Amateur Paint Questions
by The Critic - 11/18/19 04:15 AM
What the..
by Mad_Hatter - 11/18/19 03:53 AM
Neighborhood Etiquette
by The Critic - 11/18/19 03:41 AM
AME 37330 Hub Cleaner for Impact Wrench
by The Critic - 11/18/19 01:54 AM
Plastic bag vs Car
by The Critic - 11/18/19 01:50 AM
Fram XG7317 20k miles cut open
by dbeau - 11/17/19 09:46 PM
2021 Ford Mach-E Electric SUV
by KeithS_NW_Ohio - 11/17/19 09:05 PM
Walker mower Oil
by Joey737 - 11/17/19 09:03 PM
Rough service tough light bulb 1¢ at Home Depot
by JLawrence08648 - 11/17/19 08:40 PM
2015 F150 5.0; 10w-30/5w-40 mix 8.6k miles
by Buzzinhalfdozen - 11/17/19 08:36 PM
MOPAR MO-285 FACTORY OIL FILTER CUT OPEN
by 53' Stude - 11/17/19 07:43 PM
Best Garage Door Seals
by Gebo - 11/17/19 07:18 PM
Bar oil as fogging oil
by WA1DH - 11/17/19 06:47 PM
Fram PH2 ExtraGuard Cut Open
by A310 - 11/17/19 06:38 PM
C&P Pentius UFXL PH16-equiv.
by 92saturnsl2 - 11/17/19 06:18 PM
Fleetguard WF2074 Coolant Filter Cut Open
by Pyrotechnic - 11/17/19 05:24 PM
Cuts on tire sidewall
by mclasser - 11/17/19 03:19 PM
Hyundai Theta II Engine in Newer Years
by smc733 - 11/17/19 02:41 PM
Walmart deals
by Deere John - 11/17/19 02:33 PM
leafuntec, wolf777, Smittyzzz, JimBobSeeker, Joey737
69902 Registered Users
61 registered members (2010Civic, 65convertible, Amkeer, Aichiguy, 77GrandPrix, 2015_PSD, 5 invisible), 889 guests, and 17 spiders.
Topics297,573
Posts5,118,294
Members69,902
Most Online3,589
Nov 2nd, 2019
What is this Oil's Application? #5194028 08/22/19 04:19 PM
MolaKule Offline OP
Global Moderator
Global Moderator
This type of lubricating oil has the following average Properties:
Kinematic [email protected] - 20.00 cSt
Base Number - 100
Pour Point - + 3.0C
Flash Point - 235C
Density - 58.1 Lbs/cubic foot (930 kg./cubic meter)
What might be the application for this lubricant??
This question is NOT open to Engineering disciplines, Tribologists, or Chemists.
"Dr. Larry Fleinhardt:
You know that it's considered unsolvable?
Charlie Eppes:
Well, certainly people who have failed to solve it might think that." From NUMB3RS
Re: What is this Oil's Application? [Re: MolaKule] #5194040 08/22/19 04:34 PM
skyactiv Online Content
Online Content
A very large ocean going vessel.
Sold: 13' VW GTI 3 door 6 speed manual
Me: 18' Elantra Sport 6 speed manual
Re: What is this Oil's Application? [Re: MolaKule] #5194045 08/22/19 04:45 PM
L
LotI Offline
L
Cooking.
A guess
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450 Cutaway
19 Buick Regal TourX http://www.fuelly.com/car/buick/regal_tourx/2019/loti/943992
Re: What is this Oil's Application? [Re: MolaKule] #5194070 08/22/19 05:18 PM
W
walterjay Offline
W
Lubricant for slides on machinery
(NA) Re: What is this Oil's Application? [Re: MolaKule] #5194087 08/22/19 05:40 PM
MolaKule Offline OP
Global Moderator
Global Moderator
Additional data Hint:
It is used mainly in large, two-cycle engines.
The fuels for these engines may contain anywhere from 1.5% to 4.5% sulfur.
Charlie Eppes:
(NA) Re: What is this Oil's Application? [Re: MolaKule] #5194116 08/22/19 06:16 PM
T
tomcat27 Offline
T
my first thought, even before your hint, was diesel locomotive. of course, I could be way off
2019 Cherokee, 2018 Jetta, 2014 Sentra, 2001 Camry, 1995 Escort, 1970 Cougar, 2013 XT250, 2010 Vstar, 2014 CTX1300
(NA) Re: What is this Oil's Application? [Re: MolaKule] #5194121 08/22/19 06:25 PM
Online Content
I don't know if I disqualify for studying diesels at Nashville Auto Diesel College, but it's the engine oil used for large ocean going vessels.
(NA) Re: What is this Oil's Application? [Re: MolaKule] #5194127 08/22/19 06:36 PM
sloinker Offline
Big slow moving ships diesels would be my guess.
'16 Tiguan TSI Ravenol VST 5W40
'15 VW Golf TDI Ravenol VMP 5W30
'15 VW Golf Sportwagen TDI VMP 5W30
'14 Dodge Grand Caravan 3.6 Red Line Blue Label 5W20
'64 Plymouth Fury440 Red Line Blue Label 10W40
(NA) Re: What is this Oil's Application? [Re: MolaKule] #5194150 08/22/19 07:01 PM
I
Imp4 Offline
I
Sounds like Vactra #4.
Way lube.
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
(NA) Re: What is this Oil's Application? [Re: MolaKule] #5194292 08/22/19 11:01 PM
Dylan1303 Offline
Oil for a big drill?
12 cruze rs 1.4t 6spd pp 5w30 tuned on 22psi
19 cruze auto 1.4t amsoil oe 5w20 tuned on 24psi
(NA) Re: What is this Oil's Application? [Re: MolaKule] #5194478 08/23/19 08:17 AM
L
Linctex Offline
L
Large ship engines running on bunker fuel oil.
Or - - also large I.C.E. power plants.
Getting VERY rare - but fit this description.
(NA) Re: What is this Oil's Application? [Re: MolaKule] #5195139 08/24/19 03:53 AM
Skippy722 Offline
I’m late but I’m going with way lube as well... something thick like a Citgo 220?
I do not miss that G&L horizontal boring mill at all shoot
2016 Chrysler 300S v6
2018 Dodge Grand Caravan GT
Slight Mopar obsession
(NA) Re: What is this Oil's Application? [Re: MolaKule] #5195283 08/24/19 09:15 AM
MolaKule Offline OP
Global Moderator
Global Moderator
Thanks for your responses!
Could it be used as a way lube? Possibly.
Those who guessed a lube for ocean vessel engines were spot on.
The high Base Number is required to combat the high amount of sulfur in the heavy fuel oil.
Shell Marine "Alexa" will have two lubricants available for ships that will be running 0.5% sulfur (BN=40) and 0.1% (BN=25) fuels in the near future, respectively.
Too much BN (alkalinity) and you run the risk of disrupting the cylinder liner's oil film, so there has to be just enough alkalinity to combat the percentage of acids produced during combustion.
Once again, "balance" is key here.
Charlie Eppes:
(NA) Re: What is this Oil's Application? [Re: MolaKule] #5196521 08/25/19 06:46 PM
G
Garak Offline
G
Now we're talking about "diesel" lubes that shouldn't be used in gassers. wink
Plain, simple Garak.
