Originally Posted by SlavaB
What I was thinking about is that actually these numbers make sense - their 5w20 and 10w30 have less VII so the oil evaporates less as well (and both noack numbers are low), while lets say for PP 10w30 it's at 4.7 and PP 5w20 is almost 9 and it just doesnt correlate well in my head
Where did you get those noack values? The 5/20 and 10/30 have identical flash points so I would expect similar noack numbers, no? But you're saying they're really really different, almost by a factor of 2. Is it possible Pennzoils not using a (the same) 100% GTL base stock for both?...but then again they have nearly identical VI's, so that's probably not it. Are you 100% certain that 4.7 is correct for the 10/30??
That's what I've found here on bitog and people refer to it quite often
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4718980/Pennzoil_Platinum_and_Ultra_Pl
PPPP 0W-20: 10.8%
PPPP 5W-20: 8.6%
PPPP 5W-30: 10.1%
PPPP 10W-30: 4.7%
Weird...(I wasn't calling you a liar, just that 10/30 stuck out like a sore thumb). Pennzoil markets their PP using the same PurePlus GTL...so why the big difference in noack? I see your point... dunno, you got me my friend.🤔.. that's one for the formulators and since they never disclose that stuff, good luck getting an answer.
Fwiw... that 10w30 PP looks pretty darn good now! Talk about a hidden gem...
