I found this: https://bit.ly/2NmOGOT to be an interesting article, but I do have a question.
The writer makes, what *I* think is, a blanket statement, "Enthusiasts already know (or should know) that older performance engines require oils with elevated zinc and phosphate (ZDDP) levels. The reduced levels of ZDDP in current API SN engine oils demand that those with older performance engines use a different, more targeted, hot rod-style engine oil."
We, here at BITOG know, that some oils are very high in ZDDP (for example, Toyota Genuine Motor Oil - 0W-20, correct?), so I think it's "old-school" to poo-poo more modern oils just because you have an "older performance engines" and/or because you think the oil is too thin (which is, I think, what the writer is implying)?
Ed
Ed
