Originally Posted by samhainlimon
Thanks for the feedback kind sirs. All of the suggestions are important for me to double check. I appreciate it. I am systematically checking things off.
Your going to laugh but I think the problem might actually be that there is air in the cooling system. Although my coolant reservoir says it should be full. I read the following and it was eye opening
"The surge tank must be large enough to allow the air to separate as the coolant flows through it. Air in the system will then migrate to the area just below the radiator cap, again so that it will be forced out first if system pressure exceeds the radiator cap's rating." - OK I know that
" The surge tank should be filled to a level just below the inlet ports, as shown in the system diagram above." - OK Yes I did that
" The continual de-aeration that a surge tank provides can be a huge benefit to your overall cooling system. We already discussed all the bad things that happen when steam or air are trapped in the cooling system. In addition to those, consider that 2% air in the system results in 8% less heat transfer, but 4% air results in a whopping 38% less!!" - Didn't realize it was to that extent -
I read about it here from another site
http://www.pirate4x4.com/tech/billavista/Cooling/#LSCoolingSystems
Granted they are talking about high performance mods but they still explain the LS motor cooling system in detail.
I remembered that it seems like I was only able to get about 10qt of coolant in rather than the required 16+ after most recently replacing the radiator. I figured at the time maybe there is water in the system somewhere (wouldn't water mixed with coolant be better for cooling? It's bad for corrosion and freeze protection but I heard good for cooling )
Sooo.. I put a little more coolant in it when it was cool and I ran it under the same conditions. It ran much cooler only to 217 this time. It seems to have also sucked the coolant in and I don't think I lost it anywhere.
P10crew maybe your on to something. You mentioned "Did you fill the coolant while the system was under vacuum?"
My answer: I think so lol. I used the Chiltons manual and You Tube instructions they all seemed similar, with the motor running so the coolant pump appropriately moves the fluid. Is there something else? Maybe that could explain why. All good suggestions I'll keep checking and keep you posted. In the meantime. I'm slowly adding small amounts of coolant. She ran cooler today in 94 deg weather so hopefully that's it.
Eric O. / South Main Auto has a video on his youtube channel showing the vacuum filling system to fill the system with coolant .
Basically vacuums as much air from the system as possible & then use the vacuum to pull the coolant into the system .
