belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
Help me understand
by 1978elcamino - 02/24/20 02:25 PM
2019 VW Passat Trip Mileage
by Boomer - 02/24/20 01:13 PM
Changed my ATF, difference is crazy!
by cwilliamsws6 - 02/24/20 12:36 PM
Specs on Conventional Oils 4 Comparing
by Perseus - 02/24/20 12:32 PM
EarlT500, Newbie111, Boris_Be, NHR, zip15
70798 Registered Users
57 registered members (apollo18, Arob, A_User55555, alcyon, aleneros, 6 invisible), 1,434 guests, and 20 spiders.
Topics301,895
Posts5,204,831
Members70,798
Alternative oil filters #5195808 08/24/19 09:16 PM
G
GeoffPD Offline OP
G
This thread comes more out of desperation than pure curiosity but may be interesting for others in a similar situation.
I'm the proud new owner of a BMW G310GS , a really outstanding bike perfectly suited to the mix of twisty mountain roads and gravel/sand side roads which lead off down to the many beautiful beaches here in Palawan.
However living on a seemingly 'paradise' tropical island, albeit a rather long one with a 10 hour drive end-to-end, comes with it's own problems.....AVAILABILITY!
I bought my bike slightly used with only 3000km odo and 14 months of use. It's had it's first BMW service at 600km but now is a little overdue for it's 12 month service. Personally I would have done this before I sold it, but the original owner didn't want to spend out to have it done. However it's now down to me.
Getting the oil is no problem, in fact I have enough Mobil 1 fully synthetic left over from my VStrom service. The problem is the OIL FILTER. There is NO BMW dealer here on my island province (in fact there are NO dealers of ANY bikes apart from a Yamaha dealership). There are 1 or 2 Japanese car dealers and that's about it. So here comes the crunch! For me to buy an official BMW oil filter on-line and have it shipped from the dealer in Manila will cost me just short of $40!!!! (actually 1950 Philippine Peso). OK I realise I'm paying for the 'BMW' badge, but this seams ridiculous for what is a pretty standard looking and rather small filter.
Then my friend (a Husqvarna Nuda 900r owner who had a similar problem) told me that he used 'alternative' oil filters which were more readily available and only a few hundred peso!
So, my question is - what are the issues with using a 'similar' oil filter, maybe from a car, which is the same diameter, has the same oil-seal diameter, the same internal thread (M20x1.5?) but maybe slightly different length (8 or 10mm longer) on your bike?? For example the readily available oil filter for my Mazda CX5 is same diameter but 10mm longer than my BMW G310GS bike, and is 1/3rd of the price!
Living in Paradise aka PALAWAN
Re: Alternative oil filters [Re: GeoffPD] #5195820 08/24/19 09:54 PM
ctechbob Offline
If the threads, mounting gasket, and bypass pressure are same/very similar there shouldn't be any reason you can't use an 'auto' filter. I'd done it plenty on the 3 Kawasaki's I owned over the years and never had any problems. Never saw any abnormal wear when doing valve adjustments.
There's not a lot of information out there about the Mahle OC1141, but that's the one you'll be wanting to match those specs on.
2008 Acura TL Type S-165k
2003 Honda Accord V6-222k
Oil-Havoline HM 5W20
Filter-Partsmaster 61334
Trans-Idemitsu H+
Re: Alternative oil filters [Re: GeoffPD] #5195821 08/24/19 09:57 PM
blupupher Offline
If filter mount, gasket diamater, bypass pressure, burst strength are similar, and no clearance issues, no problem using it.
Many use "car" filters on motorcycles with no issues at all (I am one of them).
Many aftermarket car oil filters are probably "better" than motorcycle specific filters.
The Fram Ultra is used by many.
I like the Fram ToughGuard myself (although I currently have a Bosch Distance + on the bike now).
