belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
Help me understand
by 1978elcamino - 02/24/20 02:25 PM
2019 VW Passat Trip Mileage
by Boomer - 02/24/20 01:13 PM
Changed my ATF, difference is crazy!
by cwilliamsws6 - 02/24/20 12:36 PM
Specs on Conventional Oils 4 Comparing
by Perseus - 02/24/20 12:32 PM
EarlT500, Newbie111, Boris_Be, NHR, zip15
70798 Registered Users
49 registered members (bbhero, Bailes1992, aleneros, berlyn, BlakeB, 928, 4 invisible), 1,412 guests, and 21 spiders.
Topics301,895
Posts5,204,851
Members70,798
Bent wheel... #5196414 08/25/19 05:06 PM
N
NoNameJoe Offline OP
N
The other day I was driving on the highway and during a lane change I looked over my shoulder and apparently didn't see something I hit. It was not a car or an animal, the sound was so bad I thought I ran over a bike or hit a stove laying in the middle of the highway. Couldn't see anything in the rear view so I just assume it was a really big pothole.
Put the car up, couldn't see anything under the car, no body damage, nothing.
Today I notice an odd mark on the sidewall of the tire that hit whatever. It's as if something rubbed the dust off the sidewall. I pull the wheel cover back a little right near it and notice the lip of the steel wheel is bent.
The reason I checked the wheel again today (and found the problem) is because after the hit I've noticed a consistent vibration in the steering wheel past 70mph.
Could appreciate your help for answering these questions:
1. Does a bend always need to be fixed? I don't know if it's just the very lip of the rim that's bent or the actual barrel of the wheel itself. It looks extremely minor. Can it just be balanced out with more weights?
2. I just want to fix the balance issue. Not sure if the balance issue was caused by internal damage to the tire, a thrown weight or the minor bend on the lip or possibly more of a bend I can't see.
3. How much would you think it would cost for a tire shop to fix a bent rim? What exactly do they do to fix the bent rim? This is a steelie. If it's going to be more than 50 I might as well just buy a new steelie, I'm due for new tires anyway.
I'll get a picture for you guys soon. I'm convinced whatever it was, I happened to hit it with just the outer lip of the wheel (hence why the sidewall was scraped). That's probably the worst place to hit because it puts more leverage on the wheel width wise? That's also probably why the hit sounded so harsh and bad, it contacted the wheel directly (it literally sounded like crunching metal LOL). If it had gone under the tire, it would have been a dull and softer blow because it would have hit the tread and not the wheel.
2015 Civic LX Coupe
Re: Bent wheel... [Re: NoNameJoe] #5196423 08/25/19 05:23 PM
gathermewool Offline
Why not just take it to a tire shop and have them see out of balance it is? They'll be able to tell pretty quickly how bad it is.
14 Forester XT Touring FA20DIT (Cobb Stage 1)
Castrol Magnatec 5W-30 D1G2 + FU filter (72,320mi, 8/24/19)
15 Legacy Premium FB25
Magnatec 5W-20 + FU filter (47,300mi, 5/11/19)
Re: Bent wheel... [Re: NoNameJoe] #5196424 08/25/19 05:24 PM
N
N
Hmmm I may try fixing the bend myself also if it's just dismounting the tire and torching the steel until it's soft.
2015 Civic LX Coupe
Re: Bent wheel... [Re: NoNameJoe] #5196430 08/25/19 05:32 PM
M
mclasser Offline
M
I agree about taking it into a tire shop. If it noticeably wobbles on the balancer it's time to replace. Steelies should be pretty cheap anyway.
I've had a slightly bent alloy rim on my Accord for years. I left it alone since It holds air fine and doesn't cause a significant shimmy.
2018 Hyundai Elantra VE
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
Re: Bent wheel... [Re: NoNameJoe] #5196441 08/25/19 05:40 PM
E
ecotourist Online Content
Online Content
E
And you might be able to get a matching wheel from a wrecker. It wouldn't necessarily have to come from the same year or even the same model. The wrecker should be able to tell you which wheels would match.
