Timken Rear Wheel Bearing - Any Good?
by Delta - 02/28/20 02:47 PM
121k 2011 GMC Terrain 2.4 ~ PP 6250 miles
by Matt1980 - 02/28/20 02:42 PM
Mopar coolant alternative?
by ram_man - 02/28/20 02:38 PM
Old (but new) filters
by RF12 - 02/28/20 01:54 PM
5.3 DOD/AFM Delete - Looking for LS Advice
by RoadDukie - 02/28/20 01:47 PM
Help picking battery powered mower
by Huie83 - 02/28/20 01:41 PM
Can I use 75w instead 70w gear oil?
by Polyalphaolefin - 02/28/20 11:57 AM
Alternative to Unaffordable New SUV?
by Fitz98 - 02/28/20 11:24 AM
What is this??
by DriveHard - 02/28/20 09:45 AM
Ultimax 18" Build
by DriveHard - 02/28/20 09:42 AM
spray paint the wheel bead
by CNT - 02/28/20 09:40 AM
'What car should we get...'
by wings&wheels - 02/28/20 09:30 AM
Free entertainment at the gas station.
by Chris142 - 02/28/20 09:17 AM
Using Redline SL-1 as a Maintenance Dose
by Boomer - 02/28/20 09:08 AM
Oil changed yesterday on F150
by redhat - 02/28/20 07:30 AM
Intel or AMD Processor
by ZeeOSix - 02/28/20 04:02 AM
ABchevy, RAOD, MichaelTx, duesenberg, Shevretti
70825 Registered Users
103 registered members (2K2AcuraTL, aquariuscsm, askani79705, ABchevy, ArrestMeRedZ, 53' Stude, 11 invisible), 2,155 guests, and 16 spiders.
Topics302,046
Posts5,207,977
Members70,825
Page 1 of 4 1 2 3 4
Meguiars Hyper Dressing #5192789 08/21/19 08:46 AM
B
buster Offline OP
B
Ordered a gallon of this. Will make it simple for both cars. I never gave this stuff much thought but I should have. I’m done with the idea that you can “protect” plastic to the degree many of these products claim. With that said, spray and go is what I’m after. 83% positive review rating on Amazon.
2019 Frontier Pro 4X - RGT 5w30
2019 Impreza Sport - OE fill
Re: Meguiars Hyper Dressing [Re: buster] #5192820 08/21/19 09:38 AM
A
atikovi Offline
A
Like that ad for hot sauce says, I put that shet on everything.
Tires
[Linked Image from fototime.com]
Engine
Bedliner
Interior
The only problem being that it's water based is that it doesn't last long on the exterior if you get much rain.
Re: Meguiars Hyper Dressing [Re: buster] #5192827 08/21/19 09:48 AM
B
buster Offline OP
B
Nice! You are right but you know I thought more about it and none of these products last as long as they claim so I went with “easy”. Plus you can change the ratios so that is a big plus.
Re: Meguiars Hyper Dressing [Re: buster] #5192906 08/21/19 11:33 AM
ls1mike Offline
Hmmm, I'm interested I may have to try it.
Mike
00 Trans Am WS6 5.7 LS1
17 Silverado 3500HD 6.0
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: Meguiars Hyper Dressing [Re: buster] #5192907 08/21/19 11:36 AM
E
Ed_Flecko Offline
E
To me, this product is a waste of my time and money. From their own description, https://bit.ly/2MrKAoV , all it does is purely cosmetic.
I like 303 much better because it not only makes the surface looks good...it protects!
Ed
K-9s teach the suspect that if you run...you'll only be arrested tired.
Support YOUR local law enforcement K-9 Unit!
https://www.ssdk9.com/
Re: Meguiars Hyper Dressing [Re: ls1mike] #5192920 08/21/19 11:52 AM
B
buster Offline OP
B
It’s a great product. Gets very good reviews on Autopia and AutoGeek.
I use 303 as well but under the engine Hyper Dressing is easier. Less wiping and settles better.
303 does have better UV protection though.
