belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
Help me understand
by 1978elcamino - 02/24/20 02:25 PM
2019 VW Passat Trip Mileage
by Boomer - 02/24/20 01:13 PM
Changed my ATF, difference is crazy!
by cwilliamsws6 - 02/24/20 12:36 PM
Specs on Conventional Oils 4 Comparing
by Perseus - 02/24/20 12:32 PM
EarlT500, Newbie111, Boris_Be, NHR, zip15
70798 Registered Users
44 registered members (Astro14, Bailes1992, Ag76, bbhero, aleneros, 928, 3 invisible), 1,378 guests, and 20 spiders.
Topics301,895
Posts5,204,854
Members70,798
Supertech vs OEM #5195703 08/24/19 07:05 PM
B
Bettez88 Offline OP
B
I was bored so I decided to hack apart an OEM Honda oil filter and a Supertech 6607 since that’s what Walmart recommends for my wife’s 2013 Honda Fit. I can’t believe the filter media size difference! Not sure I would use that small of a filter for any car!
Last picture is the Supertech filter recommended for my 2009 Corolla. Much better quality! OEM filter for comparison.
A9EA7E3C-4610-4729-B8FE-40D8442FE4D6.jpegF01765D4-3CAE-4181-A448-DC154EE1D547.jpeg03BB909E-C36E-41BD-95F3-69C7FEF13EFA.jpeg73490481-1A8B-48C8-9AF5-C068904A5B5C.jpeg4FDDE64A-1352-471C-A420-3D08335D3DD1.jpeg8CA1364F-F640-4905-866D-F9B1DACCC7E5.png
2013 Honda Fit, QSUD 0W20 with Honda filters
2009 Toyota Corolla, PP 0W20 with Toyota filters
Re: Supertech vs OEM [Re: Bettez88] #5195714 08/24/19 07:18 PM
CR94 Offline
I bought one of the ST10358 filters like yours, but haven't used it yet. The end caps and construction appear identical to Fram Extra Guard 10358 (although media might differ). Center holes of the end caps are a snug fit on the center tube of my spare cap.
2011 Toyota Prius now at 109K
Re: Supertech vs OEM [Re: CR94] #5195725 08/24/19 07:27 PM
B
Bettez88 Offline OP
B
The only difference I see between the Fram and Supertech 10358 are the size of the plastic endcaps
Re: Supertech vs OEM [Re: Bettez88] #5195736 08/24/19 07:38 PM
slacktide_bitog Offline
The PH7317 is basically the same as an A02, so use that smile
Re: Supertech vs OEM [Re: Bettez88] #5195774 08/24/19 08:30 PM
M
mattwithcats Offline
M
Wal-Mart does not make a 7317 equivalent, they use the 6607 for both 6607 and 7317 applications.
Try a Baldwin B1431 or Hastings LF486, they are four inches long, verses three and a half for the 7317...
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Wix XP 51356 filter, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: Supertech vs OEM [Re: Bettez88] #5195829 08/24/19 10:08 PM
blupupher Offline
You could also use a ST9688.
Seems the 7317 is a dying size. Many oil change shops consolidated filters, and use the 6607 for many applications (6607, 7317, 9688, 3693a).
Although the 6607 is smaller, there has been nothing to show that the smaller filter causes any issues.
'18 Santa Fe: PP 10W-30/OEM
'18 Soul: Synpower 5W-30/PG
'10 Santa Fe: Synpower 5w-30/D+
'04 F150: Magnatec 10w-30/ST
'12 xB: M1EP 0W-20/CQ Blue
'02 F150: Magnatec 5W-20/D+
'94 VT1100: Peak 15W-40/D+
Re: Supertech vs OEM [Re: Bettez88] #5195932 08/25/19 05:03 AM
Sayjac Offline
Quote
…..Seems the 7317 is a dying size....