We got 3 matching wheels for my '81 Celica from the wrecker when my daughter spun the car and exited the freeway backwards. Much cheaper than new ones.
2000 BMW 528i 5MT M Sport
2007 Honda Accord EX-L 4Door V6 6MT
Re: Bent wheel... [Re: NoNameJoe] #5196442 08/25/19 05:40 PM
K
Kira Offline
K
My friends and I have beaten small dents out of steel wheels using a large hammer and wood. We had both seen it done.
Give it a shot. True out what you can see then go to the tire shop. You've nothing to lose.
3 cheers for steel wheels. Love 'em.
Re: Bent wheel... [Re: NoNameJoe] #5196447 08/25/19 05:44 PM
A
atikovi Offline
A
Just swap wheel with the rear one first before taking it anywhere. You might decide not to do anything after that.
Re: Bent wheel... [Re: atikovi] #5196548 08/25/19 07:21 PM
M
mattd Offline
M
Steel wheels are usually replaced from big bends unless it can be “banged” out. Aluminum wheels are usually repaired but that is a process as it’s not usually done on site.
2007 Ford F-350 4x4 6.0 PSD
ASE Master, L1, L2
Re: Bent wheel... [Re: NoNameJoe] #5196566 08/25/19 07:43 PM
N
N
I'm going to try what Kira said, bang it out with a wood block. Once I get the wheel off I can look at it overall to see how bent it actually is.
2015 Civic LX Coupe
Re: Bent wheel... [Re: NoNameJoe] #5196573 08/25/19 07:47 PM
R
Rand Offline
R
if it hit hard enough to bend a wheel there is a significant chance the tire is damaged.
Re: Bent wheel... [Re: NoNameJoe] #5196578 08/25/19 07:49 PM
Chris142 Offline
Don't heat it. Bend it back at ambient temp with a sledge.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Bent wheel... [Re: NoNameJoe] #5196663 08/25/19 09:21 PM
R
rubberchicken Offline
R
If the wheel is bent, then no amount of "balancing" is going to fix your issue. However, if its only a very slight amount then a "road force balance" where the wheel and tire variations are used to try to cancel each other out could help. In your case I think anything short of replacing the steel wheel is a waste of time. I have had decent results in buying used wheels from junk yards or eBay- just make sure there is no lip damage, and have it swapped out at a place that does "road force balancing" to check the straightness of the wheel.
I really dislike the term "road force balance" as it does not fully describe the process and can be misleading.
Re: Bent wheel... [Re: NoNameJoe] #5196665 08/25/19 09:24 PM
G
geeman789 Offline
G
Steel wheels are cheap. Just replace it and move on. Maybe try and find a used oem one at a wrecker. Aftermarket ones often don't work with the factory hubcap.
Cheapest fix if wheel still holds air ... move it to the back. You won't feel the vibration thru the steering wheel, and probably won't feel it at all.
2011 SUBARU Impreza 5-door manual / 2016 HONDA Pilot / 2011 MAZDA 2 auto
Re: Bent wheel... [Re: NoNameJoe] #5196712 08/25/19 11:09 PM
W
WyrTwister Offline
W
Local tire shop has straightened minor bebds for me using hammer or a " bod bone " shaped tool .
Cost only slightly more than a flat repair .
Wyr
God bless
Re: Bent wheel... [Re: NoNameJoe] #5196778 08/26/19 04:25 AM
R
RayCJ Offline
R
Slowly spin the wheel and check it against a stationary reference point. If it's on the front, jack up the car and get a brick and set a pen (or metal rod etc) so the tip is almost touching the edge of the rim. Slowly rotate the tire and see if the gap increases considerably. You'll need to do this on the inside and outside of the tire.
My son has a bad vibration so he took the tires for balancing. Problem persisted. I checked the tires as mentioned and found one to be bent almost 1/2 inch. He had steel rims, we replaced it -and problem was gone.
Ray
