belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
Help me understand
by 1978elcamino - 02/24/20 02:25 PM
2019 VW Passat Trip Mileage
by Boomer - 02/24/20 01:13 PM
Changed my ATF, difference is crazy!
by cwilliamsws6 - 02/24/20 12:36 PM
Specs on Conventional Oils 4 Comparing
by Perseus - 02/24/20 12:32 PM
EarlT500, Newbie111, Boris_Be, NHR, zip15
70798 Registered Users
53 registered members (aleneros, BlakeB, 928, bbhero, Arob, Bailes1992, 6 invisible), 1,425 guests, and 22 spiders.
Topics301,895
Posts5,204,845
Members70,798
Toilet flange problem #5196401 08/25/19 04:52 PM
dja4260 Offline OP
Finally got around to yanking basement toilet off as it was shimmed all around and rocked.
Not suprised to find the top of the 4''in toilet flange was raised 3/4''in above the floor. The flange isn't actually sitting on the tile floor, as I have 3/8''in of daylight below the bottom of the flange and tile.
It's a spare bathroom in the basement. I WON't be breaking up the floor.
I'm thinking to using a dremel to cut the PVC flush with the floor, using one of those flange repair kits. My only hesitation is that it would reduce the size to 3''in? It has a rubber boot that would fit tight to the existing pvc wall and sit flush on the floor. I would use concrete screws to secure to the floor.
I considered using 3/4 inch plywood and tracing the toilet base, and shimming the flange all around. It would be what my father considers a "hack job"..
Thoughts?
[Linked Image]
[Linked Image]
2013 Hyundai Elantra Gt Hatch 6 spd
2005 Toyota Highlander V6
1997 HD Sportster
Re: Toilet flange problem [Re: dja4260] #5196418 08/25/19 05:14 PM
R
Rand Offline
R
if it were my house in a basement.. I'd shim with the plywood method.. but I suppose if you mess it up can always call in a pro.
Re: Toilet flange problem [Re: dja4260] #5196433 08/25/19 05:34 PM
sloinker Offline
There are some interesting kits to address that problem. Look around youtube and see what you think. I would get a hammer drill and drill an inch around the pipe many holes down about 4 inches an chip out the concrete, dremel the pipe and use the correct flange.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Ravenol VMP 5W30
'15 VW Golf Sportwagen TDI VMP 5W30
'14 Dodge Grand Caravan 3.6 Red Line Blue Label 5W20
'64 Plymouth Fury440 Red Line Blue Label 10W40
Re: Toilet flange problem [Re: dja4260] #5196444 08/25/19 05:42 PM
L
LoneRanger Offline
L
Main concern with flange repair kit method is usually plywood or osb subfloor flexing during use can allow sewage system odors to leach into the room air as the two parts joined together - repair piece and main pvc pipe - dont move together all the time, i.e. flexing may break seal. However, that would not be a concern here with the concrete slab floor with tile on top. Zero movement of floor. I vote for the flange repair kit option. Use hardening caulk to stabilize toilet base to the floor. Don;t caulk back section of toilet base only front and along sides.
'19 F-150 2.7 twin turbo DI V6 .....(Motorcraft synblend 5W30 SN+)
'19 GMC Terrain 1.5 turbo DI I4....(Warren 0W20 1DexosGen2)
'16 Moto Guzzi NTX 1151cc v-twin (Eni 10W60)
Re: Toilet flange problem [Re: dja4260] #5196549 08/25/19 07:21 PM
N
NormanBuntz Offline
N
I like the hack job method, using marine grade or pressure treated plywood.
Porgy Tirebiter: "Heavy on the 30 weight, Mom."
2017 Toyota Camry XLE, 12K, 2nd owner
2007 Honda Ridgeline RTS, 96K, original owner
2007 Infiniti M35, 115K, original owner
Re: Toilet flange problem [Re: dja4260] #5196570 08/25/19 07:44 PM
W
wog Offline
W
Could you use durorock and put mud or mastic to attach to concrete?then anchor flange into concrete . The wood breaks down from moisture,rock holds up . Then use neoprene ring for seal.
Re: Toilet flange problem [Re: dja4260] #5196846 08/26/19 06:46 AM
L
Linctex Offline
L
I wouldn't use plywood, I'd use masonry and tiles around the base area to bring the floor up to meet the flange where level.
Re: Toilet flange problem [Re: Linctex] #5197063 08/26/19 10:48 AM
P
pandus13 Offline
P
On one 'tube video, I saw an older style plumber use a cement bed to set toilets, like the bathtubs.
16 Golf SportWagen
13 Mazda5
08 Yaris
04 Elantra
95 accent
95 mystique
97 concorde
Re: Toilet flange problem [Re: dja4260] #5197543 08/26/19 07:46 PM
doitmyself Offline
Correct toilet flange installation is with the flange mounted on top of the finished floor. You would only have to raise the toilet 3/8" high, not 3/4 " in the OP. Maybe less if there is a lot of clearance underneath your toilet. Yes, you would need to shim underneath the current flange so that you can screw it into the concrete. Glue some kind of shims where the toilet base edge would sit so they do not stick out beyond the edge. Apply a nice bead of caulk around the base to hide the gap. This would require a bit of perfectionism type patience to do correctly.
"I'm thinking to using a dremel to cut the PVC flush with the floor, using one of those flange repair kits. My only hesitation is that it would reduce the size to 3''in? It has a rubber boot that would fit tight to the existing pvc wall and sit flush on the floor. I would use concrete screws to secure to the floor "
The toilet horn is only about 2" opening, so going from 4" to 3" should be no problem. Buy your replacement part FIRST and check to see if it will fit both the drain pipe and the toilet (length and diameter). There at least 4 different expansion/gasket type toilet flanges:
Sioux Chief Push Tite: Watch the push tite portion of this video at 1:15: https://www.youtube.com/watch?v=s-P141kXoiY ...This type seems perfect and it has the stronger metal flange ring.
[Linked Image from ecx.images-amazon.com]
Or, a Fernco waxless flange extender in conjunction with a repair flange ring might work: https://www.fernco.com/plumbing/wax-free-toilet-seal
Re: Toilet flange problem [Re: doitmyself] #5197763 08/27/19 07:23 AM
dja4260 Offline OP
Thank you. I'm going to buy a few options and dry fit them before I cut anything. I'm not going with the shim method.
1997 HD Sportster
Re: Toilet flange problem [Re: dja4260] #5197881 08/27/19 10:08 AM
doitmyself Offline
There are also plastic base plates of various brands, if interested: https://www.oatey.com/ASSETS/DOCUMENTS/ITEMS/EN/Toilet_Base_Plate.pdf
If the floor is not perfect and the toilet rocks even the slightest, it's best to use some shims to prevent any movement.
Re: Toilet flange problem [Re: dja4260] #5198279 08/27/19 06:10 PM
dja4260 Offline OP
I'm super pleased. I went to HD than Lowes. Lowes had a replacement/repair flange that is made to fit inside a 4''in PVC that already has a flange glued inside of it. I basically just need to cut the top off flush with the floor and glue this one inside the existing. Should be a piece of cake?!?!
1997 HD Sportster
