I know the OP is in Florida where he likely doesn't have a basement. But I wonder if a dehumidifier would help in northern climes where basements are more common. Hot air rises and thus there is often a vacuum pulled on the basement, so I wonder if dehumidifying the basement might lead to more dry air being pulled upstairs, which may be cooled more easily.
Originally Posted by Gillsy
Originally Posted by Alfred_B
I would use a portable AC for additional cooling. Some have a dry function as well.
Portables in my opinion won't help. All that hot air that the portables blow outside is replaced with outside air being drawn back into the house or you would wind up with a vacuum. They in my situation raise the humidity in the house, and I verify that with a hygrometer. If the condenser is too big, it may short cycle, and not run long enough to remove the humidity. If too small, it can't remove enough humidity no matter how long it cycles. I'm no HVAC pro, but maybe someone with more know-how can chime in.
Some portable units are single hose, and you'd be right. However some are dual hose and will use outside air instead. But they do cost a bit more.
