96 registered members (AC1DD, 2010Civic, 69Torino, bbhero, 14Accent, 7 invisible),
2,002
guests, and 24
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics298,551
Posts5,137,920
Members70,092
Most Online3,589 Nov 2nd, 2019
Re: Oil Analysis Results for 2002 LB7 Duramax
[Re: Bdsankey]
#5197522
08/26/19 07:24 PM
oakaro68
Posts: 44 |
As for the wear; it's pretty normal. The Cu is common if you've recently switched to Amsoil; a reaction of chelation. The Pb is probably a spike that will subside; happened to mine once. There's no Pb associated with the cooler.
I presume you are only sampling and not OCI'ing? It's far too soon to be dumping lube.
I don't really understand why you're upgrading the oil cooler. Do you have the LB7 significantly "tuned up" to where it's producing a LOT more power (heat)? Do you track the oil temps; is there evidence they are too high? I am just sampling, not dumping. The latest oil sample went out yesterday to OAI and should have results to post back on Friday or Monday. Yes I have recently switched. Previously the truck had Cenpeco S3 15W40 in it ( Cenpeco S3 Data Sheet). The reason I switched was purely because Amsoil sponsored Diesel Power Challenge 2019 and provided me with 10gal free of any engine oil. I chose 15W40 Heavy Duty Diesel Marine since I've run it in the past as a child (all my dad used in his pickups/HD equipment) and the results were good. It also was all that was used in my 2005 duramax by the previous owner. At 342k when the motor was torn down (replaced due to bent connecting rod) all the bearings looked absolutely brand new and held clearance within manufacturer's spec for new. The engine in this 2002 is a little tired (some blow-by that I don't like, lower oil pressure than I'd like which is 20psi hot/40 psi cruising down the freeway hot and towing) but it hasn't shown me any signs it needs to be replaced yet. I am planning on running the remaining 7.5 gallons of Amsoil 15W40 HD Diesel Marine through this engine but will only change once this forum or the testing indicates a need. Before this year I've always done 5k drain intervals on all my diesel pickups. Yes, I understand this was wasting money as the oil did not warrant a replacement but it was what I've done since I was a child and kept up with it regularly. My other truck gets an oil change every 8 sled hooks or 1000mi but it also makes 1300hp+ and money isn't an issue there. I eventually plan on going back to Cenpeco S3 oil once this stock of Amsoil is depleted. They were also gracious enough to provide me with 10gal of Torque Drive ATF (my favorite synthetic ATF for an Allison) that will be going in the transmission once it is built this winter. The reason for upgrading the cooler is to manage oil temps while towing heavy. Duramax trucks are quite known to run hot oil temps when towing quite heavy (~15k+). The new 2020 oil cooler is a cheap investment as it is roughly $250 for all the required parts to install. I do have the truck tuned but only run on a 75hp tow tune. Coolant temps stay in check (under 200F) as well as trans temps (under 200F) when towing in 90F-95F ambient conditions grossing 24k lbs. What was the bent rod from? what the truck tuned? That's pretty impressive about the bearings/clearances! LB7/LLY duramax trucks (01-05) have very weak connecting rods from the factory. They tend to fail north of 650hp, especially on a drop-in upgraded turbo or compound turbos. I had an upgraded drop-in turbo with upgraded injectors and pump. The truck made ~700hp/1200tq. Well (edit - mod) more than double stock power and bearing clearances were good as new after 342k miles. Seems like every day I have more respect for the Duramax
[Re: Bdsankey]
#5197737
08/27/19 06:39 AM
Bdsankey
OP
OP
Posts: 29 |
Well (edit - mod) more than double stock power and bearing clearances were good as new after 342k miles. Seems like every day I have more respect for the Duramax I don't know if the respect is due to the engine, 5k intervals its entire life until failure, or the lube quality. What I do know is the lube is holding up extremely well (as so it seems) at 7500mi. I am thinking my next sample will be at 15,000mi, is this too long to wait?
Current Rides: Toy: 2005 Chevrolet Silverado 2500HD, Duramax Diesel (LLY) DD/Tow Rig: 2002 Chevrolet Silverado 2500HD, Duramax Diesel (LB7)
[Re: Bdsankey]
#5197852
08/27/19 09:29 AM
claluja
Posts: 484 |
Here is an updated report at 7510mi. When should I pull the next sample? 10k, 12.5k, or 15k? Same lube/filter. My vote is 12 or 15K for next sample, and to keep using oil analyzers. Very good oil you have in her now.
2014 F250 6.7L PSD 2006 Sequoia 4.7L 2005 E500 5.0L 2018 Jeep Rubicon, Pentastar 3.6L
[Re: claluja]
#5197856
08/27/19 09:35 AM
Bdsankey
OP
OP
Posts: 29 |
Here is an updated report at 7510mi. When should I pull the next sample? 10k, 12.5k, or 15k? Same lube/filter. My vote is 12 or 15K for next sample, and to keep using oil analyzers. Very good oil you have in her now. Thank you. I will either keep using OAI or switching directly to Polaris Labs. Brett from Amsoil (who I worked with for Diesel Power Challenge 2019 and continue with) has recommended to go to 15k and pull a sample. He said everything is looking good and nothing is outstanding that would dictate any issues.
[Re: Bdsankey]
#5211595
09/13/19 08:56 AM
Bdsankey
OP
OP
Posts: 29 |
Well looks like I am starting to have a bearing failure. In the last 2000mi there has been a significant drop in oil pressure. This is all running Amsoil AME 15W40 Heavy Duty Diesel Marine. Looks like I'm going to pull the motor out and rebuild it.
[Re: Bdsankey]
#5212048
09/13/19 07:15 PM
mattd
Posts: 1,110 |
Certainly looks that way to me. Post some pictures if you can interested to see the nature of the failure. The oil still seems like it go quite a bit more especially with the base number
2007 Ford F-350 4x4 6.0 PSD
ASE Master, L1
[Re: mattd]
#5212414
09/14/19 10:48 AM
Bdsankey
OP
OP
Posts: 29 |
Certainly looks that way to me. Post some pictures if you can interested to see the nature of the failure. The oil still seems like it go quite a bit more especially with the base number Agreed. It took 1qt of makeup at around 9600mi. The oil seems to be wearing extremely well. I don't believe this to be an oil related failure. I do not know any history before ~253k. I am wondering if it got studded because of a head gasket failure pushing coolant into the oil and compromising a bearing. I'm hoping it is a cam bearing. The turbocharger oil supply is off of one of the cam bearings. My theory is (if it is a cam bearing) that when the oil got hot towing it just couldn't provide the necessary lubrication as that has been seen more than once on the duramax platform. Posting pictures is no problem, I fully intend on tearing it down and repairing it/slight upgrades suited to the nature of towing/longevity (better oil cooler, better piston cooling nozzles, more oil pump flow, upgraded bearings etc).
[Re: Bdsankey]
#5244192
10/19/19 12:13 PM
mattd
Posts: 1,110 |
You had a chance to pull the engine and check things out yet? Just curious.
ASE Master, L1
