Originally Posted by 04CorCar
Hello,
I recently purchased a 2004 Toyota Corolla with only 85,000 miles on it. I bought it for a good price sight unseen and it runs great. I replaced the spark plugs, water pump, thermostat, coolant, brake pads, rotors, etc. My goal for this car is to have a reliable gas saver as my only car.
Here is the problem, when I went to change the oil and took off the fill cap, I noticed some sludge. When changing the oil, it came out very dark, pretty much black. I have no idea what kind of oil it was but I'm assuming cheap stuff. So I put in Penzoil High Mileage 5W-30.
So what I've decided is to pull the valve cover and oil pan, clean it as best as I can by hand and do an oil change after about 100 miles, then maybe 500 miles, etc?
The question is, with all of the above considered, what would be the best way to go about removing the sludge? I'm driving to move cross country at the end of the year and then will be using the car to get to and from work.
Thank you!
If the spark plugs looked OK and the rest of the car is in good condition, I would not bother with a high mileage oil. My Tacoma has 155k miles and runs like new (no leaks and no oil consumption), so I don't plan on using a high mileage oil until I have good reason.
About potential engine sludge, I would keep an eye on the first oil change and if the dipstick gets dark quickly, go ahead and change it early (3k miles or so?). Some will say to just change the oil filter and leave the oil, which you can do also because most of the "bad stuff" will get caught in the filter. Just be sure to top off the oil after replacing the filter. I still think it's a better idea to do the full service with fresh oil and filter. I don't think you would need to short change the oil more than once, again assuming the spark plugs and everything else looks fine. Good luck.
