Denso Iridium TT's are great
by jayjr1105 - 02/23/20 01:46 PM
Girl Scout question
by ffhdriver - 02/23/20 01:36 PM
MTD Snowblower issues
by 97prizm - 02/23/20 01:19 PM
OBD scanner
by NH73 - 02/23/20 10:18 AM
Oil additive and effects on oil analysis results
by MoneyJohn - 02/23/20 09:48 AM
More 6.7 PSD engine repairs
by mattd - 02/23/20 09:10 AM
How to get sediment out of heater oil tank?
by BAJA_05 - 02/23/20 08:37 AM
Oil Prices in Europe
by BBDartCA - 02/23/20 08:08 AM
Fury -Wilder 3?
by pbm - 02/23/20 06:41 AM
toro super recycler
by passgas55 - 02/23/20 06:05 AM
Chain style for ag tires
by puma4440 - 02/23/20 04:25 AM
2014 GMC Terrain 2.4L AWD
by Char Baby - 02/23/20 02:06 AM
Conventional VS Synthetic In The Winter Months
by BlueOvalFitter - 02/23/20 01:36 AM
Paint Splatter
by rrretiree7 - 02/23/20 12:54 AM
The Jeep Made it to 150k Miles - Storytime
by Nick1994 - 02/23/20 12:54 AM
Supertech vs Dexcool
by WA1DH - 02/22/20 11:44 PM
Spark plug gap f
by Rohan - 02/22/20 10:28 PM
Chaucha, UofA, Jeffrey78, Markovchain, o_s
70787 Registered Users
98 registered members (bbhero, BBDartCA, Bailes1992, AZjeff, 74Widebody, 12 invisible), 2,774 guests, and 18 spiders.
Topics301,831
Posts5,203,557
Members70,787
Page 1 of 3 1 2 3
Removing Sludge to Prevent Engine Failure? #5192470 08/20/19 08:05 PM
04CorCar Offline OP
Hello,
I recently purchased a 2004 Toyota Corolla with only 85,000 miles on it. I bought it for a good price sight unseen and it runs great. I replaced the spark plugs, water pump, thermostat, coolant, brake pads, rotors, etc. My goal for this car is to have a reliable gas saver as my only car.
Here is the problem, when I went to change the oil and took off the fill cap, I noticed some sludge. When changing the oil, it came out very dark, pretty much black. I have no idea what kind of oil it was but I’m assuming cheap stuff. So I put in Penzoil High Mileage 5W-30.
So what I’ve decided is to pull the valve cover and oil pan, clean it as best as I can by hand and do an oil change after about 100 miles, then maybe 500 miles, etc?
The question is, with all of the above considered, what would be the best way to go about removing the sludge? I’m driving to move cross country at the end of the year and then will be using the car to get to and from work.
Thank you!
Re: Removing Sludge to Prevent Engine Failure? [Re: 04CorCar] #5192474 08/20/19 08:13 PM
L
Lolvoguy Offline
L
Originally Posted by 04CorCar
... what would be the best way to go about removing the sludge? ....
Disassemble engine, clean and check for significant damage.
Rebuild/replace anything showing noticeable wear.
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: Removing Sludge to Prevent Engine Failure? [Re: 04CorCar] #5192479 08/20/19 08:16 PM
R
Rolla07 Offline
R
Welcome to Bitog! First off, its an extremely reliable car. If I were in your shoes, I wouldnt of been as extensive as you. My 07 with 170k miles is still on its original water pump. Regardless thats another story. How bad was everything under the valve cover? How much oil drained out? These engines are easy on oil.
How have you confirmed its sludge? Show us pics of the valve cover and im sure some members can provide you tips and insight depending on level of sludge. Good luck!
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
2015 Toyota Venza Parisian Blue Pearl 25k miles
TGMO 0W20 & OEM filter
Re: Removing Sludge to Prevent Engine Failure? [Re: Lolvoguy] #5192481 08/20/19 08:17 PM
04CorCar Offline OP
Sorry about that, I meant the best way considering my plans above as for just removing the valve cover and oil pan. Meaning, should I put some type of engine flush in it before I take both off and/or multiple short interval oil changes?
Re: Removing Sludge to Prevent Engine Failure? [Re: Rolla07] #5192486 08/20/19 08:21 PM
04CorCar Offline OP
Thank you, they sure are. I owned an 04 before this and it never missed a beat.
Actually, I haven’t pulled the oil pan or valve cover yet. I just know it can’t be good considering what I saw under the fill cap AND how the oil drained out. I’ll definitely be removing the valve cover once I get the gaskets in to assess how bad it really is but I’m not totally sure I’ll be removing the oil pan yet, however I probably will since I can.
Re: Removing Sludge to Prevent Engine Failure? [Re: 04CorCar] #5192492 08/20/19 08:27 PM
Donald Offline
I would buy Supertech or NAPA synthetic oil and change at 3K intervals until it does not look so dark when changing. Forget about pulling the valve cover. Looking down the oil fill is not a good indicator. The goal is to remove or at least not let it get worse. Some sludge does not kill an engine. Its only when it starts to prevent the oil from returning to the oil pan that there is an issue.
And forget about an oil flush also.
2015 Ford F-250 w/Powerstroke
Re: Removing Sludge to Prevent Engine Failure? [Re: Donald] #5192530 08/20/19 09:22 PM
Chris142 Offline
I agree. You may cause more damage by messing with it.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Removing Sludge to Prevent Engine Failure? [Re: 04CorCar] #5192537 08/20/19 09:32 PM
Dave9 Offline
Get the high mileage oil out of it now, unless it was burning oil or there was a leak, and consider that your safer alternative to a flush, to just do that very short oil change.
