belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
Help me understand
by 1978elcamino - 02/24/20 02:25 PM
2019 VW Passat Trip Mileage
by Boomer - 02/24/20 01:13 PM
Changed my ATF, difference is crazy!
by cwilliamsws6 - 02/24/20 12:36 PM
Specs on Conventional Oils 4 Comparing
by Perseus - 02/24/20 12:32 PM
EarlT500, Newbie111, Boris_Be, NHR, zip15
70798 Registered Users
53 registered members (aleneros, BlakeB, 928, bbhero, Arob, Bailes1992, 6 invisible), 1,425 guests, and 22 spiders.
Topics301,895
Posts5,204,845
Members70,798
Sealing Redundant Door #5192359 08/20/19 06:25 PM
gathermewool Offline OP
LARGEST GAP IS 1/2"
The door doesn't seal well and has been bothering me since we moved in a couple of years ago. In the afternoon, I can feel the heat coming through some of the worst parts of the poorly-installed door. From the outside, with music blasting, I can hear a major difference when I pull the door hard toward me, connecting the seal more fully.
This door is redundant - it has been used ZERO times since we've moved in. We use the sliding door to access the deck. When this section of the house was added by the previous owners (living room over garage), it's almost as if it was an afterthought.
What's the best way to semi-permanently seal it.
If we ever do a major renovation, it'll likely be replaced with just a window, though I'll likely be too cheap to actually opt for that if I can seal it off well enough!
Here are the pics. I didn't clean, because, well, I've got a lot more going on than needing to pretend my house is actually ever cleaner than it looks in these pics!
[Linked Image]
[Linked Image]
14 Forester XT Touring FA20DIT (Cobb Stage 1)
Castrol Magnatec 5W-30 D1G2 + FU filter (72,320mi, 8/24/19)
15 Legacy Premium FB25
Magnatec 5W-20 + FU filter (47,300mi, 5/11/19)
Re: Sealing Redundant Door [Re: gathermewool] #5192366 08/20/19 06:31 PM
skyactiv Offline
Elmer's glue.
Joking
Me: 18' Elantra Sport 6 speed manual
The rude guy that points out reality
Re: Sealing Redundant Door [Re: gathermewool] #5192374 08/20/19 06:36 PM
H
hemitom Offline
H
can you move the door latch plate a little to tighten the door when you pull it closed ??
2009 Saturn Vue.
2015 Mustang GT Convertible.
Re: Sealing Redundant Door [Re: gathermewool] #5192378 08/20/19 06:43 PM
O
oemjunk Offline
O
If you don't ever use it, just get rid of it. A few 2x4's and some drywall and paint. Never no it was there.
2000 Chevy Stepside - PP 5W-30
1973 Buick Boattail
2006 Poulan Pro 42" - M1 5W-30
Re: Sealing Redundant Door [Re: gathermewool] #5192381 08/20/19 06:48 PM
danez_yoda Offline
Yes adjust the door jam latch more towards the inside. you will have to pull the door harder to close.
Otherwise just replace the weather stripping and scoot it a bit forward of the previous one.
Re: Sealing Redundant Door [Re: gathermewool] #5192391 08/20/19 06:59 PM
My wife wants the sunlight.
Would using closed-cell foam actually make more sense in this case?
Note: I'm a total newb carpenter. My wife wants the light there for all the plants she intends to kill throughout the year.
The largest gap is on the outswing side.
The door will literally never be used in the next few years or until we demo the door and replace it with a window (beyond my skill-set at this time).
1. Weatherseal replacement only makes sense for a door in-use
2. re-orienting the door only makes sense for a door in-use
Right?
Re: Sealing Redundant Door [Re: hemitom] #5192404 08/20/19 07:08 PM
I could install a deadbolt, and try to make it so that the bolt only inserts with the door FULLY shut. With my skills, there's a 50/50 chance that won't seal the door sufficiently for my needs (i.e.,. never to be used, max seal)
Re: Sealing Redundant Door [Re: gathermewool] #5192410 08/20/19 07:14 PM
W
Warstud Offline
W
May only need one 2x4 down the middle of the door add some insulation then drywall then paint. You may have to replace all the siding to make it look right tho.
Re: Sealing Redundant Door [Re: gathermewool] #5192423 08/20/19 07:24 PM
Eddie Offline
Put a window there to match the other two on the same wall. Will look more professional. Ed
2014 CX5 Touring 2.5L :-)
Re: Sealing Redundant Door [Re: gathermewool] #5192461 08/20/19 07:56 PM
Again, money is a concern for now. I likely won’t replace the door for a few years. Foam?
Re: Sealing Redundant Door [Re: gathermewool] #5192466 08/20/19 08:02 PM
PimTac Offline
Dittos on the window idea.
2017 Mazda CX5
Valvoline Advanced Synthetic 0w20
Roki OEM filter.
Re: Sealing Redundant Door [Re: gathermewool] #5192497 08/20/19 08:29 PM
G
greenjp Offline
G
Maybe something like a caulking backer rod would work? Closed cell foam tubes, come in a variety of sizes. Easy to stuff in there.
jeff
Re: Sealing Redundant Door [Re: gathermewool] #5192499 08/20/19 08:30 PM
F
Fawteen Offline
F
You can actually buy weatherstripping and door seals that will help, along with making adjustments to the door. If you really don't use the door at all, you can also get some peel & seal caulking along with some backer rod (1/2 inch gap is huge). The peel & seal caulking has the advantage of working like regular caulk, but also peels right off if you ever want to use (or remove) the door.
Re: Sealing Redundant Door [Re: gathermewool] #5192520 08/20/19 09:05 PM
O
oldhp Offline
O
Open it, chalk it really good, shut it, put 2 drywall screws to hold it tight. Smooth the chalk out. Fuhgedaboudit........
"None of us are getting out here alive.....drink that beer.....eat that pizza......drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just wait"
Re: Sealing Redundant Door [Re: gathermewool] #5192626 08/21/19 04:09 AM
R
RayCJ Offline
R
Is there any chance the doorway is needed to meet building code? If so, the building inspection during re-sale might get interesting.
