Back in the days I used a router with panel antenna to connect to a regular wifi access point (like home router) over about 100m in suburb type of environment. Antenna itself is like 50 bucks. It worked well
Originally Posted by dlundblad
Originally Posted by mk378
Is there a window on the side facing the house? If there is you could place an indoor router in the window.
There is. Here's a couple actually.
What would the router be talking to from the house?
But, the question would be whether you get strong enough wireless signal at the window in the barn from the main house. If not, I'd still go with getting two of these and putting one in each window pointed at each other.
That one is sold individually but you can buy sets of two that the seller pre-configured to link with each other.
Each unit also requires a power supply that sends power through the Ethernet cable to run the Nanostation. That way you only need to install an Ethernet cable on the outside of the house. In most cases it is included but some do not. The only way these CPE will run is with power through the Ethernet cable, there is no separate power input on the unit.
This one needs to be connected with a PoE (Power over Ethernet) LAN cable. https://www.amazon.com/EnGenius-directional-long-range-N-ENH500-KIT/dp/B007ZDC64I/ref=sr_1_1?keywords=EnGenius+Technologies+Long+Range+11n+5GHz+Wireless+Bridge%2FAccess+Point+%28ENS500%29+supports&qid=1566514142&s=electronics&sr=1-1
There are lots of companies making these point-to-point solutions. Ubiquiti has been around for about 15 years and they're at the top of the pile of affordable consumer brands.
