Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
Help me understand
by 1978elcamino - 02/24/20 02:25 PM
2019 VW Passat Trip Mileage
by Boomer - 02/24/20 01:13 PM
Changed my ATF, difference is crazy!
by cwilliamsws6 - 02/24/20 12:36 PM
Specs on Conventional Oils 4 Comparing
by Perseus - 02/24/20 12:32 PM
Ford Edge owners chime in
by grampi - 02/24/20 11:49 AM
EarlT500, Newbie111, Boris_Be, NHR, zip15
70798 Registered Users
75 registered members (bbhero, asleepz, bdcardinal, apollo18, 7 invisible), 1,570 guests, and 20 spiders.
Topics301,894
Posts5,204,818
Members70,798
Mobil Super or Mobil 1 #5193265 08/21/19 06:34 PM
8
80Boxcar Offline OP
8
What is the difference between Mobil Super Synthetic and Mobil 1?
Re: Mobil Super or Mobil 1 [Re: 80Boxcar] #5193266 08/21/19 06:37 PM
danez_yoda Offline
For a daily driver, for all practical purposes, nothing. Super just north of a semi-synthetic. M1 is just south of a true synthetic. smile
If you're not doing hard driving or 10K plus OCIs either would work fine.
[Linked Image]
Re: Mobil Super or Mobil 1 [Re: 80Boxcar] #5193279 08/21/19 06:48 PM
dave1251 Offline
OP welcome thank you for joining. What vehicle would you use either oil in?
don't use.
Re: Mobil Super or Mobil 1 [Re: dave1251] #5193293 08/21/19 07:06 PM
8
80Boxcar Offline OP
8
09 WRX. 117K. No engine mods
Re: Mobil Super or Mobil 1 [Re: 80Boxcar] #5193492 08/22/19 12:22 AM
T
tahoe_hybrid Offline
T
just get the full synthetic
not the super one if you go to walmart and use the mail in rebate you can get the full synthetic for 11 dollars plus tax so about 24$ or 12.50 after rebate...
I suggest buying 4 at a time so you can get 4 rebates as it's expiring soon
they also offer 17$ back if you get the filter+oil so the filter will be 17$ ea after rebate.. with the filter
I used it in my chevy impala Wbody it got it to 180,000 miles with Zero problem to the engine
Re: Mobil Super or Mobil 1 [Re: 80Boxcar] #5193495 08/22/19 12:35 AM
ChristianReske Offline
Mobil Super Synthetic is labeld "HC (Hydrocrack) Synthese" here in Germany,
Mobil 1 Extended Performance is labeld "SHC ((Full) Synthetic + Hydrocrack) Synthese" here.
For a DD, Mobil Super is surely more than good enough.
Re: Mobil Super or Mobil 1 [Re: 80Boxcar] #5193497 08/22/19 12:43 AM
SlavaB Offline
Welcome!
Between those 2 just get a M1 - you still can get an instant $5 off for your Walmart purchase here https://mobiloil.com/en/promotion/mobil-promotions/hot-wheels
And then submit for a $12 rebate (which will take like 8-12 weeks to arrive) here https://mobiloil.com/en/promotion/mobil-promotions/mobil-1-rebate-2019
Locals of bitog have stashes of M1 these days smile
Another good oil will be Castrol Magnatec - has plenty of excellent UOA and I've seen other WRX owners here give it a try
17 Kia Sportage EX 2.4 GDI / Castrol Magnatec 5w30, OEM filter
15 MB GLA250 4Matic 2.0T / Mercedes OEM 5w40, OEM filter
Re: Mobil Super or Mobil 1 [Re: 80Boxcar] #5193500 08/22/19 01:08 AM
M
Mad_Hatter Offline
M
It's hard to get numbers out of XOM but they market Mobil Super Syn as a intermediary between M-Super (a syn blend) and their top M1 product line. My guess would be in the base stock (M1 using a grp3+??) and add pk (higher qlty VII's?). But from a consumer standpoint with a daily driver...not much.
Weird thing is Mobil Super Syn is often more expensive than M1.
Re: Mobil Super or Mobil 1 [Re: Mad_Hatter] #5193529 08/22/19 02:41 AM
4WD Offline
Weird thing is Mobil Super Syn is often more expensive than M1.[/quote]
Familiar bottle … Wonder if that’s a twin for some of the past AC Delco
Re: Mobil Super or Mobil 1 [Re: 80Boxcar] #5193535 08/22/19 03:39 AM
8
80Boxcar Offline OP
8
The reason I ask is because I'm normally a Mobil 1 user but the shop I work at is getting a deal on super syn @ $2.89 qt in bulk. I'll make the switch because the savings.
Alot of the Subie owners use Motul or Redline. I just can't see shelling out $79.00 for an oil change for a daily driver with some spirited driving.
I am still a novice at the different types of syn oils and pretty much thought that if the label said full syn then it was full syn. I just get lost with the different brands and prices. Menards usually sells Quaker State syn for $2.99 qt after rebate. I don't understand the drastic difference in prices among the brands.
Re: Mobil Super or Mobil 1 [Re: 80Boxcar] #5193606 08/22/19 06:36 AM
T
tig1 Offline
T
M1 is their higher quality product. Is your ride worth a quarter more a week using M1?
2007 Ford Fusion 253,000 miles
M1 5-20HM
2017 Ford Fusion 86K
M1 0-20EP
M1 ATF and M1 LV HP ATF
M1 10-30 in all OPE
MC filters
Re: Mobil Super or Mobil 1 [Re: 80Boxcar] #5193620 08/22/19 06:52 AM
W
WyrTwister Offline
W
When we purchased our 2015 Sonic , I discovered it requires DEXOS spec oil . Found the Super Synthetic on sale at AAP . Next time I bought Mobil 1 . This switched back and forth , depending on sales . I have also used one of the Pennzoil synthetic DEXOS , and now using NAPA synthetic DEXOS .
This is my Wire's daily driver . Figured , as long as it was a DEXOS spec " full " synthetic , I was going more with price .
Been ordering filters from RockAuto 6 or 12 at a time to spread out the freight cost .
Wyr
God bless
Re: Mobil Super or Mobil 1 [Re: 80Boxcar] #5193680 08/22/19 07:53 AM
T
The_Nuke Offline
T
Your confusion is understandable and justified. It all boils down to what “synthetic” means when referring to engine oil. Some brands have a differing opinion on that, and they formulate their synthetic oils accordingly.
You will be fine with the Mobile Super Synthetic oil, as long as you do not try to push it past it’s mileage limit in each OCI, but that is the case with every oil.
2012 Charger Pursuit aka "The Bacon Hauler"
- 5.7L + NAG1 (A5) + 2.65 (215mm)
Re: Mobil Super or Mobil 1 [Re: 80Boxcar] #5193722 08/22/19 09:02 AM
dave1251 Offline
The one which costs less will be good for the factory recommended OCI the engine won't know the difference.
don't use.
Re: Mobil Super or Mobil 1 [Re: 80Boxcar] #5194048 08/22/19 04:49 PM
8
80Boxcar Offline OP
8
I usually change oil @ 3K in all my vehicles no matter the type of oil. I just can't stand the thought of the dirty dark oil sloshing around the crank case.
Some of these OEM OCI just freaks me out. I have seen a number of GM 2.2, 2.4, 3.6, etc.. with broken timing chains and solids under the valve covers.
