wix 2019 sienna oil filter cartridge fitment
by s2krunner - 02/23/20 02:19 PM
Urban Carry G3
by Gebo - 02/23/20 02:16 PM
Denso Iridium TT's are great
by jayjr1105 - 02/23/20 01:46 PM
Girl Scout question
by ffhdriver - 02/23/20 01:36 PM
MTD Snowblower issues
by 97prizm - 02/23/20 01:19 PM
OBD scanner
by NH73 - 02/23/20 10:18 AM
Oil additive and effects on oil analysis results
by MoneyJohn - 02/23/20 09:48 AM
More 6.7 PSD engine repairs
by mattd - 02/23/20 09:10 AM
How to get sediment out of heater oil tank?
by BAJA_05 - 02/23/20 08:37 AM
Oil Prices in Europe
by BBDartCA - 02/23/20 08:08 AM
Fury -Wilder 3?
by pbm - 02/23/20 06:41 AM
toro super recycler
by passgas55 - 02/23/20 06:05 AM
Chain style for ag tires
by puma4440 - 02/23/20 04:25 AM
2014 GMC Terrain 2.4L AWD
by Char Baby - 02/23/20 02:06 AM
Conventional VS Synthetic In The Winter Months
by BlueOvalFitter - 02/23/20 01:36 AM
Paint Splatter
by rrretiree7 - 02/23/20 12:54 AM
Lucase483, Chaucha, UofA, Jeffrey78, Markovchain
70788 Registered Users
103 registered members (alchargo, atikovi, 67ZL1, AZjeff, 74Widebody, 12 invisible), 2,657 guests, and 16 spiders.
Topics301,831
Posts5,203,563
Members70,787
P0455 Large evap leak on my G35 #5192578 08/20/19 10:49 PM
B
bowlofturtle Offline OP
B
So i've been battling this evap leak for the last 2 years or more. Yes, i know i'm throwing parts at it.
CEL comes and goes. Sometimes i clear the fault and after a drive cycle it comes back and sometimes it doesn't come back for 3 months and it passes readiness monitors.
This leads me to believe its like a part that not fully sealing when it should be. Goings on the forums a large leak means its likely the vent valve that is on the canister. Most people report that to be the fix.
1. I buy new OEM gas cap, cheap $20 item.
2. I grab a used whole canister assembly. Came with vent valve as well.
3. Bought a Autozone purge valve, that sits near the engine bay.
I did all of these and spaced them out and i still have this fault. This somewhat leads me to believe it could be a broken vac line or something harder for me to find. I have a state emission, its only OBD2 check coming up next month and go figure car wants to constantly fail. Looking for a few more hail marys before i take it to the shop.
My toys
-05 Infiniti G35x 140k
-03 Suzuki SV650N 8.5k
Maintaining
-16 Jetta 1.4T 20k
-98 Nissan Maxima 160k
-09 Toyota Camry V6 96k
Re: P0455 Large evap leak on my G35 [Re: bowlofturtle] #5192600 08/21/19 12:07 AM
M
mehullica Offline
M
I have seen quite a few cracked fuel filler hoses at the Infinity dealer next door to my dealer.
Re: P0455 Large evap leak on my G35 [Re: bowlofturtle] #5192601 08/21/19 12:10 AM
chemman Offline
Since you live in a metro area where I'm sure lots of salt is used in the winter, what about rust around the filler neck where you put gas in? Also, what mehullica said.
92 Olds 88 Hav 5w30 PL/L24011
99 Buick Century Hav 5w30 PL/L24011
99 Silverado 5.3L Hav 5w30 PL/L25288
04 TrailBlazer 4.2L Hav 5w30 PL/L25288
Re: P0455 Large evap leak on my G35 [Re: bowlofturtle] #5192612 08/21/19 02:09 AM
M
Mad_Hatter Offline
M
Have you checked the fuel tank pressure sensor?
It’s part of the evap system and reads pressure in the fuel system to detect evaporative leaks. When the sensor detects a leak, or if the sensor itself fails, you'll get a CEL.
Re: P0455 Large evap leak on my G35 [Re: bowlofturtle] #5192652 08/21/19 05:36 AM
Char Baby Offline
Right, I start with the gas cap too and then follow the filler tube to the tank & surrounding tubes on the fill tube. You may have some rotted tubing going to the top of the gas tank where you can't see them.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: P0455 Large evap leak on my G35 [Re: bowlofturtle] #5192663 08/21/19 05:54 AM
T
Trav Offline
T
Instead of throwing parts at it invest in a cheap smoke tester, you can find them for less than $150. While not the best they work okay and you will find the leak, sell it on ebay later if you don't want want to keep it.
https://www.amazon.com/STINGER-Smok...&hvtargid=pla-570590603233&psc=1
Re: P0455 Large evap leak on my G35 [Re: bowlofturtle] #5192709 08/21/19 07:20 AM
R
Rolla07 Offline
R
Bah..if u have a good indy Id bring her in for diagnosis at the minimum. I had similar issue and it ended up being a sensor that sends unburnt fuel back to the charcoal canister...cheap fix that I would not have been able to figure out myself...i did replace my gas cap 1st but stopped short of canister swap..$$. It was on a different car though, but just sayin.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
2015 Toyota Venza Parisian Blue Pearl 25k miles
TGMO 0W20 & OEM filter
Re: P0455 Large evap leak on my G35 [Re: bowlofturtle] #5193189 08/21/19 05:07 PM
CBR.worm Offline
On my two of my Infinitis of that generation, I had to replace the valve at the canister to fix that same DTC. That being said, it never hurts to confirm your specific case with the smoker.
'06 Infiniti G35 Sedan 6MT - 180k
Re: P0455 Large evap leak on my G35 [Re: chemman] #5206978 09/07/19 09:41 AM
B
B
After all my parts throwing at it, this was what I suspected.
Finally caved in and took it to a shop to smoke it, turns out there was a rust hole at the filler neck.
$250 dealer only part and 3 hours to R/R.
A little out of my capabilities at home to drop the tank a little to get to the area.
I would get a smoke machine but i also need to invest in a scantool with di-directional controls to turn on/off the purge valve as well. I realized this as i was about to order up the smoke machine linked on amazon.
My toys
Maintaining
-16 Jetta 1.4T 20k