Re: Meguiars Hyper Dressing [Re: Ed_Flecko] #5193103 08/21/19 03:08 PM
The Critic Offline
Ed
Dressings offer very little protection. Most of the UV protection stems from the "sheen" which deflects UV rays.
2011 Toyota Prius 1.8L - 206K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 144K - Valvoline Premium Blue Restore 10W-30
Re: Meguiars Hyper Dressing [Re: buster] #5193107 08/21/19 03:13 PM
B
buster Offline OP
B
That is true.
Re: Meguiars Hyper Dressing [Re: Ed_Flecko] #5193115 08/21/19 03:20 PM
R
Reddy45 Offline
R
Ed
Ditto. 303 is proven and also can be buffed to a neutral and non-slick sheen.
Re: Meguiars Hyper Dressing [Re: buster] #5193148 08/21/19 04:07 PM
B
buster Offline OP
B
I'll let you know how it compares to 303. I've been using 303 in the engine bay for the last several years. It does the job.
I've also used Sonus Motorkote, which is specifically designed to handle the higher temps of an engine bay, something 303 and Hyper Dressing don't do all that well. None of these products last that long in my experience under the hood. I also don't think any of them "protect" as well as they claim. It therefore comes down to ease of application and desired look.
Sonus Motorkote
Re: Meguiars Hyper Dressing [Re: buster] #5194184 08/22/19 07:47 PM
B
buck91 Offline
B
I like M40 for general plastic/rubber/vinyl work. Does the Hyperdressing offer anything other than economy compared to M40?
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: Meguiars Hyper Dressing [Re: buck91] #5194459 08/23/19 07:42 AM
B
buster Offline OP
B
The M40 is a good product. Hyper Dressing's claim to fame is it's versatility, and ease of application. You can also dilute it. Being it is water based, which is both a positive and a negative depending on how you look at it (washing off in some ways is good as it doesn't stain rubber tires etc.).
Hyper Dressing lays to a perfect finish in the engine bay. Requires no buffing at all. You spray it on a dry or wet engine and walk away. Done.
I've ordered a small bottle of Polish Angel Engine. This stuff goes on amazingly well. I tested some last night on the exterior trim and we ended up getting rain last night. No water spots. It smells incredible and leaves a beautiful matte finish. A little goes a looong way with this stuff. It has oils in it that protect the rubber and plastic surfaces. It's expensive and overkill for most cars, including my own, but I wanted to try it.
As of now the top engine bay products I feel are:
303 Aerospace
Sonus Motorkote
Polish Angel Engine
….in no particular order.
Re: Meguiars Hyper Dressing [Re: buster] #5194462 08/23/19 07:45 AM
B
billt460 Offline
B
I'm going to have to try that. I just finished cleaning and detailing all 3 of my vehicles. (They had not been touched since before we started our move, and they all needed attention both inside and out). I had a can of aerosol Armor All Outlast Tire Dressing that was almost full. I started to apply it, and the spray nozzle just quit. I'm sick of this happening to aerosol car care products, and as a result I'm done with them.
From now on if it's not a pump spray or pour out, I'm not buying it. That stuff was expensive, and it P.O.'d me to have to toss it. So I ended up finishing the tires with regular Armor All Protectant. (Not the best, but better than nothing). The Meguiar's "Hyper Dressing" looks to perform well. Not too dull, and not too shiny. My new Toyota has more interior plastic than a recycling center.
Re: Meguiars Hyper Dressing [Re: billt460] #5194471 08/23/19 08:04 AM
B
buster Offline OP
B
Hyper Dressing is quite remarkable in it's applicability. Probably the best of any product. You dilute it depending on the level of gloss you want. OEM look is more like 4:1. It spray it liberally to the entire engine and walk away. That's what is so great about it. Based on what you're telling me that is what I think I would go with. I have a gallon of it. It can go a long way.
Re: Meguiars Hyper Dressing [Re: buster] #5194510 08/23/19 09:11 AM
PimTac Offline
You must have a garage filled with partially used bottles of assorted stuff.
2017 Mazda CX5
Valvoline Advanced Synthetic 0w20
Roki OEM filter.
Page 1 of 4 1 2 3 4
