I have installed several over the years (Aisin kits) and never had a problem. On another auto forum, someone just posted to avoid Mitsuboshi timing belts because he had two that broke on him. I know Mitsuboshi makes some of their TB's in Thailand. Is it possible the Thai belts are inferior to the ones made in Japan? I am not a mechanic but have read extensively about timing belt quality and failure modes over the last 20 years or so. I can not recall a single case where a relatively new timing belt failed on its own. Failures are always a result of a faulty tensioner, WP or idler bearing. The only belt failures I ever heard about were ones with ridiculously high mileage, ie 200k +/-.
So, would you guys hesitate to install a Mitsuboshi timing belt? Thanks.