In quick lube, indie, jobber tier filters (like ST), consolidation of 7317 for cost savings seems to be the rule. However as long as the vehicle manufacturers including Honda use it as the spec size, imo I don't believe 7317 application size availability is going away. Unlike the jobbers, the aftermarket still is going to try an offer equivalent to spec size applications. But as noted, the shorty 6607 is frequently used now as substitute for the 7317 and even the 9688 size. It is also the spec size on many/most Nissans.
As for using the 9688 size, many/most newer Honda and Nissan now have diameter restriction of some sort that make using the wider filter (used on older Honda) a no go. 7317 size is the biggest that can be used. While I agree the 6607 size acceptable to use, personally if 7317 or wider 9688 application is spec, using them would be my preference.
Re: Supertech vs OEM [Re: Bettez88] #5196063 08/25/19 08:27 AM
M
Mad_Hatter Offline
M
Do you know what the efficiency and dirt holding capacity of each is? And isn't a yellow media a synthetic and a brown cellulose? So these may be two filters meant for differing oci's. (5k v. 7.5/10k?)
Re: Supertech vs OEM [Re: Mad_Hatter] #5196160 08/25/19 10:38 AM
blupupher Offline
Well the Honda is basically a Fram ExtraGard in a blue can, so should be 95.7% @ 20 microns.
Supertech says on the box 99% @ 30 microns (but similar Champ made filters say 90% or 93% @ 20 microns).
The Supertech is advertised as a 10,000 mile filter.
Honda is by the OLM, which seems is around 8,000 miles (do they still recommend a filter change every other oil change?).
Re: Supertech vs OEM [Re: blupupher] #5196227 08/25/19 12:21 PM
M
Mad_Hatter Offline
M
What's the typical sump size for these filters? I wasn't aware ST made a 10k filter. I don't shop them as they don't make one for my ride. Anywho.. the filter has to meet OE spec for flow and efficiency, so I don't see what the issue is here. I have to believe tend of thousands of cars have logged millions of miles on that can without issues. As they say, size isn't everything.😂
Re: Supertech vs OEM [Re: Bettez88] #5196249 08/25/19 12:55 PM
M
Mr_Luke Offline
M
The smaller size has been what always shied me away from using ST oil filters but will reconsider them in the future (if I ever run out of MC, Fram, and Federated oil filters, lol). I can get a Fram for $3.75, a MC for about $4 each, an ST for $3, and a Federated for $2.17.
2012 Toyota Prius C / 108k
Conoco Phillips 0w20 FS
Federated PG4476F
Re: Supertech vs OEM [Re: Mr_Luke] #5196434 08/25/19 05:34 PM
M
Mad_Hatter Offline
M
At those prices it's not like spending the addtl .75c on the Fram is gonna change your way of life. But nice to know you've got so many good options at really good prices.👍 (no need to buy bulk from RA to get great pricing)
Re: Supertech vs OEM [Re: Mad_Hatter] #5196455 08/25/19 05:51 PM
F
Farnsworth Offline
F
That's interesting as no one knows the flow and efficiency of most OE filters except the OE. So any aftermarket filter can say we meet the specs, because it's only for specs that exist. Like size of thread, bypass yes or no and psi, adbv yes or no, size of can. etc.
Re: Supertech vs OEM [Re: blupupher] #5196581 08/25/19 07:50 PM
Coastie05 Offline
Honda still recommends a filter change every other oil change. However, I change mine every time. I have been using TG7317 on my CRV and plan to use UG7317 on my Pilot.
2018 Honda Pilot EX AWD
2013 Honda CRV EX
2014 Honda Civic LX (sold)
2001 Acura Integra GSR (sold)
Re: Supertech vs OEM [Re: Farnsworth] #5196675 08/25/19 09:46 PM
M
Mad_Hatter Offline
M
You missed the point entirely.
Try making a filter that doesn't meet the OE spec and see how long you stay in business.😂..The ST filter is made by a reputable company that's been in business a long time, so it meets the spec - trust me.😉 But if you wanna argue about what we don't know for certain, sure.. I'm your huckleberry.😂
