Girl Scout question
by ffhdriver - 02/23/20 01:36 PM
MTD Snowblower issues
by 97prizm - 02/23/20 01:19 PM
OBD scanner
by NH73 - 02/23/20 10:18 AM
Oil additive and effects on oil analysis results
by MoneyJohn - 02/23/20 09:48 AM
More 6.7 PSD engine repairs
by mattd - 02/23/20 09:10 AM
How to get sediment out of heater oil tank?
by BAJA_05 - 02/23/20 08:37 AM
Oil Prices in Europe
by BBDartCA - 02/23/20 08:08 AM
Fury -Wilder 3?
by pbm - 02/23/20 06:41 AM
toro super recycler
by passgas55 - 02/23/20 06:05 AM
Chain style for ag tires
by puma4440 - 02/23/20 04:25 AM
2014 GMC Terrain 2.4L AWD
by Char Baby - 02/23/20 02:06 AM
Conventional VS Synthetic In The Winter Months
by BlueOvalFitter - 02/23/20 01:36 AM
Paint Splatter
by rrretiree7 - 02/23/20 12:54 AM
The Jeep Made it to 150k Miles - Storytime
by Nick1994 - 02/23/20 12:54 AM
Supertech vs Dexcool
by WA1DH - 02/22/20 11:44 PM
Spark plug gap f
by Rohan - 02/22/20 10:28 PM
Mad mike hughes.rip
by Chris142 - 02/22/20 10:15 PM
Chaucha, UofA, Jeffrey78, Markovchain, o_s
70787 Registered Users
107 registered members (69GTX, 53' Stude, ammolab, 74Widebody, ABursell, 97prizm, 10 invisible), 2,843 guests, and 23 spiders.
Topics301,830
Posts5,203,536
Members70,787
ULSD and HPFP's #5192458 08/20/19 07:54 PM
sloinker Offline OP
The ULSD is capped at 15ppm for on road vehicles. Do the latest HPFP's run ok on this without added lubricity added at the terminal/truck/station? If you got a batch of ULSD fuel that was without additives would you harm your older or newer HPFP?
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Ravenol VMP 5W30
'15 VW Golf Sportwagen TDI VMP 5W30
'14 Dodge Grand Caravan 3.6 Red Line Blue Label 5W20
'64 Plymouth Fury440 Red Line Blue Label 10W40
Re: ULSD and HPFP's [Re: sloinker] #5192645 08/21/19 05:18 AM
B
BMWTurboDzl Offline
B
Un-additized ULSD will cause excessive wear on the fuel system and could also have a low cetane rating which results in poor starting performance.
435i
Re: ULSD and HPFP's [Re: sloinker] #5192670 08/21/19 06:05 AM
O
Olas Offline
O
TCW3 gives all the lubricity you need, and a splash of 2ehn gives better starting&performnce
Cable ties should hold it
Re: ULSD and HPFP's [Re: sloinker] #5192780 08/21/19 08:42 AM
K
kschachn Offline
K
I always find these threads interesting. So do the majority of all diesel owners use an additive, or is there a large percentage of failures on fuel pumps? I don't imagine most owners use an additive, do they? Don't they just fuel and go like everyone else? If so, how long can you go before there is a failure of pump?
Seems so odd that a change in fuel composition was made that essentially damages a significant percentage of the trucks in existence.
1994 BMW 530i, 251K
1996 Honda Accord, 280K
1999 Toyota Sienna, 430K
2000 Toyota ECHO, 284K
Re: ULSD and HPFP's [Re: kschachn] #5192870 08/21/19 10:52 AM
B
BMWTurboDzl Offline
B
IMO there is an opinion that fuel systems used in light passenger cars/trucks are less robust (Ex, VW TDI's had a rash of HPFP failures back in 2011 or so) AND/OR European diesels almost always call for Cetane of 51 or more. IIRC US diesel is spec'd at a min of 40 and real-world testing usually came in around 45-48.
Since diesel pumps in my area never indicated a cetane of 51 or more let alone bio-diesel concentration, I always used an additive which contained a cetane booster (2EHN) when I had my 335d for this very reason. I felt it would prolong the life of my DPF and I would realize slightly better experience via more complete combustion which would reduce EGR usage.
435i
Re: ULSD and HPFP's [Re: sloinker] #5192915 08/21/19 11:40 AM
sloinker Offline OP
I'm just wondering if the latest pumps are robust enough to withstand the lowest sulfur fuels in case they forgot to add the lubricity/cetane modifiers along the way. You are seeing failures of older pumps before their usual service life. VW's and their Bosch pumps seem to be the most issues although there are a goodly amount of Ford and GM horror stories too. Are the newest pumps immune?
Re: ULSD and HPFP's [Re: sloinker] #5192999 08/21/19 01:12 PM
BeerCan Offline
So I fell prey to the Ford HPFP failure thread on another forum. So I add a small dose of Alliant ultraguard at every fill. I also try and use at least B5 if I can find it. Bio diesel is a good lubricant. I have about 200K on different Ford 6.7's and no issues. I think the issue is a little overblown but for sure the Bosch CP4 had some teething issues. I feel they got it sorted on the CP 4.2
2020 Porsche Cayenne
2017 Ford F250 6.7 PS
2016 Ford F150 3.5 EB
2016 Porsche 981 GTS
2015 Ford Mustang 2.3 EB
My car list is getting long smile
1994 Porsche 968 Coupe
1987 Porsche 944 Turbo
