Originally Posted by kehyler
Originally Posted by 2015_PSD
Let's try and get back on topic, which is the pursuit of data-verification of lower temperatures.
Would we admit the following experiment as valid:
(1) drive the same stretch of long highway multiple times & measure the temperature of underside of the differential (not the cover) with an infrared temperature sensor?
(2) change the differential cover & fluid
(3) drive the same stretch of long highway multiple times (at same ambient temperature) & measure the temperature of underside of the differential (not the cover) with an infrared temperature sensor?
When then compare the temperatures obtained in (1) against those in (3) to see if the fluid cooler.
I think you would have to change gear oil first, put the old cover back on, then check temps. Otherwise you are comparing worn possibly lower viscosity sheared oil against new oil with the new cover.
You would also need to have a temperature probe directly in the fluid to eliminate any variables from the external reading and would need to have controlled "runs" for consistency otherwise, it is semi-guess work.
What variables from the external reading and why would they have a significant impact?
How will you compensate for the increased quantity of oil with the aftermarket cover? Will you run it longer or harder or? Reading externally has variables--different location, the rate of thermal transfer to the metal, etc, reading the fluid directly should not. In the end if the conditions are not controlled and repeatable, then the results will interesting, but highly debatable.
