OBD scanner
by NH73 - 02/23/20 10:18 AM
Oil additive and effects on oil analysis results
by MoneyJohn - 02/23/20 09:48 AM
More 6.7 PSD engine repairs
by mattd - 02/23/20 09:10 AM
How to get sediment out of heater oil tank?
by BAJA_05 - 02/23/20 08:37 AM
Oil Prices in Europe
by BBDartCA - 02/23/20 08:08 AM
Fury -Wilder 3?
by pbm - 02/23/20 06:41 AM
toro super recycler
by passgas55 - 02/23/20 06:05 AM
Chain style for ag tires
by puma4440 - 02/23/20 04:25 AM
2014 GMC Terrain 2.4L AWD
by Char Baby - 02/23/20 02:06 AM
Conventional VS Synthetic In The Winter Months
by BlueOvalFitter - 02/23/20 01:36 AM
Paint Splatter
by rrretiree7 - 02/23/20 12:54 AM
The Jeep Made it to 150k Miles - Storytime
by Nick1994 - 02/23/20 12:54 AM
Supertech vs Dexcool
by WA1DH - 02/22/20 11:44 PM
Spark plug gap f
by Rohan - 02/22/20 10:28 PM
Mad mike hughes.rip
by Chris142 - 02/22/20 10:15 PM
MTF drain = chocolate milk
by Texasdoc - 02/22/20 10:02 PM
New Valvoline looks promising?
by kr_bitog - 02/22/20 08:45 PM
rock like debris in generac generator 17kw
by jb5150 - 02/22/20 08:25 PM
Chaucha, UofA, Jeffrey78, Markovchain, o_s
70787 Registered Users
95 registered members (benjy, 74Widebody, aquariuscsm, 2003f7, askani79705, 10 invisible), 2,452 guests, and 17 spiders.
Topics301,826
Posts5,203,484
Members70,787
Oil for my 2006 5.9 Cummins #5192505 08/20/19 08:35 PM
M
mobilaltima Offline OP
M
I just hit 100k miles on the truck in my sig, I've always ran CJ4 15W40 at 5-6k intervals. I just went to Wal Mart and was trying to decide between the Mobil Delvac 15W40 CK4 for 10.97 a gallon, and the Motorcraft 15W40 which has the 1000 ppm phosphorus, which Im assuming is CJ4 spec, for 18.68 for a 5 quart jug.
I ended up going with the Delvac CK4, my question is, should I return it and get the Motorcraft? Will the Motorcraft be that much better in terms of wear protection, or will the Delvac work just fine?
I'm not hard on this truck, it never goes past 75 mph on the rare interstate trip I do take..lives an easy life.
2006 2500 Dodge 5.9 Cummins Mobil Delvac 15W40, Fleetguard Stratapore 90k miles
Early '99 F250 ECLB 7.3 Stroker, 223k miles
Re: Oil for my 2006 5.9 Cummins [Re: mobilaltima] #5192516 08/20/19 08:55 PM
Capt Offline
http://pqiadata.org/Valvoline_15W40.html
^I would try this Valvoline white bottle 15w-40 it looks really good on paper for a CK4/SN 1,100 ppm phosphorus.
Walmart had it on clearance for $3 per gallon it looks like its still available online for $9.50. Try a purchase online and return in store and re-buy at counter?
Additionally Napa 15w-40 made by Valvoline has an identical VOA.
Re: Oil for my 2006 5.9 Cummins [Re: mobilaltima] #5192519 08/20/19 09:01 PM
Chris142 Offline
Super tech 15w-40. The truck will fall apart around that 5.9.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Oil for my 2006 5.9 Cummins [Re: mobilaltima] #5192524 08/20/19 09:14 PM
Propflux01 Offline
Consider Rotella 15w-40?
2014 Hyundai Elantra
2014 Hyundai Elantra GT
Re: Oil for my 2006 5.9 Cummins [Re: mobilaltima] #5192525 08/20/19 09:17 PM
R
Roost426 Offline
R
I would get the Supertech its zinc/phos levels are great even at ck4 spec, I think the delvac CK4 is down around 800ppm on both...
