Originally Posted by dave1251
Originally Posted by Navi
I went through a lot of different oil analysis and you might want to try Shell Rotella T6 5W30.
The Shell Gas Truck seems to shear too much...
Shearing means what? Oils shear I'm sure the designers and manufacturers who make the grade recommendations account for this. Just because of shear is a lame reason for a motor oil recommendation. If shear was not accounted for Ford would recommend 0W16/20 for everything.
Depends on what the designer's goal is.
In NA, the goal is to squeeze every MPG even if it sacrifices a bit of protection because of CAFE. They cannot recommend grades that will affect fuel efficiency.
Now, I'm not saying that the engine will not last a long time on thin oil, however I am sure that a thicker oil will make it last longer.
Edit: another vote for the T6 5w-30. BTW it's SN+ which is recommended for your TGDI.
