OBD scanner
by NH73 - 02/23/20 10:18 AM
Oil additive and effects on oil analysis results
by MoneyJohn - 02/23/20 09:48 AM
More 6.7 PSD engine repairs
by mattd - 02/23/20 09:10 AM
How to get sediment out of heater oil tank?
by BAJA_05 - 02/23/20 08:37 AM
Oil Prices in Europe
by BBDartCA - 02/23/20 08:08 AM
Fury -Wilder 3?
by pbm - 02/23/20 06:41 AM
toro super recycler
by passgas55 - 02/23/20 06:05 AM
Chain style for ag tires
by puma4440 - 02/23/20 04:25 AM
2014 GMC Terrain 2.4L AWD
by Char Baby - 02/23/20 02:06 AM
Conventional VS Synthetic In The Winter Months
by BlueOvalFitter - 02/23/20 01:36 AM
Paint Splatter
by rrretiree7 - 02/23/20 12:54 AM
The Jeep Made it to 150k Miles - Storytime
by Nick1994 - 02/23/20 12:54 AM
Supertech vs Dexcool
by WA1DH - 02/22/20 11:44 PM
Spark plug gap f
by Rohan - 02/22/20 10:28 PM
Mad mike hughes.rip
by Chris142 - 02/22/20 10:15 PM
MTF drain = chocolate milk
by Texasdoc - 02/22/20 10:02 PM
New Valvoline looks promising?
by kr_bitog - 02/22/20 08:45 PM
rock like debris in generac generator 17kw
by jb5150 - 02/22/20 08:25 PM
Chaucha, UofA, Jeffrey78, Markovchain, o_s
70787 Registered Users
88 registered members (bdcardinal, 97prizm, 53' Stude, 74Widebody, 94astro, benjy, 14 invisible), 2,520 guests, and 17 spiders.
Topics301,826
Posts5,203,504
Members70,787
Is the 5.7gm engine still made brand new? #5194979 08/23/19 07:19 PM
M
motor_oil_madman Online Content OP
OP Online Content
M
I'm looking at doing a total repower on my boat and I've always been cautious about remanufactured engines cause some engine builders take short cuts or use marginal parts.
I was thinking of having my vortec 5.7 carbed engine turned into a 383 stroker and just using a reputable shop here in Houston.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: Is the 5.7gm engine still made brand new? [Re: motor_oil_madman] #5194981 08/23/19 07:23 PM
cpayne5 Offline
Yes, you can buy a brand new L31 from your local Chevy dealer for about $2k.
Re: Is the 5.7gm engine still made brand new? [Re: motor_oil_madman] #5194984 08/23/19 07:26 PM
R
rrwildlife Offline
R
https://www.ebay.com/itm/GM-OEM-NEW-CRATE-Engine-350-12530283-Chevrolet-5-7-L31R-DEALER-DIRECT-12681431/301567296304?hash=item4636cfc330:g:uxgAAOSwTC1dUc2L
I purchased one of the L31’s from Radley Chevrolet to upgrade a 83 Silverado to fuel injection. Fast shipping, the price was right, and the transaction was handled professionally
2020 Toyota Corolla SE 11,500 Toyota Dealership Oil/filter
2005 Toyota RAV4 - 180,000 Havoline Pro DS 5w30 Wix
2004 Pontiac Vibe - 187,000
Re: Is the 5.7gm engine still made brand new? [Re: rrwildlife] #5194987 08/23/19 07:36 PM
cpayne5 Offline
Originally Posted by rrwildlife
https://www.gmperformancemotor.com/parts/12703983.html
What EFI setup did you use?
Re: Is the 5.7gm engine still made brand new? [Re: motor_oil_madman] #5194990 08/23/19 07:40 PM
A
AVB Offline
A
Aren't boat engines reverse rotation?
Re: Is the 5.7gm engine still made brand new? [Re: cpayne5] #5194994 08/23/19 07:44 PM
R
rrwildlife Offline
R
Holley Sniper
Re: Is the 5.7gm engine still made brand new? [Re: motor_oil_madman] #5194997 08/23/19 07:47 PM
clinebarger Offline
GM Performance Parts still sells brand new 5.7L crate engines. None are intended for Marine use, Even though the Ramjet 350 is built as a marine engine (Has marine head gaskets/Brass core plugs) though I would upgrade the valve springs!!
*Some marine engines are reverse rotation, Something you need to know before doing anything.
I'm by no means a marine engine guy......Know just enough to be dangerous!!
2001 Chevy Camaro L92/4L80E
Re: Is the 5.7gm engine still made brand new? [Re: AVB] #5195016 08/23/19 08:14 PM
Chris142 Offline
Some are. If it has 2 engines one will rotate backwards to that the boat won't go lopsided.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Is the 5.7gm engine still made brand new? [Re: motor_oil_madman] #5195020 08/23/19 08:21 PM
M
OP Online Content
M
I don't think the engine turns backwards, the transmission/outdrive does.
Re: Is the 5.7gm engine still made brand new? [Re: motor_oil_madman] #5195031 08/23/19 08:49 PM
M
mk378 Offline
M
You would look at the balancer pulley on the front of the engine. If it turns clockwise it is the same as a car engine.
Re: Is the 5.7gm engine still made brand new? [Re: Chris142] #5195039 08/23/19 09:03 PM
E
Elkins45 Offline
E
Just mount one of your props backwards. smile
Re: Is the 5.7gm engine still made brand new? [Re: motor_oil_madman] #5195041 08/23/19 09:06 PM
Donald Offline
The 5.7 small block engines in boats were 4 bolt mains, similar to a truck 5.7.
There is a difference between rebuilding and remanufacturing an engine. The big companies that do engine remanufacturing have machines that the local rebuilders cannot afford. And a reman engine always changes a set number of parts whether it needs it or not. A rebuilding will change worn parts.
2015 Ford F-250 w/Powerstroke
Re: Is the 5.7gm engine still made brand new? [Re: motor_oil_madman] #5195050 08/23/19 09:17 PM
Donald Offline
The rest of the power train needs to be able to handle the increase in power.
Re: Is the 5.7gm engine still made brand new? [Re: motor_oil_madman] #5195054 08/23/19 09:24 PM
M
OP Online Content
M
It has a 4 bolt mains already and vortec heads. What else does it need? to be a 383 it will need a new crankshaft. connecting rods, etc.
Re: Is the 5.7gm engine still made brand new? [Re: motor_oil_madman] #5195078 08/23/19 10:31 PM
clinebarger Offline
You can run the factory 5.7" rods, The pistons will need to be swapped (Higher wrist pin height). You can also run 5.565" 400 rods but new pistons are still required.
383 is technically a .030" overbored 350/327 (4.00") block with a 400 3.75" stroke crank, We used to turn down 400 cranks before companies like Scat started offering cast & forged cranks just for this.
The increased stroke may not the best thing for a marine engine that spends its entire working life at higher RPM's, Sure.....If it's balanced well & you use top shelf Forgings, It may last longer than the original 350. Use bottom of barrel cast crank, Recon forged or powdered rods, & Cast pistons....Don't expect much in the way of longevity.