1990 Dodge W250 5.9 Cummins - VPB 15W-40,MO-285
1986 Ford F350 6.9 IDI - ST15W-40,MC FL1995
1987 Jeep Comanche 4.0L - Mobile Super 5K HM10W-40,Fram TG8A
1993 Ford Ranger 2.3L - RGT5w-30,Fram FPS8A
Re: Oil for my 2006 5.9 Cummins [Re: Capt] #5192584 08/20/19 10:59 PM
SavagePatch Offline
Do they have the Maxlife version of this posted? I couldn't find it.
Re: Oil for my 2006 5.9 Cummins [Re: Propflux01] #5192586 08/20/19 11:01 PM
SteveG4 Offline
Yep... any of the older 15W-40 oils from the Majors would do fine.
I would use Shell Rotella T4 15W-40. It's pretty much available everywhere.
If you can find it, look for CJ-4 formulation Chevron Delo 400 LE 15W-40.
Even Valvoline Premium Blue or their White Bottle in 15W-40 would do great.
And Chris142 is right. Your truck will fall apart around that Cummins engine.
Good luck.
Somewhere between Alaska and Wisconsin...
2006 Silverado LT Crew Cab 4WD & 2013 Equinox AWD
Re: Oil for my 2006 5.9 Cummins [Re: mobilaltima] #5192777 08/21/19 08:38 AM
Donald Online Content
Online Content
CJ-4 oil is getting hard to find.
2015 Ford F-250 w/Powerstroke
Re: Oil for my 2006 5.9 Cummins [Re: mobilaltima] #5192856 08/21/19 10:23 AM
dnewton3 Offline
Global Moderator
Global Moderator
Originally Posted by mobilaltima
... my question is, should I return it and get the Motorcraft? Will the Motorcraft be that much better in terms of wear protection, or will the Delvac work just fine?
Your engine will never know the difference between the two. Never, ever.
Or use the ST brand; just as effective.
Buy whichever is least expensive.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: Oil for my 2006 5.9 Cummins [Re: mobilaltima] #5192984 08/21/19 12:58 PM
BeerCan Offline
In my diesels I have been using Vavoline blue bottle15w40, I like it because you can always find it cheap and it is a great product. Plus for your application it is Cummins approved smile
2020 Porsche Cayenne
2017 Ford F250 6.7 PS
2016 Ford F150 3.5 EB
2016 Porsche 981 GTS
2015 Ford Mustang 2.3 EB
My car list is getting long smile
1994 Porsche 968 Coupe
1987 Porsche 944 Turbo
Re: Oil for my 2006 5.9 Cummins [Re: mobilaltima] #5202641 09/02/19 07:33 AM
O
ofelas Offline
O
In your climate, any CI4+, CJ or CK 15w40 will do just fine.
R12 in the summer, Webasto in the winter, and cassette tapes all year.
Re: Oil for my 2006 5.9 Cummins [Re: mobilaltima] #5207513 09/08/19 06:03 AM
T
turbowhistle Offline
T
I used own a 2002 F350 Super Duty with the very reliable 7.3 Power Stroke then made for Ford by International. It was a fantastic motor, trouble free and very easy to work on. It held 15 quarts of oil with that huge oil filter sitting at the bottom of the motor and very easy to get to. I used the Motor Craft 15w40 and always had good results. As you know, the Motor Craft oil was made for Ford at that time by Conoco- Phillips and was engineered to satisfy the needs of the Power Stroke due to the injection system that would sheer the oil.
I now have a 2011 Ram 3500 with the 6.7 Cummins and use the Rotella T6 all year. If it wasn't for some of the cold months, I would have no issue using Motor Craft 15w40 in my Ram.
As long as you use a 15w40 that meets the requirements along with a good oil filter and change the oil and filter as required, you shouldn't have any issues.
Re: Oil for my 2006 5.9 Cummins [Re: SteveG4] #5211990 09/13/19 05:43 PM
SteveG4 Offline
Good luck.
Did I say Valvoline "white bottle?" Oops... nobody's perfect. Valvoline's diesel oils are fine business...
