Denso Iridium TT's are great
by jayjr1105 - 02/23/20 01:46 PM
Girl Scout question
by ffhdriver - 02/23/20 01:36 PM
MTD Snowblower issues
by 97prizm - 02/23/20 01:19 PM
OBD scanner
by NH73 - 02/23/20 10:18 AM
Oil additive and effects on oil analysis results
by MoneyJohn - 02/23/20 09:48 AM
More 6.7 PSD engine repairs
by mattd - 02/23/20 09:10 AM
How to get sediment out of heater oil tank?
by BAJA_05 - 02/23/20 08:37 AM
Oil Prices in Europe
by BBDartCA - 02/23/20 08:08 AM
Fury -Wilder 3?
by pbm - 02/23/20 06:41 AM
toro super recycler
by passgas55 - 02/23/20 06:05 AM
Chain style for ag tires
by puma4440 - 02/23/20 04:25 AM
2014 GMC Terrain 2.4L AWD
by Char Baby - 02/23/20 02:06 AM
Conventional VS Synthetic In The Winter Months
by BlueOvalFitter - 02/23/20 01:36 AM
Paint Splatter
by rrretiree7 - 02/23/20 12:54 AM
The Jeep Made it to 150k Miles - Storytime
by Nick1994 - 02/23/20 12:54 AM
Supertech vs Dexcool
by WA1DH - 02/22/20 11:44 PM
Spark plug gap f
by Rohan - 02/22/20 10:28 PM
Chaucha, UofA, Jeffrey78, Markovchain, o_s
70787 Registered Users
107 registered members (69GTX, 53' Stude, ammolab, 74Widebody, ABursell, 11 invisible), 2,830 guests, and 23 spiders.
Topics301,830
Posts5,203,536
Members70,787
Confusion on oil to use on BMW 328i 2010 #5194779 08/23/19 02:21 PM
G
goldenjava Offline OP
G
So, I have a 2010 BMW 328i. I've read up on what type of oil I'm supposed to use:
Castro Syntec European Formula SAE 0w-30
Mobil 1 SAE 0W-40
Penzoil Platnium European Formula ultra SAE 5W-30
Valvoline SynPower SAE 5W-30
I've narrowed it down to Mobil 1 SAE 0W-40 because it is the easiest to find in my area. However, I am a bit confused about the difference between Mobil 1 SAE 0W-40 vs. Mobil Advanced, and Mobil European Formula.
I am a total novice at this and would just like to find the correct oil for my car. It's starting to burn oil more quickly as well. Any help is greatly appreciated.
Re: Confusion on oil to use on BMW 328i 2010 [Re: goldenjava] #5194783 08/23/19 02:24 PM
K
kschachn Offline
K
As I posted in your other thread, what is needed is an oil that has the approval required by your owner's manual. All that brand stuff and the grades you posted are irrelevant, what matters is the approval. In your reading, what does your owner's manual give for the required approval?
1994 BMW 530i, 251K
1996 Honda Accord, 280K
1999 Toyota Sienna, 430K
2000 Toyota ECHO, 284K
Re: Confusion on oil to use on BMW 328i 2010 [Re: kschachn] #5194790 08/23/19 02:30 PM
G
G
The above 4 oils I listed is what is recommended by BMW on a link I found for my car. It needs to be LL-01. However, the Mobil oils today is named Mobil Advanced, or Mobil European Formula. I'm just wondering if I find the same 0W-40 but under different Mobil name, it will be the same?
Re: Confusion on oil to use on BMW 328i 2010 [Re: goldenjava] #5194795 08/23/19 02:34 PM
Quattro Pete Offline
Technically, none of the Mobil oils in the US carry the BMW LL-01 approval anymore.
So if you really want an LL-01 oil, you can scratch Mobil off your list.
2002 530i   2015 Q5 3.0T   2018 Charger SRT
Re: Confusion on oil to use on BMW 328i 2010 [Re: Quattro Pete] #5194798 08/23/19 02:37 PM
G
G
Well, that's no good. Anyone know a equivalent I should use for this older car?
