Interstate batteries problems
by JimPghPA - 11/15/19 09:49 AM
2008 Dodge Ram 3500, first sample
by A_Harman - 11/15/19 09:44 AM
Steelers/Browns
by CourierDriver - 11/15/19 09:04 AM
Beard care in cold weather?
by pandus13 - 11/15/19 08:39 AM
Door Sill protection for new car - which one?
by henni - 11/15/19 08:18 AM
Exterior Home Security Cameras?
by Gebo - 11/15/19 08:13 AM
5w-20 ok for GMC 6.2l ?
by jdw1222 - 11/15/19 08:02 AM
M. Defender vs Cont. TrueContact Tour?
by lukejo - 11/15/19 07:53 AM
Alternative for Lexus Toyota WS
by Joephu - 11/15/19 06:19 AM
F1 - 2019 Brazilian Grand Prix
by gofast182 - 11/15/19 06:10 AM
2019 i30 Nline 1.6T and first service (1500km)
by rov137 - 11/14/19 10:11 PM
Garbage Disposal Replacement
by bunnspecial - 11/14/19 09:58 PM
Nest thermostat
by miden851 - 11/14/19 09:06 PM
2011 G37X
by maverickfhs - 11/14/19 08:27 PM
Recommendations for oil filter
by dawgn86 - 11/14/19 07:38 PM
2001 Subaru Outback $2,300 OBO
by 14Accent - 11/14/19 07:16 PM
Brake Friction Code List
by 92saturnsl2 - 11/14/19 07:14 PM
Accord reached a milestone today!
by mclasser - 11/14/19 06:59 PM
Is an alignment absolutely needed after new tires?
by SouthDakotaDad - 11/14/19 06:11 PM
DjS71, Akhunter, rov137, Dorisy, DesktopDave
69870 Registered Users
123 registered members (Akhunter, aquariuscsm, 4WD, 2004tdigls, 14Accent, Aichiguy, 12 invisible), 1,826 guests, and 24 spiders.
Topics297,438
Posts5,115,741
Members69,870
Most Online3,589
Nov 2nd, 2019
Ford 2.5 vibration at idle #5197591 08/26/19 09:00 PM
dogememe Offline OP
2010 escape, 100k miles. Plugs and coils changed maybe 30k miles ago. I've replaced maf and throttle body. Why do I still have rough idle. I have a laptop in the car with a ram mount and the letters on the screen vibrate enough reading it is annoying. Plz help?
2010 Ford Escape 2.5 ~101K Miles: Castrol Magnatec 5W-20, Wix Filter.
2001 Chevy Suburban 5.3 ~283K Miles: Unknown Oil, Filter.
Re: Ford 2.5 vibration at idle [Re: dogememe] #5197596 08/26/19 09:12 PM
clinebarger Offline
Probably a engine/trans mount. Take a floor jack with a piece of soft wood (Pine) on the jack pad & lightly lift the engine at the mount locations to find the offending mount.
ALL inline 4 cylinder engines vibrate......It's the mounts job to isolate it from the vehicle.
2001 Chevy Camaro L92/4L80E
Re: Ford 2.5 vibration at idle [Re: clinebarger] #5197602 08/26/19 09:22 PM
dogememe Offline OP
I've always owned big 6s or v8s. Am I just expecting too much? It hasn't got better or worse than at 60k about a year ago when I bought it from a Ford dealer.
Re: Ford 2.5 vibration at idle [Re: dogememe] #5197610 08/26/19 09:41 PM
clinebarger Offline
V6's also have issues with balance vibrations, Some worse than others, Still nothing like a I4....Especially the larger ones like your 2.5L.
A Cummins 3.9L I4 diesel will shake the fillings out of your teeth where a Cummins 5.9L I6 is smooth as glass.
I use my buddies Case skid steer with a 3.9L Cummins for dirt work around the homestead fairly often......I feel the aftershock for hours afterward!
Re: Ford 2.5 vibration at idle [Re: dogememe] #5197658 08/27/19 01:01 AM
M
mcrn Offline
M
I test drove one that was new.....had a bad vibration at idle. A friend of mine bought the Mercury version and has had a vibration the entire time. It was bad enough that I got the Rogue instead.
2012 Nissan Rogue
Re: Ford 2.5 vibration at idle [Re: dogememe] #5197663 08/27/19 01:46 AM
carloz Offline
Most likely the motor mounts are wearing out.
Re: Ford 2.5 vibration at idle [Re: dogememe] #5197733 08/27/19 06:33 AM
E
Eddie Offline
E
Most 2.5L I4 engines have balance shafts and idle smoothly like my MAZDA 2.5. Ed
2014 CX5 Touring 2.5L :-)
Re: Ford 2.5 vibration at idle [Re: Eddie] #5197740 08/27/19 06:43 AM
PimTac Offline
Yes but we are talking two different engines. Only the displacement size is the same. My Mazda 2.5 is also very smooth.
2017 Mazda CX5
Havoline Pro DS 0w20
Roki OEM filter.
Re: Ford 2.5 vibration at idle [Re: dogememe] #5197747 08/27/19 07:03 AM
M
Miller88 Offline
M
I bet it's the hydraulic engine mount at the "front" passenger side of the engine.
A 2010 Escape should have the MZR I4, which is very close to the mazda 2.5 - they also have balance shafts as far as I know.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Ford 2.5 vibration at idle [Re: dogememe] #5197772 08/27/19 07:36 AM
W
WyrTwister Offline
W
Shot in the dark . Hook up a OBDII reader & look for misfires , O2 sensors , and the other sensors that would contribute to vibration .
Very big shot in the dark . Valve or valve timing issue ?
Also , check for vacuum leaks .
Did you replace the plugs & coil , or some one else .
( Actually , the timer has counted down to zero & it is time to trade it in & buy a new car . :-) )
Best of luck to you , :-)
Wyr
God bless
Re: Ford 2.5 vibration at idle [Re: dogememe] #5197812 08/27/19 08:25 AM
M
Mad_Hatter Offline
M
Check your IAC, EGR and PCV...it can also be your mount(s). Less common but possible are bad or failing crank/camshaft sensors.
Using an obd reader, are your rpms bouncing bigly?
Re: Ford 2.5 vibration at idle [Re: dogememe] #5197823 08/27/19 08:48 AM
slug_bug Offline
My 2013 Fusion has the 2.5. It's never had what I'd call a real smooth idle. It's the same at 100k as it was at 26k.
2017 RX350 (36k)
2016 Miata 2.0l (20k)
2013 Fusion 2.5l(91k)
2013 Focus(76K)
Re: Ford 2.5 vibration at idle [Re: dogememe] #5197969 08/27/19 11:53 AM
K
Kestas Offline
Global Moderator
Global Moderator
K
2.5L for a 4-cyl is getting up there for size as far as vibration goes. Balance shafts are needed around this point, unless the engineers find a way to lower the reciprocating mass (piston and small end of connecting rod).
I've also read that some modders remove balance shafts to get the extra gain in power and economy. So you can look at your engine two different ways - pros and cons.... it's either efficient or it's shaky. Given the push for meeting CAFE, I'd say the manufacturer opted for efficient.
Re: Ford 2.5 vibration at idle [Re: dogememe] #5198125 08/27/19 02:19 PM
1
1978elcamino Offline
1
my fusion 2.5 has a smooth idle, but vibrates more than I would like. I would recommend looking at the mounts.
2018 F150 5.0
2016 Ford Fusion 2.5
