belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
Help me understand
by 1978elcamino - 02/24/20 02:25 PM
2019 VW Passat Trip Mileage
by Boomer - 02/24/20 01:13 PM
Changed my ATF, difference is crazy!
by cwilliamsws6 - 02/24/20 12:36 PM
Specs on Conventional Oils 4 Comparing
by Perseus - 02/24/20 12:32 PM
EarlT500, Newbie111, Boris_Be, NHR, zip15
70798 Registered Users
60 registered members (apollo18, Arob, Bailes1992, A_User55555, alcyon, 7 invisible), 1,435 guests, and 20 spiders.
Topics301,895
Posts5,204,837
Members70,798
Eco Plug oil drain plug #5191570 08/19/19 06:15 PM
P
passgas55 Offline OP
P
https://ecoplugsystem.com/10mm-14mm-magnetic-oil-drain-plug/
I have an old Yanmar tractor and the oil pan is stripped. It does not leak but you can not tighten it. Just a little snug.
I feel it will end up leaking. I can remove the pan and try to go one size up on a tap with new drain plug. I happen across the ecoplug.
Any one has used one of these?
Re: Eco Plug oil drain plug [Re: passgas55] #5191590 08/19/19 06:39 PM
R
Reggaemon Offline
R
It probably works as advertised and a tractor would seem to be a good place to use it, but I can't imagine using that plug on a car.
After every bump in the road I'd be checking my rear view mirror to see if I was putting down a fresh oil slick.
Re: Eco Plug oil drain plug [Re: passgas55] #5191614 08/19/19 07:19 PM
simple_gifts Offline
If you google Dorman 65240; i have used something similar. The claws parts are spring loaded so it snaps open after you feed it thru the drain hole
I had a Caprice SBC305 with a bent pan AND a stripped drain plug (not my doing)
Tons of BITOG'rs would never use something like it, but no one has ever produced a technical reason not to.
Here it is
https://www.oreillyauto.com/detail/...orman-autograde-drain-plug/65240/4182313
forgot to add crankshaft clearance is a concern for some vehicles/motors
2004 Prius; 126K; ALM
2007 Yaris 103K ATM
2006 B2300;137K;ALM
Was driving an ox cart; Now on the USS Enterprise
Re: Eco Plug oil drain plug [Re: passgas55] #5191645 08/19/19 07:58 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
If its a steel pan, cutting new threads should be trustworthy, but that product looks interesting.
The alternative is to use a time sert kit.
https://www.bobistheoilguy.com/foru...6559/diy-time-sert-oil-pan-thread-repair
Re: Eco Plug oil drain plug [Re: simple_gifts] #5191663 08/19/19 08:24 PM
P
P
Here it is
Yes I looked at those too. I like them in that I feel better with it being held tight by a screw and toggle instead of a strong magnet,. Then again the magnet is more flush and easier to change out with out worrying about your wings ending up in your oil pan. Come this winter I will fix it either by magnet. wingnut or drill and tap. I did cheap out during oil change with oil filter(OrangeCOD)
and do want to replace when I do the plug.
Re: Eco Plug oil drain plug [Re: JHZR2] #5191664 08/19/19 08:33 PM
P
P
I saw that in my search on what my options were. I really don't want to drill my plate because if I screw up I may have a hard time finding a new plate. I may buy a new tractor in a year but I do have a use for this one. Got to keep it running.
Re: Eco Plug oil drain plug [Re: passgas55] #5196507 08/25/19 06:32 PM
Here it is
Wings will not come off as the threaded shaft is crimped on the end.
2007 Yaris 103K ATM
2006 B2300;137K;ALM
