Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
Help me understand
by 1978elcamino - 02/24/20 02:25 PM
2019 VW Passat Trip Mileage
by Boomer - 02/24/20 01:13 PM
Changed my ATF, difference is crazy!
by cwilliamsws6 - 02/24/20 12:36 PM
Specs on Conventional Oils 4 Comparing
by Perseus - 02/24/20 12:32 PM
Ford Edge owners chime in
by grampi - 02/24/20 11:49 AM
EarlT500, Newbie111, Boris_Be, NHR, zip15
70798 Registered Users
68 registered members (bbhero, asleepz, bdcardinal, apollo18, 8 invisible), 1,549 guests, and 20 spiders.
Topics301,894
Posts5,204,821
Members70,798
Is VW507 okay for flat tappets in EA 827? #5193352 08/21/19 08:06 PM
V
vavavroom Offline OP
V
Will VW 507 result in worse, comparable, or improved wear characteristics compared to VW 502 in an older VW engine with flat tappets? My concern is mostly regarding the cam lobes and tappets.
Re: Is VW507 okay for flat tappets in EA 827? [Re: vavavroom] #5193542 08/22/19 04:06 AM
O
Olas Offline
O
Look at the zinc/phos limits for both specs - if one is significantly lower than the other it will allow wear to occur more quickly than with the higher z&p.
Continue to use 502 if possible, or A3/B4 or A40 where 502 is not available.
Re: Is VW507 okay for flat tappets in EA 827? [Re: vavavroom] #5193599 08/22/19 06:21 AM
T
Trav Offline
T
This is the old 1.6 family and uses bucket under lobe not flat tappets that are commonly associated with high lobe contact pressures like those found on push rod engines and OHC engines that use a offset slipper to reduce lobe diameter operate multiple valves from a single lobe.
This engine uses full size lobes (1.1) in direct contact over the valve spring and has very low contact pressures on the cam lobes, wear on this type is not common unless the cam is defective (not hardened properly).
I read many times on here about flat tappets on engines with lower spring pressure not needing higher levels of zddp, this is incorrect, the rocker arm multiplies the force of the spring on the cam lobes, on OHC engines that use slippers to operate multiple valves from a single cam the stress on the lobe is dramatically increased and the use of a higher level of zddp may be beneficial.
You can run the 507 in your engine without concern of addition wear.
Re: Is VW507 okay for flat tappets in EA 827? [Re: Trav] #5199366 08/28/19 09:28 PM
V
V
I'm glad I asked. I thought bucket lifters were considered a type of flat tappets. Obviously, VW's have had hydraulic lifter for over 40 years. Olas brings up zinc and phosphorus. 507 is low-SAPS as fas I know. Is that a concern or not with bucket lifters/non-roller cams?
Re: Is VW507 okay for flat tappets in EA 827? [Re: vavavroom] #5199777 08/29/19 10:41 AM
O
Olas Offline
O
Based on Travs post your cam won't suffer unless it wasn't properly hardened during manufacture. If that is the case no oil will save it.
Use your favourite brand that meets the specs in the owners manual.
Re: Is VW507 okay for flat tappets in EA 827? [Re: Trav] #5199779 08/29/19 10:43 AM
O
Olas Offline
O
Trav you typed 'bucket under lobe' but the pedant in me wants to say it was bucket under shim under lobe (pre 86 hydraulic switchover, of course..)
Re: Is VW507 okay for flat tappets in EA 827? [Re: Trav] #5199862 08/29/19 12:32 PM
Duffyjr Offline
I have to ask, what is the least amount of zinc and phosphorus you would recommend running in a stock flat tappet engine?
89 GMC Sierra Advanced 5w30/51036 Wix
08 Lucerne CX Advanced 5w30/1040 Gold
18 Toro Super Recycler T5 10w30
