Originally Posted by RayCJ
Originally Posted by grampi
Originally Posted by Al
I used the Insulator wax and the paste many years ago. I stopped using it bc it was a PIA to apply.
I reconfirmed that the other day. I went back to another product.
I have not tried those, but you should try the 845...it's delightfully easy to apply and remove...and it not only doesn't stain trim, it can be used to keep it looking nice...
Grampi... It's perfectly understandable some folks would find Collinite waxes harder to work with. A lot of folks are not familiar with traditional "elbow grease" type car waxes like "Simoniz" and "Johnson's Paste Wax". Do you remember working with those? Oh, it was a bear! -And before clearcoat came out, you had to put wax on thick and wide to keep from buffing the color out of the paint.
Collinite is much more forgiving (and clearcoat is the invention of the century) but still needs a little TLC to do it right. If someone does half a hood on a sunny day, they'll be hating life. You can take Finish 2000 and do a whole car on a sunny day and it will still come off easy. With Collinite, you need to be mindful of the temperature and humidity and work accordingly.
That said, I use the 845, 476 and 915 and in all honesty, they all look and work great. Unless I buy a black or very dark colored vehicle, I'll probably use-up the 915 and just stick with the other 2 for simplicity.
Ray
I have not used any of Collinite's paste waxes, but I find the 845 very easy to work with. Goes on and comes off very easily. I don't know how difficult it is to apply or remove in the sun as I always do my vehicles in the garage, so this is not a problem. Another nice feature of the 845 is how it makes trim look new again. Usually waxes/sealants leave trim looking bad, but not Collinite. I have never used any other wax that's looked good on trim...
Ray