Re: Confusion on oil to use on BMW 328i 2010 [Re: goldenjava] #5194804 08/23/19 02:43 PM
K
kschachn Offline
K
No it isn't the same if it doesn't have the same approval. Names and so forth are irrelevant, what is printed on the container as an approval is what's important. And not one that is "recommended for".
Mobil 1 0W-40 no longer has Longlife-01 approval, and according to most on here Castrol 0W-40 no longer has the approval either (however all the Castrol 0W-40 in my local Walmart is still labeled with Longlife-01 approval, so your mileage may vary.) It does appear that it's getting harder to find a cheap Longlife-01 oil.
Having said that, both the Mobil 1 0W-40 and the Castrol 0W-40 have Porsche A40 and Mercedes-Benz 229.5 approvals which are very demanding approvals and are at least equivalent to Longlife-01. In a car that is out of warranty I would have no issues using either one based on those two approvals. They are inexpensive at Walmart as well.
1994 BMW 530i, 251K
Re: Confusion on oil to use on BMW 328i 2010 [Re: goldenjava] #5194805 08/23/19 02:43 PM
I'm using Castrol Edge 0W-40 in my 2002 530i. It's readily available at most Walmart stores in 5qt jugs, or you can get it on Amazon.com.
Technically, Castrol no longer carries the LL-01 spec either, although the jugs on store shelves still show it.
LL-01 is an outdated spec, so that's why not many oils still carry it. For an older car like yours, I wouldn't sweat it too much. Anything with ACEA A3/B4 approval or MB 229.5 approval will work just fine.
Re: Confusion on oil to use on BMW 328i 2010 [Re: goldenjava] #5194812 08/23/19 02:52 PM
The Critic Offline
BMW LL-01 is slowly being phased out. BMW has deemed LL-01FE to be backwards compatible for all applications which previously called for LL-01.
https://www.fcpeuro.com/products/bmw-engine-oil-07510017866
2011 Toyota Prius 1.8L - 203K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 143K - Valvoline Premium Blue Restore 10W-30
Re: Confusion on oil to use on BMW 328i 2010 [Re: goldenjava] #5194815 08/23/19 02:59 PM
K
kschachn Offline
K
Can you post the link that shows where BMW recommended those oils for your car?
1994 BMW 530i, 251K
Re: Confusion on oil to use on BMW 328i 2010 [Re: The Critic] #5194820 08/23/19 03:02 PM
G
G
Thank you for this link. I just need to top off my car now and then will get the BMW oil for future change.
I also wonder if you all recommend High Mileage Oil for over 75,000 miles (of course it will need to meet the car requirements).
Re: Confusion on oil to use on BMW 328i 2010 [Re: kschachn] #5194823 08/23/19 03:08 PM
G
G
This is a link I found for 2019 but I suspect it's not for my 2010 car. https://atfulldrive.com/best-oil-for-bmw
The link I found for the 2010 328i I found on a Bimmer Forum. I'll post it when I find it again.
Re: Confusion on oil to use on BMW 328i 2010 [Re: goldenjava] #5194824 08/23/19 03:10 PM
G
G
Re: Confusion on oil to use on BMW 328i 2010 [Re: goldenjava] #5194825 08/23/19 03:12 PM
K
kschachn Offline
K
The first site you posted is a perfect illustration of why no one should ever believe everything they read on the Internet. That is a complete train wreck.
1994 BMW 530i, 251K
Re: Confusion on oil to use on BMW 328i 2010 [Re: goldenjava] #5194827 08/23/19 03:15 PM
How about actually looking at what's written in your owner's manual instead?
Re: Confusion on oil to use on BMW 328i 2010 [Re: goldenjava] #5194836 08/23/19 03:29 PM
rooflessVW Offline
Pick Mobil 1 FS 0W-40 or Castrol Edge 0W-40 and keep it to 10k/1yr. Either are more than adequate.
Castrol Edge 5W-40 is still LL-01 approved if you're hung up on the specification.
Mann, Mahle, or Hengst filters.
Simple.
"Zed's dead baby, Zed's dead."
