New Valvoline looks promising?
by kr_bitog - 02/22/20 08:45 PM
rock like debris in generac generator 17kw
by jb5150 - 02/22/20 08:25 PM
FL820S C&P BAD GLUE JOB
by naterbomb - 02/22/20 08:21 PM
Photo Uploader Not Working
by ZeeOSix - 02/22/20 07:49 PM
Faulty clutch master cylinder 17” Honda Civic
by parshisa - 02/22/20 07:33 PM
Ford drain plugs
by buck91 - 02/22/20 07:09 PM
What's the greatest amount of miles you've heard of someone
by Speak2Mountain - 02/22/20 05:53 PM
Oil Jug - Leaking
by MasterSolenoid - 02/22/20 05:40 PM
Which one
by tiger862 - 02/22/20 05:05 PM
HM from the start?
by AJB0009 - 02/22/20 04:00 PM
Fram XG3600 instead of XG3614
by BTW574 - 02/22/20 03:57 PM
Unbranded Hydraulic Fluid Filters
by shibby6600 - 02/22/20 03:53 PM
Homemade pizza
by 53' Stude - 02/22/20 03:07 PM
New Shoes For The Tacoma!
by Delta - 02/22/20 02:52 PM
Giti tires - newish large brand.
by pezzy669 - 02/22/20 02:51 PM
New pennzoil oils
by Spitter - 02/22/20 02:26 PM
Breaking in the new clutch. Backwards.
by Chris142 - 02/22/20 02:18 PM
Toyota 0W20 $2.95 + shipping YMMV
by Q451990 - 02/22/20 01:34 PM
Toyota Catalytic Converter (B2)
by MaximaGuy - 02/22/20 01:31 PM
The Camry lives!
by 53' Stude - 02/22/20 01:01 PM
Markovchain, o_s, naterbomb, Jimiii, jb5150
70784 Registered Users
99 registered members (2009Caraman, ammolab, AC1DD, ArrestMeRedZ, 55hambone, 12 invisible), 2,058 guests, and 19 spiders.
Topics301,806
Posts5,203,080
Members70,784
Page 1 of 4 1 2 3 4
Recommend a 7 passenger w/10,000 tow #5196028 08/25/19 07:54 AM
sasilverbullet Offline OP
My son needs a vehicle that can seat at least 7 and pull at 7,000 lb trailer with a 680 lb tongue weight.
He'd have the vehicle loaded up with his large family and of course the trailer would be packed for a trip.
I figure he needs at least a 10,000 lb tow capacity.
Can't afford something new, prefer something that doesn't blow plugs or have some other nightmarish problems with the drive train.
Be specific on the year/model/engine drive chain combination you recommend.
What would you guys recommend?
03 Porsche 911 Driven DT-40 5w-40 & Mahle filter
14 Honda Accord 4dr EX-L 4cyl-M1 5W-30 & WIX
02 Chevy 5.7L van-GTX HM 10W-40 & WIX
Re: Recommend a 7 passenger w/10,000 tow [Re: sasilverbullet] #5196039 08/25/19 08:06 AM
I
IndyFan Offline
I
Smells like a job for a Suburban, to me. I'd look at a 2500 model with whatever V8 is standard. 2wd, unless he needs 4wd.
Maybe a low miles used one, such as an 04-06, with the 6.0 liter and a 4L80 transmission would be perfect.
18 Jeep JLUR Wrangler 3.6 29k
15 Ford Transit 129k, Reman 3.5 @85k
17 Jeep Renegade 2.4 22k
08 Jeep Wrangler 3.8 139k
04 Jeep Grand Cherokee 4.7 109k
99 Mercedes E430 Sport 99k
Re: Recommend a 7 passenger w/10,000 tow [Re: sasilverbullet] #5196040 08/25/19 08:06 AM
Quattro Pete Offline
2002 530i   2015 Q5 3.0T   2018 Charger SRT
Re: Recommend a 7 passenger w/10,000 tow [Re: sasilverbullet] #5196042 08/25/19 08:08 AM
3
379KITTY Offline
3
An 8.1L Suburban and an Excursion are two that come to mind. I would personally avoid an Excursion with the 6.0 diesel which showed up in 03 I believe. Prior to that was 7.3 diesel (pretty much bulletproof but getting harder to find with reasonable miles). Gas V10 was an option but some years had the spark plug issue you mentioned. I think Suburban got the 8.1 around 01-02.
