Spark plug gap f
by Rohan - 02/22/20 10:28 PM
Mad mike hughes.rip
by Chris142 - 02/22/20 10:15 PM
MTF drain = chocolate milk
by Texasdoc - 02/22/20 10:02 PM
New Valvoline looks promising?
by kr_bitog - 02/22/20 08:45 PM
rock like debris in generac generator 17kw
by jb5150 - 02/22/20 08:25 PM
FL820S C&P BAD GLUE JOB
by naterbomb - 02/22/20 08:21 PM
Photo Uploader Not Working
by ZeeOSix - 02/22/20 07:49 PM
Faulty clutch master cylinder 17” Honda Civic
by parshisa - 02/22/20 07:33 PM
Ford drain plugs
by buck91 - 02/22/20 07:09 PM
What's the greatest amount of miles you've heard of someone
by Speak2Mountain - 02/22/20 05:53 PM
Oil Jug - Leaking
by MasterSolenoid - 02/22/20 05:40 PM
Which one
by tiger862 - 02/22/20 05:05 PM
HM from the start?
by AJB0009 - 02/22/20 04:00 PM
Fram XG3600 instead of XG3614
by BTW574 - 02/22/20 03:57 PM
Unbranded Hydraulic Fluid Filters
by shibby6600 - 02/22/20 03:53 PM
Homemade pizza
by 53' Stude - 02/22/20 03:07 PM
New Shoes For The Tacoma!
by Delta - 02/22/20 02:52 PM
Giti tires - newish large brand.
by pezzy669 - 02/22/20 02:51 PM
New pennzoil oils
by Spitter - 02/22/20 02:26 PM
Breaking in the new clutch. Backwards.
by Chris142 - 02/22/20 02:18 PM
Markovchain, o_s, naterbomb, Jimiii, jb5150
70784 Registered Users
81 registered members (2010Civic, AZjeff, 55hambone, 4WD, 2strokeNorthstar, AC1DD, 6 invisible), 1,544 guests, and 17 spiders.
Topics301,809
Posts5,203,123
Members70,784
1988 cadillac brougham oil disappearing #5196242 08/25/19 12:41 PM
M
momo Offline OP
M
Hi all,
I noticed whenever I check the dipstick after ~200 miles, it shows that approximately 1 quart less. I don't drive that much since it sits on the garage most of its life. I did not notice any leak under the car. I usually change the oil once a year and I had to refill the oil every time that I noticed the dipstick showed low level. I checked the pcv valve and its associated parts nothing out of ordinary (e.g., smell of gas and little bit of dirt). I checked the oil pan thoroughly no seeping or leak. I checked the valve covers (from the front and sides) and no seeping or leak.
Any advice?
My questions are also:
1- Would it be possible that I find some blockage in the head that prevents the oil from going back to the oil sump?
2- Since the car run perfect and I haven't noticed heavy smokes coming from the tail pipe (except white smoke when first starting the car after a while), do you think that it maybe the case where the car burns oil?
3- Where should I start to trace this problematic issue I have?
Thanks
Current
'20 Toyota LC200 4.5L V8 Delo 15w40 & OEM
'88 Cadillac Brougham VWB 5w30 & Wix gold
SOLD
'50 Chevy Styleline 3.5 L I6
'76 Cadillac Coupe De Ville 8.2L V8
'83 Toyota Cressida 2.8L V6
Re: 1988 cadillac brougham oil disappearing [Re: momo] #5196250 08/25/19 12:56 PM
T
Trav Offline
T
You may have a leaking oil pressure sending unit that leaks under higher pressure that that at idle and leaves it on the road as you drive. If it is damp or wet change it.
The ones from WVE are good, they are NGK/NTK and only about 7 bucks.
https://www.rockauto.com/en/moreinfo.php?pk=939311&cc=1027145&jsn=424
Re: 1988 cadillac brougham oil disappearing [Re: momo] #5196259 08/25/19 01:10 PM
O
oldhp Offline
O
If your losing 1qt in 200 miles the underside would be soaked with oil. Maybe pull the plugs and see what they look like.
"None of us are getting out here alive.....drink that beer.....eat that pizza......drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just wait"
Re: 1988 cadillac brougham oil disappearing [Re: momo] #5196267 08/25/19 01:20 PM
J
JLTD Offline
J
How many miles? Head gasket may be your culprit, since there are no leaks. Is the inside of your tailpipe greasy?
Lates.
Re: 1988 cadillac brougham oil disappearing [Re: Trav] #5196651 08/25/19 09:08 PM
M
momo Offline OP
M
Let me check this
Current
SOLD
Re: 1988 cadillac brougham oil disappearing [Re: oldhp] #5196653 08/25/19 09:10 PM
M
momo Offline OP
M
Well last time, probably 2 years ago, I changed the plugs weren't that bad. But I will check 'em again
Current
SOLD
Re: 1988 cadillac brougham oil disappearing [Re: JLTD] #5196657 08/25/19 09:13 PM
M
momo Offline OP
M
70K miles on the clock. Well this is very interesting as I noticed the other day there is wet residual that come from the tail pipe but it was watery rather than greasy
Current
SOLD
Re: 1988 cadillac brougham oil disappearing [Re: momo] #5196669 08/25/19 09:30 PM
Propflux01 Offline
Prolly falling through the valve seals.I had a Grand Prix do that, ate a quart every 800 miles and never saw smoke. Blow by was pretty rough though. always found oil in the breather element.
2014 Hyundai Elantra
2014 Hyundai Elantra GT
Re: 1988 cadillac brougham oil disappearing [Re: momo] #5196844 08/26/19 06:45 AM
Hootbro Offline
a little bit of water out of the tail pipe on startup is normal until it warms up. If you had a coolant leak making it's way to the exhaust, it would be white smoke and a classic blown head gasket situation which yours does not sound like.
2020 Jeep Gladiator Rubicon 3.6L (Dealer Bulk 0W-20)
2017 Jeep Renegade Latitude 2.4L (Idemitsu 0W-20)
2013 Volkswagen Jetta 2.5L (Havoline HM 5W-30)
