Chain style for ag tires
by puma4440 - 02/23/20 04:25 AM
2014 GMC Terrain 2.4L AWD
by Char Baby - 02/23/20 02:06 AM
Conventional VS Synthetic In The Winter Months
by BlueOvalFitter - 02/23/20 01:36 AM
Paint Splatter
by rrretiree7 - 02/23/20 12:54 AM
The Jeep Made it to 150k Miles - Storytime
by Nick1994 - 02/23/20 12:54 AM
Supertech vs Dexcool
by WA1DH - 02/22/20 11:44 PM
Spark plug gap f
by Rohan - 02/22/20 10:28 PM
Mad mike hughes.rip
by Chris142 - 02/22/20 10:15 PM
MTF drain = chocolate milk
by Texasdoc - 02/22/20 10:02 PM
New Valvoline looks promising?
by kr_bitog - 02/22/20 08:45 PM
rock like debris in generac generator 17kw
by jb5150 - 02/22/20 08:25 PM
FL820S C&P BAD GLUE JOB
by naterbomb - 02/22/20 08:21 PM
Photo Uploader Not Working
by ZeeOSix - 02/22/20 07:49 PM
Faulty clutch master cylinder 17” Honda Civic
by parshisa - 02/22/20 07:33 PM
Ford drain plugs
by buck91 - 02/22/20 07:09 PM
What's the greatest amount of miles you've heard of someone
by Speak2Mountain - 02/22/20 05:53 PM
Oil Jug - Leaking
by MasterSolenoid - 02/22/20 05:40 PM
Which one
by tiger862 - 02/22/20 05:05 PM
HM from the start?
by AJB0009 - 02/22/20 04:00 PM
Fram XG3600 instead of XG3614
by BTW574 - 02/22/20 03:57 PM
Markovchain, o_s, naterbomb, Jimiii, jb5150
70784 Registered Users
38 registered members (Bailes1992, bachman, Arrechera, 53' Stude, AurionX2, 750IX, 3 invisible), 770 guests, and 16 spiders.
Topics301,815
Posts5,203,205
Members70,784
Motul 300V -- oops #5194083 08/22/19 05:35 PM
X
xr650boy Offline OP
X
I've been running Motul 300V 15w50 in my Super Duke and it's been great. Shift quality seems to be holding up better than the Motorex PowerSynt I ran before. And the weird green color is cool. So I buy some more. Or so I thought.
Turns out I mistakenly ordered, and received, 2 liters of the 300V 15w50 "Motorsport" in a very cool metal can to go with some 300V bike oil I had left over. Car oil in other words. The specs aren't exactly the same as the 300V bike oil, but they're very close indeed.
What's the wisdom of the crowd on this one? OK to mix with the bike oil in basically a 50/50 ratio, or just set it aside and use as a spendy top off oil?
'06 FJR1300A
'15 Focus ST
'17 1290 Super Duke R
Re: Motul 300V -- oops [Re: xr650boy] #5194138 08/22/19 06:51 PM
B
Bonz Offline
B
My two cents worth is you'll be fine. No brand of 15w50 has negative friction modifying characteristics that I'm aware of so mixing it 50/50 would probably be a great way to go and probably never know the difference.
Is the Motorsport an ester oil as well? I asked because someone suggested Mobil 1 10w40 high mileage synthetic was basically the same as Mobil 1 10w40 4T racing motorcycle specific oil. I look at the analysis of recent samples of both and they are not even close. I suspect the motorcycle specific oil has more ester content in it, as it does not break down to any extent in 5,000 miles in a shared sump ZRX 1200 which would be hard on the oil very much like your KTM.
Re: Motul 300V -- oops [Re: xr650boy] #5194291 08/22/19 10:56 PM
P
Panos Offline
P
I would mix (or top up if your engine cosume oil),but not more than 25% of the Motorsport one,just to be safe...
Ford Fiesta 1.6 '05 - Motul specific 913D/Motul Gear 300 180K+ Kms
Kawasaki Ninja 250R '08 - Shell Advance Ultra 4T 10w40 75K+ Kms
Honda CBR600F pc41 '14 - Motul 7100 10w30 25K+ Kms
Re: Motul 300V -- oops [Re: xr650boy] #5194297 08/22/19 11:12 PM
BusyLittleShop Offline
Mixing oils is a crap shoot whether you will upset the balance and negate protection...
Quote Blackstone Labs wisdom...
"Usually, at least several of these additives will be synergistic. That
is, they react mutually, in groups of two or more, to create an effect
that none of them could attain individually. Changing or adding to
this formula can upset the balance and negate the protective effect
the formula was meant to achieve, even if you are only adding more of
something that was already included in the initial package."
"This information should also be taken into account when adding to the
oil already in your bike or when mixing oils for any reason, such as
synthetic with petroleum. In these cases, always make sure the oils
you are putting together have the same rating. This tells you their
additive packages are basically the same, or at least compatible, and
are less likely to upset the balance or counteract each other."
Larry L
Have a Wheelie NICE day
94 RC45 #2 58,000 on 30 Grade, Currently Mobil 1 5W30 SN
2002 Camaro Mobil 1 5W30
1952 De Havilland Chipmunk
Re: Motul 300V -- oops [Re: xr650boy] #5194465 08/23/19 07:51 AM
sunruh Offline
that combo will be better than most you can buy.
run it with zero worries
motorcycle oil myth buster
Re: Motul 300V -- oops [Re: xr650boy] #5194503 08/23/19 09:02 AM
A
A_Harman Offline
A
If you're liking what you're feeling with your current fill, don't do anything that may change it.
I have found that the shifting feel of the NV4500 trans in my Dodge is very sensitive to the fluid.
2008 Dodge Ram 3500 diesel/G56
1985 Z51 Corvette track car 355/6-speed
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel/NV4500+GV
1972 GMC 1500 shortbed project truck 307/SM465
Re: Motul 300V -- oops [Re: xr650boy] #5198306 08/27/19 06:37 PM
J
JPowell490 Offline
J
I run 300v 10w40 motorcycle as well. I personally wouldn't mix those two. Send it back and exchange it.
