Oils for old engines
by puma4440 - 02/25/20 08:18 PM
Do you still use liquid and paste sealants
by WhyMe - 02/25/20 08:16 PM
VW dealer hilarity - window tinted the wrong car.
by pezzy669 - 02/25/20 07:53 PM
New style Goodyear Duratrac
by NHRATA - 02/25/20 07:44 PM
Need oil additive advise for replacement engine.
by 13Track38 - 02/25/20 07:18 PM
New member with UOA to share
by JamesGames - 02/25/20 07:10 PM
When do you do DIY?
by BMWTurboDzl - 02/25/20 06:47 PM
synchromesh
by hunter29 - 02/25/20 06:41 PM
Ever buy a stranger lunch ?
by Mr Nice - 02/25/20 06:18 PM
36 bucks for balancing two tires....
by Vern_in_IL - 02/25/20 05:20 PM
project farm like test for Maxlife vs toyota WS
by danez_yoda - 02/25/20 05:09 PM
Audi Q5 Transmission oil?
by John344 - 02/25/20 04:35 PM
Valvoline Modern engine
by Villalobos - 02/25/20 04:35 PM
Rust bubbles
by WA1DH - 02/25/20 04:27 PM
Which of these sub $4 filters
by jayjr1105 - 02/25/20 04:05 PM
Flaring tool
by P10crew - 02/25/20 01:52 PM
Hazet 600LG/8 Wrench set - $160
by drtyler - 02/25/20 01:34 PM
akarip, BJD2020, ToyTaco2002, EarlT500, Newbie111
70801 Registered Users
101 registered members (antonmnster, 2003f7, 928, Alfred_B, AC1DD, 8 invisible), 2,277 guests, and 16 spiders.
Topics301,931
Posts5,205,667
Members70,801
Page 1 of 5 1 2 5
Amsoil SS Noack numbers #5192146 08/20/19 02:08 PM
SlavaB Offline OP
Disclaimer: I'm not an Amsoil fan, user or dealer. I don't want to start an OCI intervals war here, just as a matter of fact I'm sharing some info I think is interesting.
I've tried Amsoil in my Kia in past once, but really felt no difference in engine running so decided to switch back to off the shelf oils.
Yet every once in a while I go and check specs data for different brands and here's what I found yesterday for Amsoil Signature line - Noack 5.8 for 5w20 and 4.1 for 10w30.
This does sound like a lowest Noack numbers I've seen, what do you guys think?
Link https://www.amsoil.com/lit/databulletins/g2880.pdf
17 Kia Sportage EX 2.4 GDI / Castrol Magnatec 5w30, OEM filter
15 MB GLA250 4Matic 2.0T / Mercedes OEM 5w40, OEM filter
Re: Amsoil SS Noack numbers [Re: SlavaB] #5192159 08/20/19 02:16 PM
J
JLTD Offline
J
Amsoil typically does have very low NOACK numbers, and are - if not THE lowest - one of the lowest I've seen. That said, I've used other oils at shorter intervals and a NOACK of 8 or 10 did not burn off much oil during an OCI; approximately from top of the full mark to 1/3 from the bottom mark in 10,000mi / 16000km, or about 3/4 quart/750ml.
Lates.
Re: Amsoil SS Noack numbers [Re: SlavaB] #5192168 08/20/19 02:24 PM
SirTanon Offline
I have to actually wonder how much the tested NOACK numbers actually apply under 'real world' operating conditions.
I say this because, over the course of at least 8 or 9 OCIs in my 2010 Fusion, I would fill the oil to the top of the hash marks on the dipstick, and then when the next OCI time came, and I checked the dipstick, the oil was still at the top of the hash marks, with no added oil required during the 7,500 miles between. Sure, there might have been a negligible amount of change that I could not differentiate with my own eyes, but it was just that - negligible. I would expect with an average NOACK between 9 and 12%, I would have seen it at least down by 1/4", but I never did. It wasn't ever even 1/8".
2013 Nissan Altima SV - 2.5 liter/CVT - 125,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 68,000mi
2010 Ford Fusion - 274k mi - SOLD
Re: Amsoil SS Noack numbers [Re: SirTanon] #5192175 08/20/19 02:32 PM
B
buster Offline
B
I don't think it matters all that much. My preference is anything less than 10%, although many have used oils higher than that with no noticeable oil burn off. The engine type and oil control rings plays a big part.
2019 Frontier Pro 4X - RGT 5w30
2019 Impreza Sport - OE fill
Re: Amsoil SS Noack numbers [Re: SirTanon] #5192201 08/20/19 02:59 PM
demarpaint Offline
Great point. How hot does the oil have to get for the Noack numbers to really matter? Lets say between a Noack of 10 and a Noack of 8.8, or 4.1? I'd say a lot hotter than the engine oil ever reaches. I think some of us put too much emphasis on Noack.
