belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
Help me understand
by 1978elcamino - 02/24/20 02:25 PM
2019 VW Passat Trip Mileage
by Boomer - 02/24/20 01:13 PM
Changed my ATF, difference is crazy!
by cwilliamsws6 - 02/24/20 12:36 PM
Specs on Conventional Oils 4 Comparing
by Perseus - 02/24/20 12:32 PM
EarlT500, Newbie111, Boris_Be, NHR, zip15
70798 Registered Users
49 registered members (bbhero, Bailes1992, aleneros, berlyn, BlakeB, 928, 4 invisible), 1,412 guests, and 21 spiders.
Topics301,895
Posts5,204,851
Members70,798
Using a 7.1 receiver with only 2 speakers #5191634 08/19/19 07:44 PM
P
Papa Bear Offline OP
P
I have the opportunity to get an Onkyo TX-SR606 7.1 receiver for a great price but I want to use only 2 speakers on it - will it work satisfactorily with speakers hooked to LF & RF only?
I only plan to listen to FM radio.
TIA
Papa Bear (Bob)
2016 Dodge GC Deep Cherry 5W-30 Dino
2013 SYM Wolf Classic 150 T4 15W-40
2009 V-Star 250 Black Cherry 20W-50 Dino
https://www.hogsforhospice.com/
Friend of Bill W. since '89
Re: Using a 7.1 receiver with only 2 speakers [Re: Papa Bear] #5191638 08/19/19 07:48 PM
J
JeffKeryk Offline
J
Onk is, in my opinion, a great bang for your buck.
Use it in stereo mode with confidence.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Using a 7.1 receiver with only 2 speakers [Re: Papa Bear] #5191642 08/19/19 07:52 PM
d00df00d Offline
Absolutely.
It actually has the capability to bi-amp the front speakers, if your speakers have that feature as well.
2008 BMW M3 Sedan 6MT
Re: Using a 7.1 receiver with only 2 speakers [Re: Papa Bear] #5191650 08/19/19 08:02 PM
L
Leo99 Offline
L
I have that exact receiver. Had to replace some caps on it but it still doesn't display the volume visually. Other than that, it works great.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 392,000 miles
2015 Camry 90,000 miles
Re: Using a 7.1 receiver with only 2 speakers [Re: Papa Bear] #5191658 08/19/19 08:18 PM
P
P
Thanks !! cool
Re: Using a 7.1 receiver with only 2 speakers [Re: Papa Bear] #5191667 08/19/19 08:33 PM
Quattro Pete Offline
It will certainly work with only two speakers.
What speakers do you have?
Is the receiver used? If so, and if the previous owner used it with a powered sub, you may want to go into the settings and tell it that you don't have a sub anymore. This should reclassify your main L/R speakers as "large" so they can receive full frequency spectrum. Otherwise, you may not be getting any bass into your L/R speakers. Then again, if your L/R speakers are fairly small, then you may not want to send low end bass to them anyway.
2002 530i   2015 Q5 3.0T   2018 Charger SRT
Re: Using a 7.1 receiver with only 2 speakers [Re: Papa Bear] #5191668 08/19/19 08:33 PM
H
hallstevenson Offline
H
Yes, it will work with just (2) speakers fine. It should have a setup menu where it asks you about your speakers - front speaker size, rear size, center size, subwoofer size, distance from seating area, height, and so on. You should be able to tell it "none" or similar for the speakers you don't have. Also play with the "surround" settings to find which sounds best with a 2-speaker setup.
Re: Using a 7.1 receiver with only 2 speakers [Re: Papa Bear] #5191698 08/19/19 09:22 PM
Skippy722 Online Happy
Online Happy
Got an Onkyo TX-DS474 (5.1) with 2 speakers at work. It’s been running ~22 hours a day for at least the last 5 years. It’ll be just fine!
2016 Chrysler 300S v6
2018 Dodge Grand Caravan GT
Slight Mopar obsession
Re: Using a 7.1 receiver with only 2 speakers [Re: Papa Bear] #5191702 08/19/19 09:33 PM
N
NO2 Offline
N
I hope it is really cheap because the design is over 10 years old, meaning that that more modern surround standards are not supported and it is 1080p only.
Onkyo is not know for reliability either. They usually sound good. If you are just using it for music it will be fine, but you will miss some niceties like Airplay, and you'll have to hook up an external device to stream music.
Re: Using a 7.1 receiver with only 2 speakers [Re: Papa Bear] #5191725 08/19/19 10:32 PM
N
NO2 Offline
N
Onkyo is not know for reliability either. They usually sound good. If you are just using it for locally connected music it will be fine (like FM you described), but you will miss some niceties like Airplay, and you'll have to hook up an external device to stream music
FM over the air is going to sound pretty bad compared to streaming, even FM station streaming. I don't think this unit has HD radio.
Re: Using a 7.1 receiver with only 2 speakers [Re: Quattro Pete] #5191844 08/20/19 06:43 AM
P
P
I'm borrowing a pair of Alesis Monitor 1 speakers from my son.
I won't get an owner's manual or set-up microphone etc the tuner seems quite sensitive and the power amp has good clean sound.
It'll likely be just the ticket for my 75 yr old ears..... thumbsup
Re: Using a 7.1 receiver with only 2 speakers [Re: Papa Bear] #5191859 08/20/19 07:06 AM
Nice! According to specs, these are rated down to 45 Hz, so you do want to make sure the sub crossover network on the receiver is disabled, or else you'll be missing out on some bass frequencies.
Link to owner's manual:
https://www.intl.onkyo.com/downloads/manuals/pdf/tx-sr606_manual_e.pdf
Re: Using a 7.1 receiver with only 2 speakers [Re: Quattro Pete] #5191861 08/20/19 07:09 AM
P
P
Thanks, Pete
Re: Using a 7.1 receiver with only 2 speakers [Re: Papa Bear] #5191915 08/20/19 08:26 AM
R
Rolla07 Offline
R
I would just get a stereo receiver for 2 speakers unless u plan on using more in the future. Just for FM radio, no need for anything fancy or a 7.1 receiver. Just my 2 cents
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
2015 Toyota Venza Parisian Blue Pearl 25k miles
TGMO 0W20 & OEM filter
Re: Using a 7.1 receiver with only 2 speakers [Re: Papa Bear] #5191926 08/20/19 08:53 AM
Chris Meutsch Offline
You should be perfectly fine. I have an Onkyo from 2008 and only use two speakers most of the time in my apartment. I do have Elac's and an Elac center channel also, but it doesn't care as long as you set it to how you like it.
2005 Honda CR-V EX, 280k
