Just about every member of this site has a slight obsession with oil / maintenance--some more than others, but it's all good. Consider yourself a member of a small percentage of the population that actually realizes that an automobile will probably last longer with attentive, routine maintenance. As for your oil choices, nowadays you can't really go wrong as long as you stay in spec, but you'll eventually develop an oil preference based on your own experiences. If I were you, I'd keep the oil you've already purchased, use them and if you observe something noteworthy, share your experiences with us. . . kinda like everyone else here does. Welcome!
Originally Posted by Mr_Luke
Originally Posted by ozric
You are over thinking things a bit. Any name brand 5w-20 synthetic will be just fine. None are too thin or too thick if your engine takes 5w-20. Don't obsess over the oil filter either
Good idea.
Thanks for all the responses.
I was afraid I'd be ridiculed but actually the replies seem very tolerable and also helpful.
I might as well stick with the 15 quarts of NAPA syn blend 5w20 and 5w30 I already bought.
I'm getting so I hate to bring oil back to Walmart or where ever and explain to them why I changed my mind about it again.
As per oil filters, I have Fram PH3614, Federated PG241F, and MC FL910S.
This oil and any of these filters should do a dandy job and I don't ever have to worry about it again.
It will probably do better than the average oil and filter.
