New Fave way to remove snow from vehicles
by JC1 - 11/12/19 08:19 PM
Shying Away From Havoline 5w30
by Mr_Luke - 11/12/19 08:00 PM
New Way To Wash A Car
by buster - 11/12/19 07:52 PM
Sealed vs open bearings. What's better?
by motor_oil_madman - 11/12/19 07:51 PM
Wix WL10290XP CUT OPEN GM 22psi
by LotI - 11/12/19 07:04 PM
Do high beams make you angry?
by 1978elcamino - 11/12/19 06:46 PM
VALVOLINE V0-148 CUT OPEN
by 53' Stude - 11/12/19 06:38 PM
VW Jetta oil filter CUT OPEN
by 53' Stude - 11/12/19 06:31 PM
Turtle Wax Seal & Shine On Top of Ice or Vice-Versa ?
by Dwight_Frye - 11/12/19 06:10 PM
Timing Cover Leak in Toyota/Lexus
by Gebo - 11/12/19 05:10 PM
Anyone running only Malwarebytes for security
by Donald - 11/12/19 05:07 PM
104+ Fuel Injector Pro ?
by ChrisD46 - 11/12/19 04:55 PM
Mobil 1 FS 0w40 vs Castrol 0w40
by Ndx - 11/12/19 04:14 PM
How often to drive a second car.
by SouthDakotaDad - 11/12/19 03:48 PM
Manufacturers, Bypasses & Large Sumps
by ad244 - 11/12/19 03:23 PM
Samsung DeX for PC
by dogememe - 11/12/19 03:19 PM
2008 Acura TL Timing Belt/Component Kit
by BAJA_05 - 11/12/19 02:06 PM
Hombre909, DeLong, Scuder, Jasonrmcc, Capacc
69840 Registered Users
120 registered members (2K2AcuraTL, 2003f7, 14Accent, Aichiguy, 2015_PSD, 92saturnsl2, 12 invisible), 1,977 guests, and 19 spiders.
Topics297,336
Posts5,113,318
Members69,840
Most Online3,589
Nov 2nd, 2019
Page 2 of 2 1 2
Re: What grease for mower spindles? [Re: nomochevys] #1134430 04/22/08 12:18 AM
G
Gillsy Offline
G
Chevron Delo ep in everything I grease.
Many are the afflictions of a righteous man
2019 Nissan Murano S
2018 Gravely ZT HD 52
2016 Kawasaki 650 Versys LT
2012 Mazda 3 Skyactiv 2 ltr
Re: What grease for mower spindles? [Re: Gillsy] #1134448 04/22/08 03:22 AM
L
lars11 Offline
L
You can sometimes find a good place to drill a hole and fit a grease zerk to the bearing house. If you really are serious about greasing this stuff.!
Re: What grease for mower spindles? [Re: lars11] #1134552 04/22/08 08:03 AM
B
bob_ninja Offline
B
At the very least it is something to keep in mind when buying the next machine. On my current Scotts (relabeled JD) I don't have easy access to them.
thanks
Re: What grease for mower spindles? [Re: bob_ninja] #1139281 04/28/08 07:48 PM
B
Barkleymut Offline
B
you would know if you had grease zerks, i always used Valvoline because it was readily available and rated EP.
09 Vue(95K) 2.4 4spd AT -PU 5w30 / 09 Flex(52K)3.5L PU / Moms car 04 Pilot(105K) 5w20 PP + Puro
Re: What grease for mower spindles? [Re: Barkleymut] #1152511 05/16/08 06:40 AM
A
Allan_G Offline
A
I have a 1983 Wheelhorse C-145 Spindles on the 42" deck have grease zerks on the top.. I use Lucas Red N Tacky on them. So far so good. THey were bone dry when I bought this thing 6 years ago.
Anyone Else using LUCAS Red N Tacky?
Re: What grease for mower spindles? [Re: Allan_G] #1154482 05/19/08 01:12 PM
W
WishIhadatruck Offline
W
My JD LX277 with the 48C deck has them. I don't use anything special.