'18 Santa Fe: PP 10W-30/OEM
'18 Soul: Synpower 5W-30/PG
'10 Santa Fe: Synpower 5w-30/D+
'04 F150: Magnatec 10w-30/ST
'12 xB: M1EP 0W-20/CQ Blue
'02 F150: Magnatec 5W-20/D+
'94 VT1100: Peak 15W-40/D+
Re: Alternative oil filters [Re: GeoffPD] #5195831 08/24/19 10:13 PM
Superflan Offline
Mahle is OE Supplier for BMW. The MAHLE part number is OC1141. Here are the specs:
• Filter type: Screw-on filter
• Housing diameter [mm]: 65.0
• Height [mm]: 51,0 •: M20x1,5 - 6H
• Seal diameter [mm]: 62,2
• Opening pressure of the bypass valve [bar]: 2,5
• Tightening torque [Nm]: 18
• Article number of the recommended special tool: OCS 4
Seems that there's a standard hiflofiltro that would screw on but not suitable.
‘01 Peugeot Partner 1.9 D, 15W40 E7, 273000 Km, running on WVO
Wife's '19 Suzuki Vitara 1.0 Boosterjet (TGDI), 5W40 A3/B4, 23000 Km
Backup ‘01 Toyota RAV4 3-dr 2.0 VVTi, 5W40 A3/B4, 170000 Km
Re: Alternative oil filters [Re: GeoffPD] #5195846 08/24/19 10:54 PM
R
rubberchicken Offline
R
This is actually a more complex question. Is the bike still under manufacturers warranty ? If yes, then you probably want to stick with a filter that is either OEM or a Mahle. In the US , any filter that meets the OEM specifications can be used according to US consumer law, and it will maintain your factory warranty. I think this applies to Canada as well, and also for many Euro countries. But in real life the problem is a little more complex. First, according to your signature, you are in the Philippines and this consumer law may not be the same as in the US- in fact a lot of countries do not have the same laws on the books. Second, if you have a warranty claim you might get pushback from service people that are not familiar with the law, or may be hoping that you do not know the applicable laws. (this goes for both US and non-US areas). So even if the law applies they may try to deny warranty coverage by blaming a "non-factory part" as the cause of the problem. According to the applicable US laws , it is up to the manufacturer to specifically find that the problem was caused by the non-OEM part, which is quite rare. And for warranty coverage pushback, the problem is usually solved by either speaking to the BMW Service Manager, or escalating to the BMW Zone Rep. Failing that, a simple call to the filter manufacturer explaining the problem will almost always get support from the filter company to call your service guy and make them "prove" the part is at fault. As an example, if you call the Champion Labs customer service line (they make M1, Amsoil, RP and a ton of other brands and OEM filters) one of the choices is something along the lines of "claims" where they handle these type of issues. To get this sort of support, make sure the filter you use is authorized to be sold in your country, in which case its a fairly easy process. If the filter is "grey market" for your country, then your taking a bit more risk upon yourself. Again, in the USA they cannot just blame a non-OEM oil filter without proving their case. However this does not rule out that they may attempt to do this- I very recently had a 30+ years Ford mechanic tell me to keep all my receipts for oil filters and oil "just in case": This is the same Ford that has been giving Focus owners with the DPS-6 transmission the runaround for years. I recently had a warranty repair on a Ford, and the problem was clearly a warranty issue, but I had to keep my guard up as the service writer tried to pull a lot of tricks to get more money out of me.
I might suggest trying Amazon or eBay for OEM or Mahle filters, and buy 4-6 and have them delivered. I also locate and arrange parts for my motorcycle groups and boat groups.
Re: Alternative oil filters [Re: GeoffPD] #5195857 08/24/19 11:43 PM
J
jkhawaii Offline
J
How about a K&P reusable filter?
Re: Alternative oil filters [Re: rubberchicken] #5195909 08/25/19 03:20 AM
G
GeoffPD Offline OP
G
Thanks for your reply.
The warranty is up (we only get a miserable 12 months here in Philippines) so there aren't going to be any warranty claims. However obviously we want to protect the contents of our engines, so for me it's a case of finding a suitable and available alternative. Sadly due to locals' extremely limited available funds the marketplace can be littered with cheap Chinese 'lookalikes', so buying a reputable alternative is paramount (for example a K&N or similar).
Also, buying in bulk from Amazon or similar is equally dangerous because then you're at the mercy of the notorious Philippine customs who seem to be a law in themselves. They can literally keep your items for WEEKS then charge you a ridiculous import duty (40, 50 or even 100% is not uncommon) together with a 'STORAGE' fee while they left in untouched in their warehouse! (An example is an Amazon $12 dvd that I paid also pre-paid $6 for 'express' door-to-door delivery that ended up taking 7 weeks to arrive, costing me an additional $22.......and I had to drive 35 minutes into the city to go and pick it up!!!).
