HUBB reusable stainless steel filter?
by Vern_in_IL - 02/18/20 08:41 PM
Ultrasonic carb cleaning problems
by atikovi - 02/18/20 08:05 PM
Cheeseburger pie
by P10crew - 02/18/20 07:25 PM
The midwinter detail.
by dan_erickson - 02/18/20 05:27 PM
Tired of Using Cassette Player with iPhone
by Gebo - 02/18/20 05:04 PM
STP oil filter
by Stinky123 - 02/18/20 04:41 PM
How is this possible
by V10 - 02/18/20 04:07 PM
Monroe made in Turkey
by atikovi - 02/18/20 03:31 PM
NSFBitog
by Ursatdx - 02/18/20 03:25 PM
Wider rear tires?
by drop - 02/18/20 03:07 PM
ROCKAUTO Coupon Codes
by jrvn - 02/18/20 02:24 PM
Gold (brass?) flecks in drained Honda ATF
by TNM6i - 02/18/20 12:10 PM
What happened to licensed ATF clones?
by TimN3QE - 02/18/20 12:08 PM
E85 in non-flex fuel Ford Expy ~2013
by DriveHard - 02/18/20 11:46 AM
Jacking up a car by itself
by Alfred_B - 02/18/20 11:44 AM
Valvoline MST in 2015 Macan S
by musclecarscott - 02/18/20 11:43 AM
PH10060 oversized?
by bullwinkle - 02/18/20 11:36 AM
GardenStateAudi, Strommen95, Idaholewis, Sprite, spbonus
70746 Registered Users
86 registered members (Ag76, AdditionalD, AC1DD, aleneros, 2009Caraman, 2010Civic, 12 invisible), 1,760 guests, and 15 spiders.
Topics301,629
Posts5,199,489
Members70,746
Gen 2 ctsv...best oil opinion #5192563 08/20/19 10:10 PM
Stickygreen Offline OP
Car is a ‘14 cts-v wagon with 30k miles. Don’t get to drive it much bc of work, but when I do it gets run pretty hard...no track as of yet, just canyon carving and the occasional road rally. To give an idea, got a worst tank of 7 mpg running around the hills by Lake Berryessa.
I’ve been using PUP 5w30 every 12mo/5k miles since new because of warranty...it was subjectively the best oil I could find that met dexos specs. Warranty is set to expire in November, so I’d like to run something more robust and that doesn’t necessarily meet spec.
What would you guys consider the best fit for a fairly hard-driven LSA with price being no object? Leaning towards Redline 5w30 but open to suggestions.
‘19 cx5 touring - Edge 0w20
‘16 Ram 2500 ctd- Rotella 5w40
‘14 ctsv wagon - PU 5w30
‘08 Ram 1500 4.7 - M1 0w40
‘84 euro 635csi - RL 10w40
Re: Gen 2 ctsv...best oil opinion [Re: Stickygreen] #5192587 08/20/19 11:04 PM
A
Averroes Offline
A
Money no object? Well here’s my opinion.
Amsoil - Anything SS series either 5w30 or 5w40
Redline - 5w30/40
Schaffers - Anything 5w30/40
Motul - 300V
Shell Helix - 5W30/40
Take take your pic. Since you push it hard and switch every 5k miles pick any. The above are fine (though Amsoil is a extended oil change interval oil, well the SS anyway).
And then here are three much cheaper and easily accessible choices:
M1 - 0w40
Castrol - 0w40
Castrol 0w30 (check back, should say made in Belgium)
Oil filters (money no object)
-Amsoil
-Fram Ultra
-Royal Purple
Please keep in mind that your transmission fluid and diff fluid will be taking a beating too. So when it comes to those make sure you’re using the best as well if money is no object. For transmission and Diff, I’d throw in Amsoil or Schaefer’s, followed by Redline.
Synthetic or bust.
Re: Gen 2 ctsv...best oil opinion [Re: Averroes] #5192693 08/21/19 06:54 AM
A
avi1777 Offline
A
Redline - 5w30/40
Motul - 300V
M1 - 0w40
Castrol - 0w40
-Amsoil
-Fram Ultra
-Royal Purple
300v is top notch but not for long or even normal intervals.its more of a racing oil.