I mean I would at least drive it up to temperature to work it around the engine and get the detergent action going if you JUST changed the oil, but otherwise HM oil does more harm than good for an engine that doesn't need it.
After that, do a 3K OCI then 5K or yearly whichever comes first.
Was the sludge in the engine or only built up on the back of the cap? Back of the cap is common even if not built up in the engine, but if the PCV valve hasn't been replaced recently, do that.
Re: Removing Sludge to Prevent Engine Failure? [Re: 04CorCar] #5192539 08/20/19 09:32 PM
M
Mad_Hatter Offline
M
If you're intent on removing the VC's and pan (for whatever the reason, and that's entirely your choice) I would run a good flush through the system. A single flush is not going to hurt anything and there's no better time to do it since you're replacing the pan and valve cover seals already. A flush like Motor Medic will not only clean up sludge but go work on varnish.
Following the flush, I'd run something like Castrol Ultraclean for a 3k oci and then switch back over to your lubricant of choice.
Just my 2 pennies...
Re: Removing Sludge to Prevent Engine Failure? [Re: 04CorCar] #5192541 08/20/19 09:34 PM
Supersonic Offline
Easy, change the oil and filter, then when it starts to look a little dirty, change it again, repeat as necessary. One trick I use is before reinstalling the drain plug is to dump about 20 ounces of fresh oil into it and just let it drain out to clear any additional old dirty oil. I put my last oil change up on Rhino-ramps to help the oil to pool at the back of the pan near the drain hole, and then seemed to get more of it out when the fresh oil drained through. Your results may vary.
I'd say if your going to replace the valve cover gasket, go ahead and clean that out, but the oil pan probably shouldn't be disturbed unless there is a leak.
Re: Removing Sludge to Prevent Engine Failure? [Re: Dave9] #5192548 08/20/19 09:48 PM
M
Mad_Hatter Offline
M
Where'd you hear that load of bull pucky?.. and have you considered letting XOM, Chevron, SOPUS, Warren et al. know about this revelation of yours???.. because they, the guys who actually formulate the stuff, seem to think differently. And let me know when you're starting your class action suit against the biggies...cuzz I need a new boat!😂
Re: Removing Sludge to Prevent Engine Failure? [Re: 04CorCar] #5192552 08/20/19 09:50 PM
Doublehaul Offline
The trick to a neglected vehicle like this is simply to use it and start maintaining it properly. I would get an oil change...and keep changing it every 5,000 miles. The sludge will clean itself out gradually which is what you want. Try to do it fast and you are going to plug an oil galley etc and cause damage. DONT MESS WITH IT.
Also make sure what you saw under the cap wasn't simply a milky sludge due to around town driving and condensation in the oil.
I had a totally sludged and noisy GM 4.3 that I got with just over 100k on it. By changing the oil every 5000 miles it cleaned itself out completely by 200k and it honestly ran fine until beyond 500k. No im not exaggerating.
2019 Toyota 4Runner 4x4 TRD
2019 Toyota Tacoma 4x4 TRD*
Mobil 1 0w40
The specs on the back are more important than the label on the front
Re: Removing Sludge to Prevent Engine Failure? [Re: Doublehaul] #5192571 08/20/19 10:28 PM
M
Mad_Hatter Offline
M
Then there's this 👆 approach which is 💯% tried and true. Some oils are known for their exceptional detergency. Run one of those for 5k oci's from here on out and you'll eventually get that "clean" engine you're looking for. (-except it won't do much for varnish, for that you're gonna need solvents)
Re: Removing Sludge to Prevent Engine Failure? [Re: 04CorCar] #5192582 08/20/19 10:56 PM
04CorCar Offline OP
Well, lots of varying opinions here I see. I appreciate all the input very much.
It seems that it may be in my best interest to leave the valve cover and oil pan gasket alone and just go on with my oil changes.
Thank you everyone, I’m sure it will work out!
Re: Removing Sludge to Prevent Engine Failure? [Re: 04CorCar] #5192623 08/21/19 04:04 AM
B
Bailes1992 Online Content
Online Content
B
I just used some Seafoam on my Mondeo with 141k on the clock. It's not the cheapest stuff to buy here in the UK (16oz bottle cost me £15).
I changed the oil out for a conventional 15w40 HDEO and a Fram Extra Guard filter. The car takes ~6 litres of oil so required 6oz of Seafoam. I took all the spark plugs out and distributed 7oz of Seafoam into each of the cylinders forcing it to run past the piston rings. I decided to add the extra Oz as some was about to hang around and not make it into the oil. I then ran it for ~300miles and drained the oil which was pitch black like diesel oil. Clearly some cleaning had taken place but nothing noticeable through the filler hole. It certainly hasn't touched the light varnish that I can see on the cam bearing caps.
I've swapped it out for Castrol Magnatec 10w40 which I will run until mid December. At which point I want to replace all of the valve cover gaskets so I will have a chance to properly see what it looks like under the covers.
19 Volvo V40 D3 Auto Shell Helix ECT 0w30
07 Saab 95 TiD Auto Castrol Edge 5w30 LL
03 Ford Mondeo 3.0 V6 Shell Helix 5w40
96 Defender 300TDi Maxlife 15w40
Page 1 of 3 1 2 3