God Bless Our Troops
Re: Amsoil SS Noack numbers [Re: demarpaint] #5192236 08/20/19 03:43 PM
SlavaB Offline OP
The thing is (if my understanding is correct) it doesn't take much oil for carbon buildup to appear in GDI engine, so hence the lower the better
Re: Amsoil SS Noack numbers [Re: SlavaB] #5192239 08/20/19 03:44 PM
B
burla Offline
B
Noack are one measure of viscosity so are cst and hths. If you look at cst and hths kind of shows low viscosity oil, meaning easier to achieve lower noack. Amsoil is a very stable oil, just not very thick.
Re: Amsoil SS Noack numbers [Re: SlavaB] #5192249 08/20/19 03:54 PM
V
Virtus_Probi Offline
V
Just looking at 5W30s, Ravenol DXG beats SS by just a bit at 6.0% Noack loss.
https://www.ravenol.de/en/products/usage/d/Product/show/p/ravenol-dxg-sae-5w-30.html
The old M1 5W30 ESP Formula was also supposed to be right around 6%, although I'm not sure if we ever saw a result from the manufacturer on that one. That was a higher HTHS oil, something like 3.58 cP with the other two around 3.1 or so.
Seems like 10W30s in the area of 4% are not that hard to find...the PQIA even had PYB near that level, although it didn't last.
http://www.pqiadata.org/Pennzoil10W30.html
2014 Forester XT, 111000 miles
Last Change;
M1 0W30 AFE
Tokyo Roki 15208AA170 filter
Re: Amsoil SS Noack numbers [Re: burla] #5192589 08/20/19 11:14 PM
O
OilUzer Offline
O
Can you please elaborate?
Re: Amsoil SS Noack numbers [Re: SlavaB] #5192595 08/20/19 11:44 PM
O
OilUzer Offline
O
Castrol GTX Magnatec 10Wx30 has Noack of 6.4 or 6.9 it's one of those but can't recall.
some Kia/Hyundai people like it along with their other favorite oils ... you know flavor of the month/oci ...
The new jugs are full synthetic. Older jugs were syn-blend.
~$22.00 / 5 qt. On Wal-Mart website.
If you are chasing $ per Noack, it's not a bad price!
The only problem is that your engine may end up smarter than you shocked2 grin2
Re: Amsoil SS Noack numbers [Re: OilUzer] #5192598 08/20/19 11:55 PM
SlavaB Offline OP
[quote=OilUzer]Castrol GTX Magnatec 10Wx30 has Noack of 6.4 or 6.9 it's one of those but can't recall.
The only problem is that your engine may end up smarter than you shocked2 grin2[/
I’ve used Magnatec at the previous OCI and it was the smoothest oil I’ve tried. Will most probably switch back to it at my next OCI
Re: Amsoil SS Noack numbers [Re: SlavaB] #5192611 08/21/19 02:00 AM
M
Mad_Hatter Offline
M
A recent survey of lubricant professionals conducted by MachineryLubrication.com found 80%+ did not conduct regular volatility testing of lubricants... take that for whatever it's worth.
My guess is unless you're engines got a drinking or cooling problem, it doesn't matter much. I have 160k miles on my engine and regularly run oils with a 10%+ noack and NEVER EVER have had to top off. My engine never gets close to the 250c test temperature of the noack volatility test. In fact the hottest coolant temp I've ever seen using my OBD2 is 206c... that's not even boiling water temp, let alone oil. (grp2 are good to 250 before they begin to breakdown and grp3 or better, around 300c right???... that's gonna be well above the boiling point of your avg coolant mix/rad cap)
The way I see it, unless you have one of the aforementioned issues or you're regularly spending time on the track... noack is just not worth something losing sleep over.
Re: Amsoil SS Noack numbers [Re: Mad_Hatter] #5192622 08/21/19 04:00 AM
demarpaint Offline
javascript:quickReply(5192611,1,0)
I think you're right. I can't speak from experience about a DI engine, I don't own one. But as I said earlier the engine would have to far exceed operating temperature imo for Noack to play in, and at that point you'd have more important things to be concerned with. I still think it is something over thought in probably over 90% of the vehicles on the road today. JMO
Re: Amsoil SS Noack numbers [Re: SlavaB] #5192644 08/21/19 05:18 AM
wemay Offline
From what I've read recently, It's a test that has repeatability issues therefore doesn't give you consistent results. I was one of those Noack % chasers for while. No more.
19 VW Passat Wolfsburg TSI (VW Genuine 0W-20+OEM)
13 Hyundai Santa Fe Sport 2.0T (Shell RGT 5W-30+OEM)
Re: Amsoil SS Noack numbers [Re: wemay] #5192648 08/21/19 05:23 AM
demarpaint Offline
thumbsup After doing my own homework and research I'm not going to chase it either. There's more to a good oil than Noack numbers.
Page 1 of 5 1 2 5
