Originally Posted by d00df00d
Originally Posted by OilUzer
Originally Posted by weasley
And, once again, the caveat from the Lubrizol comparison chart has to be highlighted:
Originally Posted by "Lubrizol"
NOTE: These performance charts are primarily designed to demonstrate performance within the same industry specification, for example, ACEA E6 versus ACEA E7, or API CH-4 versus API CJ-4. This tool has not been expressly designed to show relative performance between different specifications.
Does this mean using this graph to compare a3/b4 with a5/b5 is like comparing apples and oranges ... or it sounds like it is ok since both specs are within the same industry? No?
A3/B4 vs. A5/B5 should be fine.
A3 vs. C3 would be sketchy.
A5 vs. dexos1 would be meaningless.
Also is 10 a grade meaning good or does it mean high (i.e. bad)?
High score means good.
Thanks.
Don't know why I was having difficulty with 10 being good or bad. should have looked at 10 (or a higher number) as something better ... as you have explained.
I was looking at everything collectively and thinking:
Lower wear or sludge, etc. is good so a number near 10 represents lower/less of something.
I was then applying the same rule to the fuel economy and thinking high number means lower/less fuel economy ... maybe I was distracted or had a brain frat!
Maybe they should add "protection" to it. e.g. wear protection, sludge protection, etc.
Thanks.