Anyway....back on topic, I need something that a car retailer will likely have on the shelf :-)
Re: Alternative oil filters [Re: GeoffPD] #5195969 08/25/19 06:18 AM
J
Jarlaxle Offline
J
Would any BMW CAR filters work?
1979 Coupe de Ville, 542 stroker, parked for winter frown
2011 Crown Vic P71, 5W-20 NextGen, Super Tech
2011 Sportster 883, parked for winter frown I hate winter.
Re: Alternative oil filters [Re: GeoffPD] #5195971 08/25/19 06:20 AM
T
troop Offline
T
Re: Alternative oil filters [Re: GeoffPD] #5195974 08/25/19 06:32 AM
L
Linctex Offline
L
As long as keep the oil clean, the filter will last a long long long long long time.
There is no need to change the filter every oil change.
Re: Alternative oil filters [Re: Linctex] #5196280 08/25/19 01:40 PM
R
R
I am not familiar with that bike or appropriate filter, but in the case of wet clutches on motorcycles my preference is to change the filter every oil change.
It seems the filter is priced about the same as other OEM motorcycle filters- https://www.beemershop.com/product/mahle-oil-filter-2633.html $14.99 in US funds.
Re: Alternative oil filters [Re: rubberchicken] #5196397 08/25/19 04:48 PM
blupupher Offline
Did you read the original post?
Originally Posted by GeoffPD
... The problem is the OIL FILTER. There is NO BMW dealer here on my island province ... So here comes the crunch! For me to buy an official BMW oil filter on-line and have it shipped from the dealer in Manila will cost me just short of $40!!!! ...
And buying off Amazon or e-bay is not any better:
... Also, buying in bulk from Amazon or similar is equally dangerous because then you're at the mercy of the notorious Philippine customs who seem to be a law in themselves. They can literally keep your items for WEEKS then charge you a ridiculous import duty (40, 50 or even 100% is not uncommon) together with a 'STORAGE' fee while they left in untouched in their warehouse! ...
GeoffPD, if it were me, I would just buy an equivalent automotive filter locally for the bike and be done with it.
The link Troop posted gives you quite a few part numbers to choose from.
What filter are you looking at that fits your Mazda that is variable, that may be the easier way to figure out if you should use it or not.
Re: Alternative oil filters [Re: GeoffPD] #5196531 08/25/19 06:56 PM
X
Xcbullet Offline
X
Standard Bosch is what I use on my Harley. If you can find a Bosch that fits it will be fine, they are great filters. Have torn many of them open, it's all I've used in 60,000 miles.
96 Gmc Z71 - restored & rebuilt
2000 Bonneville
2004 LeSabra
99 Electra Glide - rebuilt
2001 edge600 -rebuilt
2002 edgeX 600 - rebuilt
Re: Alternative oil filters [Re: GeoffPD] #5196656 08/25/19 09:11 PM
R
R
Blupupher-
Quote- "Did you read the original post?" - yes I did, and I replied "$14.99 in US Funds" with a link from a US reseller, and my earlier posts went into great detail about potential differences in US vs Philippines. I am thinking you did not read my previous replies and took the comment out of context, which is quite understandable if you only read my reply in isolation.
I work with a lot of contacts in both motorcycles and boats worldwide to address this sort of problem with parts availability. Recently I have been shocked at how strict certain Euro countries are in enforcing import duties: I shipped some used boat parts as a gift to a Scandinavian country with a total value of about $10. Yes they were hard to find, which explains why anybody would want used parts, but the recipient had to pay another $15 in import duties on a gift. But corruption by Customs enforcement is a topic I have not had to address in the past.
Re: Alternative oil filters [Re: GeoffPD] #5196809 08/26/19 05:46 AM
W
wagsrk08 Offline
W
Unless you can find and verify a correct alternative oil filter, I'd fall on the sword and pay the $40 for an OEM BMW filter. BMW's are not cheap! I'm not familiar with BMW service intervals, but you mentioned in original post it's due for it's 12 month servicing. If you only change the oil once a year then pay the $40 and be done with it.
2012 Toyota Tacoma 2.7L 5-Speed Manual 4WD
2016 Harley-Davidson FLHTK Ultra LImited
