Originally Posted by The Critic
The grey coating is supposed to be geo-met. Zimmerman and the german mfg's started it. The Asian rotors now have a similar process, but it is not the same.
The black paint is often e-coat, but many mfg's are moving away from this process due to the environmental issues.
Originally Posted by Wolf359
I installed coated Zimmerman rotors almost a year ago. The coated part lasted a while but I just checked recently and it's pretty much all gone at this point and certain parts of the rotor are starting to rust, but it's not that bad yet, just light rust, still areas that haven't rusted yet. Rotors are basically iron so you've got to expect them to rust as their job is also to dissipate heat from the rotors.
Did the geo-met coating last longer or shorter than the original MB rotors?
Bought the cars used so the rotors always had rust on them and the only aftermarket ones I've used are Zimmerman. MB can be lame sometimes, even their lug bolts aren't chrome and have rust on them. Got them from fcpeuro so they have a lifetime warranty on their parts so I'm not worried about the rotors.
