2014 GMC Terrain 2.4L AWD
by Char Baby - 02/23/20 02:06 AM
Conventional VS Synthetic In The Winter Months
by BlueOvalFitter - 02/23/20 01:36 AM
Paint Splatter
by rrretiree7 - 02/23/20 12:54 AM
The Jeep Made it to 150k Miles - Storytime
by Nick1994 - 02/23/20 12:54 AM
Supertech vs Dexcool
by WA1DH - 02/22/20 11:44 PM
Spark plug gap f
by Rohan - 02/22/20 10:28 PM
Mad mike hughes.rip
by Chris142 - 02/22/20 10:15 PM
MTF drain = chocolate milk
by Texasdoc - 02/22/20 10:02 PM
New Valvoline looks promising?
by kr_bitog - 02/22/20 08:45 PM
rock like debris in generac generator 17kw
by jb5150 - 02/22/20 08:25 PM
FL820S C&P BAD GLUE JOB
by naterbomb - 02/22/20 08:21 PM
Photo Uploader Not Working
by ZeeOSix - 02/22/20 07:49 PM
Faulty clutch master cylinder 17” Honda Civic
by parshisa - 02/22/20 07:33 PM
Ford drain plugs
by buck91 - 02/22/20 07:09 PM
What's the greatest amount of miles you've heard of someone
by Speak2Mountain - 02/22/20 05:53 PM
Oil Jug - Leaking
by MasterSolenoid - 02/22/20 05:40 PM
Which one
by tiger862 - 02/22/20 05:05 PM
HM from the start?
by AJB0009 - 02/22/20 04:00 PM
Fram XG3600 instead of XG3614
by BTW574 - 02/22/20 03:57 PM
Unbranded Hydraulic Fluid Filters
by shibby6600 - 02/22/20 03:53 PM
Markovchain, o_s, naterbomb, Jimiii, jb5150
70784 Registered Users
27 registered members (bachman, 74Widebody, ArgleBargle, BlakeB, 97prizm, 2 invisible), 711 guests, and 17 spiders.
Topics301,814
Posts5,203,192
Members70,784
Confused, what oil to use? #5194148 08/22/19 07:00 PM
B
BelAir Offline OP
B
I need advice on what to do and use next.
I just obtained my first Diesel for the farm & ranch. It’s a Case 580K phase3 backhoe running the Cummins 4-cylinder with turbo, hour meter stuck at 3600hrs but engine runs great. Oil level is at top of add zone and very black. The PO didn’t run it and knows little about it’s history. Should I have the oil tested before I add more or just service it then do an analysis after xxxx Hours?
But what do I change it to. I’ve read it needs API CE 10w-30 but that’s old specs and all the new oil types seem made for pickups with emission stuff have me confused.
Thanks
Re: Confused, what oil to use? [Re: BelAir] #5194163 08/22/19 07:20 PM
I
Imp4 Offline
I
Straight from the API guide...
CI-4 - Current
Introduced in 2002. For high-speed, four-stroke engines designed to meet 2004 exhaust emission standards implemented in 2002. CI-4 oils are formulated to sustain engine durability where exhaust gas recirculation (EGR) is used and are
intended for use with diesel fuels ranging in sulfur content up to 0.5% weight. Can be used in place of CD, CE, CF-4,
CG-4, and CH-4 oils. Some CI-4 oils may also qualify for the CI-4 PLUS designation.
API oil guide
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
Re: Confused, what oil to use? [Re: BelAir] #5194180 08/22/19 07:42 PM
J
JLTD Offline
J
No telling how long the old oil has been in the sump so any UOA would mean litle.
Change and sample after x hours.
Lates.
Re: Confused, what oil to use? [Re: BelAir] #5194181 08/22/19 07:44 PM
B
BelAir Offline OP
B
Thanks,
But if I can’t find CI-4 locally, then I assume I can just move to more recent types like CJ-4 or CK-4 that are found locally?
I guess I better find what Sulfur content fuel I’ll be using too and match the oil to it, right?
Re: Confused, what oil to use? [Re: BelAir] #5194187 08/22/19 07:48 PM
B
BelAir Offline OP
B
Changing it first, was my thought but wanted to ask for confirmation. So after how many hours would be a good time to get an analysis?
Re: Confused, what oil to use? [Re: BelAir] #5194220 08/22/19 08:13 PM
M
mattwithcats Offline
M
Change oil
Use Shell Rotella T6 in 5W-40, or it’s hard to find brother, 0W-40
Change after 50 hours, then every 200 hours.
Get a new hour meter...
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Wix XP 51356 filter, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: Confused, what oil to use? [Re: BelAir] #5194227 08/22/19 08:16 PM
M
M
Oil filter look like Wix 51602
2009 Smart Pure
Re: Confused, what oil to use? [Re: BelAir] #5194323 08/23/19 02:09 AM
toneydoc Offline
Mattwithcats suggested some good oil and new filter
And change the meter so you can change oil without guesswork
1994 Jeep 167k NextGen 10w30
2014 Camry 44k Castrol Magnatec 0w20
2018 Jeep Cherokee 8k Pennzoil Platinum 5w30
2014 HD Ultra 51k Mobil1 15w50
Re: Confused, what oil to use? [Re: BelAir] #5194350 08/23/19 04:49 AM
dnewton3 Offline
Global Moderator
Global Moderator
1) do not overthink this
2) go right to your local farm supply store or WM and get some house brand 15w-40 and a filter (Wix, Fram, etc)
3) pick up a new hour meter; Napa, web, wherever (does not need to be an exact fit; just get something you can wire 12v to a hot lead so it runs when the ignition is on)
4) OFCI every 200 hours or so
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: Confused, what oil to use? [Re: BelAir] #5194366 08/23/19 05:19 AM
I
Imp4 Offline
I
As others have stated, some Rotella or a house brand 5w-40 or 15w-40 would work well.
Run a 50 hour OCI and dump it. Do not get an analysis on this short OCI because it will be contaminated with residuals from the unknown oil and the analysis will be meaningless.
Refill with Rotella or house brand 5w or 15w-40 and run 200 hours. Get an analysis of the 200 hour oil and see where you stand.
Good luck!!
cheers
Re: Confused, what oil to use? [Re: BelAir] #5194967 08/23/19 07:06 PM
G
Garak Offline
G
Dave Newton is absolutely right. Any off the shelf HDEO with a current spec is backwards compatible and suitable for use.
Plain, simple Garak.
