I bought a handheld Cub Cadet brush cutter / grass trimmer. Need to cut brush like wild rose bushes. Too stalky/woody for a grass trimmer.
What would be the better blade, a blade that looks like you would have in a circular saw or one that looks like a circle with 4 rectangles welded to it that are the actual teeth?
I tried it today and while it easily will cut a woody wild rose bush, it has trouble when you you try to go into a thicket of various tall weeds including wild rose bushes and cut them.
I used the blade that comes with it that is like a circle with 4 rectangles welded to it.
