Denso Iridium TT's are great
by jayjr1105 - 02/23/20 01:46 PM
Girl Scout question
by ffhdriver - 02/23/20 01:36 PM
MTD Snowblower issues
by 97prizm - 02/23/20 01:19 PM
OBD scanner
by NH73 - 02/23/20 10:18 AM
Oil additive and effects on oil analysis results
by MoneyJohn - 02/23/20 09:48 AM
More 6.7 PSD engine repairs
by mattd - 02/23/20 09:10 AM
How to get sediment out of heater oil tank?
by BAJA_05 - 02/23/20 08:37 AM
Oil Prices in Europe
by BBDartCA - 02/23/20 08:08 AM
Fury -Wilder 3?
by pbm - 02/23/20 06:41 AM
toro super recycler
by passgas55 - 02/23/20 06:05 AM
Chain style for ag tires
by puma4440 - 02/23/20 04:25 AM
2014 GMC Terrain 2.4L AWD
by Char Baby - 02/23/20 02:06 AM
Conventional VS Synthetic In The Winter Months
by BlueOvalFitter - 02/23/20 01:36 AM
Paint Splatter
by rrretiree7 - 02/23/20 12:54 AM
The Jeep Made it to 150k Miles - Storytime
by Nick1994 - 02/23/20 12:54 AM
Supertech vs Dexcool
by WA1DH - 02/22/20 11:44 PM
Spark plug gap f
by Rohan - 02/22/20 10:28 PM
Chaucha, UofA, Jeffrey78, Markovchain, o_s
70787 Registered Users
104 registered members (AZjeff, 74Widebody, 69GTX, 53' Stude, ammolab, 12 invisible), 2,774 guests, and 20 spiders.
Topics301,831
Posts5,203,551
Members70,787
2011 GMC Acadia Shock/Strut Replacement #5194810 08/23/19 02:49 PM
P
panthermike Offline OP
P
Another question for the good folks of BITOG:
I have a friend who owns this vehicle and is on a limited budget. I have the mechanical ability to do the job but am torn on part brands. I could go with ACDELCO but the only issue there is that everyone only sells the strut, so I would have to transfer the spring, etc to the new one. I can do it, but would prefer an all in one. The cost of these is 90/each.
Are there any other brands of struts for this application that would be considered good quality or should I just make the ACDelcos work? The aftermarket options are reasonably priced but I don't want her to have crummy parts either. So far options i've seen are Monroe, Gabriel, TRQ, and 1A Auto. Thanks for any input
'17 Armada Platinum; RGT 0w20, 52K
'19 Ram 1500; RGT 5w20, 15K
'70 F100; Valvoline 15w40
Biotech For All
Re: 2011 GMC Acadia Shock/Strut Replacement [Re: panthermike] #5194829 08/23/19 03:17 PM
skyactiv Offline
I do not like quick struts. Many people don't realize vehicles manufactures often have different springs for different models.
As an example, the vehicle manufacture might use front and rear springs that are .75 MM larger in diameter for a higher trim model that has a sunroof and leather seats vs
a lower trim model. The one size fits all approach on spring rates used on quick struts doesn't fly.
Me: 18' Elantra Sport 6 speed manual
The rude guy that points out reality
Re: 2011 GMC Acadia Shock/Strut Replacement [Re: panthermike] #5194845 08/23/19 03:49 PM
I
Imp4 Online Content
Online Content
I
Rock Auto shows no quick struts for your application.
That being said, I'd choose KYB for a good balance between quality and cost.
KYB is also offering a rebate at this time.
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
Re: 2011 GMC Acadia Shock/Strut Replacement [Re: skyactiv] #5194853 08/23/19 04:05 PM
P
P
Thanks for the heads up, I did not know that. I may just get the spring compression tool if that's the case and go ACDELCO all around.
Biotech For All
Re: 2011 GMC Acadia Shock/Strut Replacement [Re: Imp4] #5194898 08/23/19 05:17 PM
slacktide_bitog Offline
no-no
Cheap quick struts are no good and rarely last beyond 10k.
Get Monroe or KYB quick struts. They're awesome smile
KYB has a rebate promo going on right now, $50 off the set of 4, the 2 front quick struts and the 2 rear shocks. The KYB Gas-A-Just shocks for the rear and the quick struts up front will make your Acadia ride like new happy
If you don't use quick struts, get Bilstein shocks and struts. Using Bilstein is the only reason to not use quick struts. That is, Bilstein B6 (listed under the red section on Rock Auto "Increased Handling/Performance). Not the B4.
Rock Auto does indeed show quick struts for the OP's 2011 GMC Acadia smile
Re: 2011 GMC Acadia Shock/Strut Replacement [Re: slacktide_bitog] #5194938 08/23/19 06:17 PM
I
Imp4 Online Content
Online Content
I
Yikes!!! My bad.
Slacktide is correct!!!
Re: 2011 GMC Acadia Shock/Strut Replacement [Re: panthermike] #5195025 08/23/19 08:32 PM
P
P
Oh dang they have acdelco's to, missed that one! For the $40/each difference, should she just go with the acs?
Biotech For All
Re: 2011 GMC Acadia Shock/Strut Replacement [Re: panthermike] #5195040 08/23/19 09:04 PM
The ACDelco quick struts are not OEM parts. They are reboxed Gabriel mad
However, the OE strut itself (NOT the quick strut) is available on Rockauto. You have to be careful when shopping ACDelco parts. It has to say "GM Original Equipment" in order to actually be the OE parts. They have a few other lines including "Professional" which is reboxed mid-grade aftermarket parts, and Advantage (Disadvantage) which is usually bottom-rung scrap metal. The only times where "Professional" is the same as OEM is pars such as filters and spark plugs.
As an aside, Ford *does* offer Motorcraft quick struts that actually are OEM parts.
So, either get the KYB quick struts + Gas-a-just shocks, or get Bilstein struts and shocks if you're willing to use a spring compressor.
Re: 2011 GMC Acadia Shock/Strut Replacement [Re: panthermike] #5195045 08/23/19 09:10 PM
clinebarger Offline
They are probably NOT OE.....AC Delco has different tiers of part quality!
The OE Sachs struts.....Toyota OE Springs, Mounts, & Isolators for the front of my Avalon cost almost $1000 in parts alone.....Just the front! GM vehicles are usually cheaper but still way more than the "Economy" offerings.
Bilsteins may cause a harsh ride......I love the Bilsteins on my 2500HD & Camaro, But never had much liking for them on a CUV or Sedan.
2001 Chevy Camaro L92/4L80E
Re: 2011 GMC Acadia Shock/Strut Replacement [Re: panthermike] #5195312 08/24/19 10:00 AM
P
P
Wow thanks for the schooling guys! I would have never known. Thanks for the tip on the KYBs slacktide!
Biotech For All
Re: 2011 GMC Acadia Shock/Strut Replacement [Re: panthermike] #5195484 08/24/19 01:24 PM
N
NYEngineer Offline
N
I put Bilstiens in my Suburban about 65,000 miles ago and couldn't be more pleased with them.
Re: 2011 GMC Acadia Shock/Strut Replacement [Re: panthermike] #5219067 09/21/19 04:51 PM
P
P
Did the job this morning; wasn't terrible at all just time consuming three and a half hours or so including a tool run haha. Plus it saved her around $600.
Ended up going with the KYB quick struts and the KYB gas adjust for the rear. Took it for a test drive and all seems good rode nice, she took it for an alignment immediately after.
Biotech For All
