Spark plug gap f
by Rohan - 02/22/20 10:28 PM
Mad mike hughes.rip
by Chris142 - 02/22/20 10:15 PM
MTF drain = chocolate milk
by Texasdoc - 02/22/20 10:02 PM
New Valvoline looks promising?
by kr_bitog - 02/22/20 08:45 PM
rock like debris in generac generator 17kw
by jb5150 - 02/22/20 08:25 PM
FL820S C&P BAD GLUE JOB
by naterbomb - 02/22/20 08:21 PM
Photo Uploader Not Working
by ZeeOSix - 02/22/20 07:49 PM
Faulty clutch master cylinder 17” Honda Civic
by parshisa - 02/22/20 07:33 PM
Ford drain plugs
by buck91 - 02/22/20 07:09 PM
What's the greatest amount of miles you've heard of someone
by Speak2Mountain - 02/22/20 05:53 PM
Oil Jug - Leaking
by MasterSolenoid - 02/22/20 05:40 PM
Which one
by tiger862 - 02/22/20 05:05 PM
HM from the start?
by AJB0009 - 02/22/20 04:00 PM
Fram XG3600 instead of XG3614
by BTW574 - 02/22/20 03:57 PM
Unbranded Hydraulic Fluid Filters
by shibby6600 - 02/22/20 03:53 PM
Homemade pizza
by 53' Stude - 02/22/20 03:07 PM
New Shoes For The Tacoma!
by Delta - 02/22/20 02:52 PM
Giti tires - newish large brand.
by pezzy669 - 02/22/20 02:51 PM
New pennzoil oils
by Spitter - 02/22/20 02:26 PM
Breaking in the new clutch. Backwards.
by Chris142 - 02/22/20 02:18 PM
Markovchain, o_s, naterbomb, Jimiii, jb5150
70784 Registered Users
79 registered members (55hambone, 4WD, 2strokeNorthstar, AC1DD, 01VFR, 2013ecof150, 10 invisible), 1,575 guests, and 18 spiders.
Topics301,809
Posts5,203,116
Members70,784
CanAm OEM oil alternatives #5196115 08/25/19 09:46 AM
Carbon12 Offline OP
I have a 2015 CanAm Outlander L 450 purchased new in 2016 with 5 year warranty. OEM oil is available as 0w40 full syn or 5w40 blend and both are pricey. Thus far I have used the 5w40 blend which has no API donut but "meets" SM. 2015 manual says to use 5w40 SG, SH, or SJ oil if OEM oil is unavailable. I think the 2019 manual states SM.
1. Do these ATVs use a wet clutch? I think they probably don't if OEM oil is SM rated.
2. What alternative oils are you all using? I'm thinking of using Castrol Edge black bottle 5w40 or Mobil Delvac 1 5w40 since these are API SN and are the specd weight. (I think Rotella T6 opted out of the SN rating to keep high Zn/P)
Re: CanAm OEM oil alternatives [Re: Carbon12] #5196118 08/25/19 09:51 AM
Chris142 Online Content
Online Content
Is that belt drive? If so like our Maverick every component has its own lube. Ours calls for 5w40 in the engine and I use whichever is on sale.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: CanAm OEM oil alternatives [Re: Carbon12] #5196274 08/25/19 01:27 PM
Carbon12 Offline OP
It does have the belt drive. Mine is the single cylinder 450 which holds an additional quart than the 500 and the 450 specs no additional gear box lube like the 500 does.
Where do you usually get your filters? I may try to get one at NAPA.
Re: CanAm OEM oil alternatives [Re: Carbon12] #5196393 08/25/19 04:43 PM
Online Content
I bought some online...eBay I think but they didn't come with the oring. I bought those at the dealer.
Re: CanAm OEM oil alternatives [Re: Carbon12] #5196463 08/25/19 05:55 PM
T
tc1446 Offline
T
Looked at Rotella T6 5-40 Syn today at Walmart and it says it JASO ma/ma2. About $20 gal.
'14 Kia Soul, 2.0L (29K)
'13 Accord EX-L 2.4L (110K) M1 & FU
'00 Ford Ranger 4.0L {69K} M1 & FU
'18 Polaris Slingshot 2.4L GM (QS & Bosch Cart.)
'07 Kioti CK-30 (Delo & Wix)
Re: CanAm OEM oil alternatives [Re: Carbon12] #5196542 08/25/19 07:06 PM
Online Content
I don't see why I need a 5w oil. I don't play if it's less than 75f.
Re: CanAm OEM oil alternatives [Re: Carbon12] #5197725 08/27/19 06:19 AM
T
totegoat Offline
T
Used Mobil 1 5w-40 in my 650. Bought filters and gaskets on-line.
Re: CanAm OEM oil alternatives [Re: Chris142] #5268470 11/15/19 06:14 PM
dafish Offline
W Viscosity affects flow well above freezing too. 75F is what, maybe 24C? in that area anyway. In engine terms that certainly cool. Thinner "W" will flow into smaller tighter machined tolerances better, not just flow better in freezing temps.
So yea, use 5W/40.
Rotella T-6 is the real deal. I use it vett's bikes, UTV's, my deere, the cars, everything. Hard to beat at any price, and a great value yo can get almost anywhere.
