Seems like one problem after another with the house HVAC this year. This time it was the central AC condensation pump tube that goes to the drain pump. Which pushes water outside during the cooling season. It clogged with some kind of crud and flooded a finished basement drip by drip for maybe a month. We have booms, water alarms, caulking all around the base of the partition walls of the room the HVAC is located in. But because of the slow drip it penetrated the concrete, got under the boos, caulking, into the floor and out into the room. The basement family room is finished. It does have supposed flood and mold proof pads underneath the carpet but it's definitely wet and has not dried fully in several days. I've done my best with fans and wet vacs.
Now that I found the problem and fixed it I'm looking for opinions on sealing concrete floors. Some say it's good some say don't do it. I would like to seal the HVAC room floor with some type of sealer so water will not absorb into the concrete so easily. There is nothing on the floor in that room it's just naked concrete which is in good shape. Or is there a better solution.