1996 Buick Roadmaster Wagon
2014 Cruze Eco Manual
2003 2500 Suburban, 8.1L
Re: What grease for mower spindles? [Re: WishIhadatruck] #1155282 05/20/08 02:40 PM
sweezy722 Offline
My Craftsman spindles have about 500 hours with Mystic JT6 and are as tight as new. I put Mystic JT6 in the lawn mower, bush hog, ATV, truck and boat alimites. I have only lost 2 bearings in the ATV and both times the seals were shot.
Re: What grease for mower spindles? [Re: sweezy722] #1155331 05/20/08 04:11 PM
P
pickled Offline
P
I like the Mystic products and the amsoil water resistant grease for that application. Golf course guys I know are using the water resistant grease on their reels and say that it holds up well.
Used gear lube and burnt ATF is all the cologne a real man will ever need!
Too many toys and automotive parts to list...
Re: What grease for mower spindles? [Re: pickled] #1156481 05/22/08 05:02 AM
doubleclutch Offline
The first thing I look at when buying a new piece of equipment is how many grease fittings are there, and where are they at! No grease fittings, I pass! I use the AMSOIL GLC #2 grease in everything from high speed trailer wheel bearings, mower spindles, 3 pt wood chipper bearings, U-joints, to the slow speed bushings on my yard trailer and wheel barrow. I buy it by the 14oz cartridge case and one will last me a couple of years.
Re: What grease for mower spindles? [Re: doubleclutch] #1156689 05/22/08 10:18 AM
R
RWEST Offline
R
I use the J-D "polyurea" #TY6341 multi-purpose stuff for the spindles on my J-D 54C deck, and everything else I have, too.
Got a good deal on a case of it a few years ago ($1.40/ea for 1# tubes) and it seems like good stuff. I smear a dab on the wife's glider swing pivots when I drag it out each spring, and it handles all the rain and stuff without squeaking for a couple months.
Interesting note about the lack of grease fittings some guys mentioned - my nephew's J-D L130 tractor has on of those "The Edge" decks on it. The original spindles have no zerks, but the replacements (2 so far - made in China \:\( ) he got from J-D, do. Mebbe if they had zerks from the factory, he wouldn't have had to replace the spindles? \:\(
"even if you're paranoid, they can still be following you" hide
"live so the preacher doesn't have to lie at your funeral" wink
Re: What grease for mower spindles? [Re: Allan_G] #1163830 06/01/08 09:10 PM
M
MCompact Offline
M
My Cub Enforcer 54 has grease fittings on the mower spindles as does my Dixon Estate ZTR. I use Mobil 1 grease with good results.
Mine:
2014 M235i
2009 Cooper Clubman
1999 Wrangler Sahara
1995 318ti Club Sport
Wife's:
2015 X1 xDrive28i M Sport
Son's
2009 328i
Buy what makes you smile...
Re: What grease for mower spindles? [Re: bob_ninja] #5195238 08/24/19 08:06 AM
CatCam2 Offline
thanks
Crazy thing is the Scotts S1642's owner's manual says the spindles are factory filled with grease and NOT to grease them (even though they have zerks fittings!)….so not resurrect a 10 year old thread but my S1642 is 19 years old (purchased April 2000) and I've lubed my spindles 2-3 times a year and haven't had any issues. Yes she's still running strong at 19!
I've only had to, just recently, replace the input shaft on her TuffTorq K51a transaxle.
I use the Mobile 1 grease.
I use Shell Rotella 15W-40 year round
I just replaced the original TuffTorq factory oil with Mobil 15W-50.
Re: What grease for mower spindles? [Re: TurboLuver] #5195257 08/24/19 08:40 AM
L
Lubener Offline
L
This thread is 11 years old. Those greasable ones are quickly going away.
The "thinking" man's friend.
Re: What grease for mower spindles? [Re: TurboLuver] #5195306 08/24/19 09:53 AM
dwendt44 Offline
As spindles generally use 'sealed' bearings, the grease works as a heat sink only. Those spindles
can get pretty warm if not hot with extended use.
My 2¢
There's no such thing as:
Too big of a battery,
Too large of a gas tank,
or too loud of a horn,
or too bright headlights.
Page 2 of 2 1 2
