belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
Help me understand
by 1978elcamino - 02/24/20 02:25 PM
2019 VW Passat Trip Mileage
by Boomer - 02/24/20 01:13 PM
Changed my ATF, difference is crazy!
by cwilliamsws6 - 02/24/20 12:36 PM
Specs on Conventional Oils 4 Comparing
by Perseus - 02/24/20 12:32 PM
EarlT500, Newbie111, Boris_Be, NHR, zip15
70798 Registered Users
57 registered members (bbhero, Arob, Bailes1992, apollo18, 7 invisible), 1,440 guests, and 21 spiders.
Topics301,895
Posts5,204,840
Members70,798
Caliper Recommendations for 2002 Tacoma #5193243 08/21/19 06:14 PM
M
madibob Offline OP
M
My 2002 4x4 Tacoma needs new calipers as they are currently starting to stick and drag on the rotors (front wheels don't spin freely). I know there are kits to rebuild them, but with 235K miles and rust from Minnesota winters, I'm afraid that might not be worth it. The Toyota OEM calipers are pushing $300 each. Rockauto has a few but unsure which brand would be best....I don't mind paying for quality. I read NAPA has rebuilt OEM calipers, but I haven't had the best of luck with NAPA parts.
Any recommendations?
2015 Porsche Boxster S
2002 Toyota Tacoma 3.4L 4X4
2000 Ford F350 7.3L 4X4
Re: Caliper Recommendations for 2002 Tacoma [Re: madibob] #5193247 08/21/19 06:17 PM
5
50jeffrey Offline
5
Uh, all rebuilds are from OEM cores.
Re: Caliper Recommendations for 2002 Tacoma [Re: madibob] #5193249 08/21/19 06:18 PM
SatinSilver Offline
Get the Raybestos Opti-cal calipers. They are new, not rebuilt and no core charge.
Re: Caliper Recommendations for 2002 Tacoma [Re: SatinSilver] #5193259 08/21/19 06:28 PM
M
madibob Offline OP
M
Are these now called the ELEMENT3 calipers?
https://www.brakepartsinc.com/raybestos/products/calipers/element3-calipers.html
Re: Caliper Recommendations for 2002 Tacoma [Re: 50jeffrey] #5193261 08/21/19 06:30 PM
Y
Y_K Offline
Y
That's a marketing claim we take on face value too often. In my experience with several of those for Land Cruisers, they were cheap castings from a Chicom molds knock-offs. one was not even fitting right. Tried a few times: correct casting numbers and all that, but you could see a horrible metallurgy from a mile. Some boots were dislocated, some were not polished, etc. Various 'brands', including the ones that swear they use OE cores.
Just a warning. NAPA Eclipse line was OK. Or a rebuild from a dealer is a second best choice aside from a new one.
Deal locally only. I made a mistake ordering from Rock once. Was stuck with a wrong part and it took a week of emailing back and forth with pictures and measurements to prove that the part was defective. The same happened once with a defective/wrong rotor: correct part number with a wrong hat height dimensions. One out of four was wrong and it had scuff marks from a previous customer also trying to fit the wrong part on his vehicle.
Re: Caliper Recommendations for 2002 Tacoma [Re: madibob] #5193264 08/21/19 06:33 PM
SatinSilver Offline
Yes, that's them. They must have changed the name recently. Rockauto carries them for the 05 Matrix but I didn't see them for the 02 Tacoma. But I had to guess on the trim level.
Re: Caliper Recommendations for 2002 Tacoma [Re: madibob] #5193277 08/21/19 06:47 PM
Sam_Julier Offline
I would have them restored at either Goldline Brakes or PMB Performance. I have had excellence service and product from both places.
You might also consider buying a set of calipers from a Toyota dismanteler in a dry/no salt part of the country and having them shipped to Goldline or PMB. This is what I did for the Volvo 240 calipers I had restored at Goldline.
2013 Toyota Avalon Hybrid TGMO 0W20, 81k
1993 Volvo 245 T5 10W30, 168k
1993 Volvo 244 T5 10W30, 177k
Re: Caliper Recommendations for 2002 Tacoma [Re: madibob] #5193281 08/21/19 06:52 PM
02SE Offline
Quite a few people with first gen Tacoma's and 3rd gen 4Runner's, like to do the 1st gen Tundra brake mod. Which consists of either the 199 mm rotors and calipers, or the more popular 231 mm rotors and calipers from a 1st gen Tundra, swapped onto their Tacoma or 4Runner.
If you have 15" wheels you'd have to upgrade to at least 16's to fit the larger rotors and calipers, and in some cases 17" wheels.
Re: Caliper Recommendations for 2002 Tacoma [Re: Sam_Julier] #5193297 08/21/19 07:09 PM
Y
Y_K Offline
Y
yes, Goldline are semi-local to me and they make the rebuilt calipers better than new ones
Re: Caliper Recommendations for 2002 Tacoma [Re: madibob] #5193299 08/21/19 07:13 PM
The Critic Offline
New calipers from the dealer, not the Chinese ones.
All of the rebuilt ones are a crapshoot.
2011 Toyota Prius 1.8L - 206K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 144K - Valvoline Premium Blue Restore 10W-30
Re: Caliper Recommendations for 2002 Tacoma [Re: madibob] #5193339 08/21/19 07:40 PM
N
NASTI Offline
N
I've had good luck with Cardone Ultra Premium rebuilt calipers and the Raybestos ELEMENT3 new calipers on family and friend vehicles. Unlike most store brand calipers, they are both coated to prevent weather corrosion and function well.
2005 Subaru Impreza WRX STI
2015 Audi S3
2008 Lexus RX350
2000 Lexus ES300
Re: Caliper Recommendations for 2002 Tacoma [Re: madibob] #5193546 08/22/19 04:15 AM
J
joegreen Offline
J
I think the rebuilt ones are a rebuild of whatever core gets returned. If an oem gets returned it's an oem rebuild if a Chinese caliper gets returned they rebuild the Chinese caliper.
1978 Chevrolet k20
Engine: Delo 10w30xle
Transmission: Castrol transmax dex/merc
1984 Mercedes-Benz 300 turbo diesel
Engine: Delo 400 15w40le
Re: Caliper Recommendations for 2002 Tacoma [Re: madibob] #5193581 08/22/19 05:39 AM
Donald Offline
The postage for returning a core can be hefty. For an old Suburban it was more than the core was worth.
Rebuilding a caliper is not like rebuilding an engine. Its pretty straight forward. New seal & piston, after its cleaned & honed.
2015 Ford F-250 w/Powerstroke
Re: Caliper Recommendations for 2002 Tacoma [Re: madibob] #5193856 08/22/19 11:38 AM
Yah-Tah-Hey Offline
Find some later model Tacoma units that will work and rebuild them. There really isn't that much to a caliper.
Re: Caliper Recommendations for 2002 Tacoma [Re: madibob] #5193882 08/22/19 12:26 PM
N
nthach Offline
N
If you can afford them, new from the dealer. All the reman ones are a crapshoot. Recently, I've gone through 2 calipers for a now-junked Mitsu and an ex-friend's Tahoe.
Otherwise, rebuild the OEM caliper.
