belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
Help me understand
by 1978elcamino - 02/24/20 02:25 PM
2019 VW Passat Trip Mileage
by Boomer - 02/24/20 01:13 PM
Changed my ATF, difference is crazy!
by cwilliamsws6 - 02/24/20 12:36 PM
Specs on Conventional Oils 4 Comparing
by Perseus - 02/24/20 12:32 PM
EarlT500, Newbie111, Boris_Be, NHR, zip15
70798 Registered Users
58 registered members (Arob, apollo18, A_User55555, alcyon, aleneros, 8 invisible), 1,460 guests, and 20 spiders.
Topics301,895
Posts5,204,831
Members70,798
Motorcraft 5w30 synthetic blend SN+ #5193165 08/21/19 04:37 PM
M
mpgo4th Offline OP
M
I sent a sample to Carter Cat labs for VOA. I feel like these results are not true. Isn't a V100 of 13.8 a 40w? [Linked Image]
Re: Motorcraft 5w30 synthetic blend SN+ [Re: mpgo4th] #5193178 08/21/19 04:53 PM
I
Imp4 Offline
I
SAE 30 is <12.5 cSt at 100C.
SAE 40 is <16.3 cSt at 100C.
Per SAE J300.
Maybe the results are true and your oil is heavier than you thought.
Maybe the results are false and the lab bungled the analysis.
Who knows?!?!?
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
Re: Motorcraft 5w30 synthetic blend SN+ [Re: mpgo4th] #5193218 08/21/19 05:43 PM
T
typ901 Offline
T
Re: Motorcraft 5w30 synthetic blend SN+ [Re: Imp4] #5193251 08/21/19 06:21 PM
M
mpgo4th Offline OP
M
Per SAE J300.
Who knows?!?!?
I know something is wrong. I poured it myself from a sealed motorcraft quart.
Re: Motorcraft 5w30 synthetic blend SN+ [Re: mpgo4th] #5193305 08/21/19 07:18 PM
I
Imp4 Offline
I
Per SAE J300.
Who knows?!?!?
The fact that you poured it yourself from a sealed Motorcraft quart is both true and irrelevant.
The original question that you posted was around the VOA viscosity analysis results.
Right now you have no idea if the oil is thicker than expected or if the analysis was goofed.
Re: Motorcraft 5w30 synthetic blend SN+ [Re: Imp4] #5202292 09/01/19 06:11 PM
dave1251 Offline
Per SAE J300.
Who knows?!?!?
I go with the later.
don't use.
Re: Motorcraft 5w30 synthetic blend SN+ [Re: mpgo4th] #5202333 09/01/19 06:58 PM
M
Mad_Hatter Offline
M
I'd call them and make them re run it...I'm surprised that 100c value wasn't flagged because that's clearly an SAE40 value (-and also, i don't believe SAE40 can be RC, which this MC oil is labeled as such).
Curious, do you have a 40c value to compare it to PQIA?