Re: Recommend a 7 passenger w/10,000 tow [Re: sasilverbullet] #5196045 08/25/19 08:11 AM
I
IndyFan Offline
I
Here's a low mileage beauty...
https://www.carfax.com/vehicle/1GNWCMEG5BR198319
Something like that would tow to his heart's content, for many years.
I'd think you'd find quite a number of them to choose from in Texas. Probably lots of Expeditions, too.
Re: Recommend a 7 passenger w/10,000 tow [Re: sasilverbullet] #5196053 08/25/19 08:18 AM
Snagglefoot Online Content
Online Content
How about this. A 2008 Chev Suburban 3/4 ton with a 6.0 liter gas engine, 6L90 transmission, 6 Speeds, factory transmission oil cooler, integral motor oil cooler in radiator. It has a tow mode and the ability to control the transmission gears electronically with a button on gear selector. It has 352 HP and 383 ft lbs of torque. The tow rating is 9300 lbs. Tires are LT 265 70 R17 with load range E.
The stopped selling the 3/4 ton a few years ago.
If you want the job done right......do it yourself.
Re: Recommend a 7 passenger w/10,000 tow [Re: sasilverbullet] #5196060 08/25/19 08:24 AM
A
atikovi Offline
A
Really need to know the budget. Are you talking $5K or $25K? What about full size passenger vans?
Re: Recommend a 7 passenger w/10,000 tow [Re: sasilverbullet] #5196072 08/25/19 08:40 AM
W
wag123 Offline
W
+5 on a Suburban 2500 or Yukon XL 2500.
The 8.1L big block is a beast but gets horrible gas mileage and is not necessary, the 6.0L will be fine. The 6-speed 6L90 automatic on the newer ones would be preferable but the 4-speed 4L80E automatic would be acceptable and is a very good transmission. Either way, the drive trains are pretty much bullet-proof. The problem will be... trying to find one. They are few and far between, and nice well cared-for low mile examples are going to be expensive.
Re: Recommend a 7 passenger w/10,000 tow [Re: wag123] #5196078 08/25/19 08:52 AM
A
atikovi Offline
A
How much worse could it get? I have a truck with the 6.0 and towing with a total weight around 11,000 pounds, I get in the 12's mpg. Empty at around 7,500 pounds, maybe 13.
Re: Recommend a 7 passenger w/10,000 tow [Re: sasilverbullet] #5196088 08/25/19 09:00 AM
M
Miller88 Offline
M
Chevy Express 2500. We took one down to NC and pulled a truck on a trailer back through the mountains and it did awesome. Quite comfortable too. Can't say I'd recommend an E350, overhead cam engine in a doghouse seems like a nightmere.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Recommend a 7 passenger w/10,000 tow [Re: atikovi] #5196094 08/25/19 09:05 AM
W
wag123 Offline
W
8, maybe 10 if you are very careful.
Re: Recommend a 7 passenger w/10,000 tow [Re: wag123] #5196096 08/25/19 09:11 AM
A
atikovi Offline
A
Why is that? I'm no engineer but all things being equal, shouldn't it be about the same? The 8.1 would have less throttle opening vs. the 6.0 in a identical load so it should even out.
Re: Recommend a 7 passenger w/10,000 tow [Re: wag123] #5196105 08/25/19 09:29 AM
I
IndyFan Offline
I
Yep. I towed a 27' boat with a Chevy Express 15 passenger van full of kids and gear with the 6.0 and the 4 speed. The 6 speed would be gravy. The 6.0 did just fine. They can be found and are worth the search.
Re: Recommend a 7 passenger w/10,000 tow [Re: sasilverbullet] #5196111 08/25/19 09:43 AM
dishdude Offline
Nothing but a big Chevy or GMC would be up to this task.
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI M1 Euro 0w-40 Wix WL10024
2019 Tiguan Castrol Edge Pro 0w-20
Re: Recommend a 7 passenger w/10,000 tow [Re: sasilverbullet] #5196164 08/25/19 10:42 AM
Online Content
One thing more on the 3/4 ton Suburban. Mine has hydro-boost ( the power steering pump aids the power brakes) and it has disc brakes all around. Going up grades I manually held it in 4th gear (out of 6) at 3500 rpm at 60 mph with a 3.73 rear end. They also have a 4.11 option but you’re at the mercy of what’s available on the used vehicle market.
Page 1 of 4 1 2 3 4
