 PM
N
nthach Offline
N
The tech exists for home HVAC - PSC/ECM motors work on that same principle but using AC and at line voltage. Almost like the motors inside of a Prius.
All the stuff I'm seeing via Google are 48V DC motors from China that can put out that power. What the heck are you building?
Re: Help Finding 24V motor [Re: DriveHard] #5198987 08/28/19 01:39 PM
M
mk378 Offline
M
Yes you can drive any brush-type motor with PWM to slow it down. The PWM controller is a generic item you'd select based on volts and amps.
Running a motor on less than rated voltage the hp is likely to drop by at least voltage squared, i.e. 1/4 the power for 1/2 the voltage.
Re: Help Finding 24V motor [Re: nthach] #5198994 08/28/19 01:49 PM
Sadly I can't share that right now.
Re: Help Finding 24V motor [Re: DriveHard] #5198999 08/28/19 01:52 PM
E
Ethan1 Offline
E
If it’s something classified or proprietary, you presumably have better resources at your disposal than BITOG... right?
Re: Help Finding 24V motor [Re: mk378] #5199062 08/28/19 03:11 PM
N
nthach Offline
N
Another idea would be using a DC controller to control an AC motor, which are much more plentiful.
Re: Help Finding 24V motor [Re: DriveHard] #5199088 08/28/19 03:35 PM
T
tahoe_hybrid Offline
T
you will want a GM BAS+ (eAssist) Motor Generator from one of those mild hybrid
it's 20HP 44ft lb torque it will need to be water cooled though
36 volts
Re: Help Finding 24V motor [Re: DriveHard] #5199261 08/28/19 07:17 PM
R
Rand Offline
R
With that much information given its pretty hard to find anything that would be remotely helpful to you.
Re: Help Finding 24V motor [Re: Ethan1] #5199556 08/29/19 06:30 AM
I do...but I have been surprised at some of the knowledge on this forum. It often surpasses some of the "experts" I interact with.
Re: Help Finding 24V motor [Re: Rand] #5199557 08/29/19 06:31 AM
What more do you want to know?