Re: Gen 2 ctsv...best oil opinion [Re: Stickygreen] #5192696 08/21/19 06:57 AM
A
avi1777 Offline
A
i would go with redline or amsoil altho the m1 0w40 is known to be tough oil,but if it was my car redline all day.
Re: Gen 2 ctsv...best oil opinion [Re: avi1777] #5192759 08/21/19 08:18 AM
A
Averroes Offline
A
Redline - 5w30/40
Motul - 300V
M1 - 0w40
Castrol - 0w40
-Amsoil
-Fram Ultra
-Royal Purple
True, I'll edit that in. However look at these VOA and UOA on other sites, mind you the engine types are different.
https://www.s2ki.com/forums/s2000-under-hood-22/motul-300v-5w30-uoa-747908/
If he swaps it out before 4k miles, or even less he will be fine.
Synthetic or bust.
Re: Gen 2 ctsv...best oil opinion [Re: Stickygreen] #5193331 08/21/19 07:34 PM
Thanks...will stick with the RL 5w30 for the engine
Re: Gen 2 ctsv...best oil opinion [Re: Stickygreen] #5193534 08/22/19 03:26 AM
A
avi1777 Offline
A
regardless get a good oil catch can
Re: Gen 2 ctsv...best oil opinion [Re: Averroes] #5193577 08/22/19 05:33 AM
A
avi1777 Offline
A
Redline - 5w30/40
Motul - 300V
M1 - 0w40
Castrol - 0w40
-Amsoil
-Fram Ultra
-Royal Purple
do u mean shell helix ultra w30?
didnt know its good as the redline ex.
Re: Gen 2 ctsv...best oil opinion [Re: Stickygreen] #5193726 08/22/19 09:07 AM
A
A_Harman Offline
A
Redline 5w30.
Fram Ultra filter.
PCV catch can.
2008 Dodge Ram 3500 diesel/G56
1985 Z51 Corvette track car 355/6-speed
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel/NV4500+GV
1972 GMC 1500 shortbed project truck 307/SM465
Re: Gen 2 ctsv...best oil opinion [Re: Stickygreen] #5193748 08/22/19 09:34 AM
N
nascarnation Offline
N
From my limited knowledge, the biggest failure mode on these (in a severe duty cycle) is piston fatigue failures.
So no high priced oil is going to have any effect there.
When tracking make sure your oil pressure is always good during high g cornering combined with braking/acceleration.
Re: Gen 2 ctsv...best oil opinion [Re: Stickygreen] #5194078 08/22/19 05:29 PM
Yes just read about these LSA’s needing a catch can. Will have to look into that. Have these suffered from oil starvation around corners? Was surprised to find these engines only take 6 qts of oil
Re: Gen 2 ctsv...best oil opinion [Re: Stickygreen] #5194274 08/22/19 09:28 PM
B
burla Offline
B
What's up neighbor? I haven't been to berryessa for a long while, my question is do they still let you jump off the bridge? I probably been off that bridge 50 times. I used to race a 3 seat v drive up there with a crazy set of twin brothers, good ol times boy. They flipped it the week after we had a good 10 races the week before with me in the boat, nobody got hurt thanks god. Of course they were early morning runs, no way this thing could go this fast when it gets choppy. Well over 80mph, which of course on water is hualing it.
Nick at this place https://gotexhaust.com/ sells redline 5w30 under 12 bucks a qrt shipped free by the case, pretty decent price and I think he beats amazon due to tax.
Re: Gen 2 ctsv...best oil opinion [Re: Stickygreen] #5195047 08/23/19 09:12 PM
Thanks for the RL tip...I live down in the valley near Modesto, but that trip at night around the lake was one of my first hard runs in this car. There was no traffic and it was one of those almost-spiritual experiences...until I noticed the fuel light come on with less than 100 miles on the tank. My neck was a little sore the next morning 😁
